Blindhamster Posted June 25, 2023 Share Posted June 25, 2023 24 minutes ago, Spyros said: Can you share the instructions' profile? The way I see it in the index, the rifles may have more shots and AP but only deal mortals on 6+. Isn't it better (against infantry) to use combis the deal mortals on 4+? Deployed in rapid fire range and buffed by OoM or incursors the combis should be murderous... Other people have done the math in the sternguard thread, but basically bolt rifles on sternguard push through more wounds and more mortals against almost every target, I believe toughness 5 infantry the combos work out slightly better but that’s it. if you check the leviathan thread in N&R forum someone posted instructions for the sternguard and originally the plasma was anti monster, melta was anti vehicle with melta 2, they were all 2 shots hitting on 3s. but that’s not the rules we currently have Karhedron, Khorneeq and Spyros 3 Back to top Link to comment https://bolterandchainsword.com/topic/379147-how-will-you-expand-your-army-in-10th/page/2/#findComment-5965130 Share on other sites More sharing options...
Karhedron Posted June 25, 2023 Share Posted June 25, 2023 I am busy putting together a unit of Sternguard. I am building them with bolters ATM but I am going to keep the option for combis in my back pocket. Basically, combis pull ahead against heavy infantry like Terminators and above but against other targets, the higher rate of fire and BS on the bolt rifles gives them the edge. It just depends what you want them to do. With OOM, a Squad of Sternguard will still kill a couple of Terminators which is not too shabby at all. Spyros 1 Back to top Link to comment https://bolterandchainsword.com/topic/379147-how-will-you-expand-your-army-in-10th/page/2/#findComment-5965168 Share on other sites More sharing options...
ShadowCaptainMcCaffery Posted June 25, 2023 Share Posted June 25, 2023 The only thing that I am planning on adding to my Blood Angels are a couple of Deimos Rhinos and a unit of Relic Terminators. This is because my army is my 30K army pulling double duty. Link to comment https://bolterandchainsword.com/topic/379147-how-will-you-expand-your-army-in-10th/page/2/#findComment-5965234 Share on other sites More sharing options...
Spyros Posted June 26, 2023 Share Posted June 26, 2023 11 hours ago, Karhedron said: Basically, combis pull ahead against heavy infantry like Terminators and above but against other targets, the higher rate of fire and BS on the bolt rifles gives them the edge. It just depends what you want them to do. With OOM, a Squad of Sternguard will still kill a couple of Terminators which is not too shabby at all. That's my thinking too, Sternguard as heavy anti-infantry, ergo combi-weapons. I'm not going to fish 6s from rifles as an anti-tank/monster option, I'll use dedicated units for that job. Link to comment https://bolterandchainsword.com/topic/379147-how-will-you-expand-your-army-in-10th/page/2/#findComment-5965286 Share on other sites More sharing options...
