 The B&C Presents:
The Call to Arms 2023
IMPERIUM STRONGHOLD
What better way to celebrate a new edition of our favourite table-top wargame than to have a big Inter-Forum Painting Event, amiright? Time to bust out those brushes and paints and stand ready to represent your Forum/s of choice and aid them on the path to claim Victory!!!!
What is The Call to Arms, I hear you ask?
The Call to Arms is a new multi-forum event designed to celebrate the coming of Warhammer 40,000's new, 10th Edition, and encourage us all to start a new army, or bring our current armies into the new edition.
The Forums of the B&C are divided up into three Strongholds;
The Imperium Stronghold
The Chaos Stronghold
The Xenos Stronghold
These three Strongholds will act as the hub for each of the three main Factions, and will for the 3 Month duration of the Call to Arms, run independently of the two other Strongholds. Each Stronghold may have different targets and goals, and even their own mini/complementary events, all with unique badges and achievements, but at the end of the 3 months, the three Strongholds will face off, and overall winners will be declared.
Start Date: 1 July 2023
End Date: 30 September 2023
So, how is it all going to work?
  1. As each of the Strongholds are acting (initially) as their own Events, you may choose to focus within a single Stronghold, or participate in all three Strongholds, and any complementary/mini-events that you would like to. Your Vows will be treated independently in each Stronghold, meaning a Failed Vow in one Stronghold will NOT effect Vows in the other Strongholds.
  2. Models pledged to a Stronghold must come from the army books associated with those Forums covered by each Stronghold. The exceptions to this are Titans and models from the Other Games Forum (Aeronautica, Titanicus, Necromunda etc), these models / units may be pledged to any Stronghold.
  3. You may join in any of the Events at any time within the 3 Month time-frame of The Call to Arms
  4. For each Stronghold, you have a MAXIMUM of 3 Vows, you must finish your active vow before pledging to a second or third vow.
  5. Once recorded, Vows may not be altered, however special considerations may be made upon request.
  6. There is no minimum pledge, you may vow 1 model, or your entire collection, but beware, failing your last active vow will invalidate any completed vows you may have already submitted.
  7. In addition to the three Vows, any model in the 10pt Category or higher will fit into the "Job's a Big'un" Vow, and will run separate from the 3 Vow limit and have the entirety of the 3 months to be completed.
How do I join in?
Each model has a point value based upon it's size, and the comparative amount of effort and time it takes to paint said model, listed below are are the points-per-model, more specific lists can be found in each Forums Rally Point thread, but I've added some generic examples below,
1pt   Infantry
2pts   Cavalry/Bikers/Heavy Weapons Teams
3pts   Walkers (Dreadnaughts, Sentinals)
4pts   Skimmers / Light Vehicles (Landspeeders, ATV, Armigers)
5pts   Small Tanks (Leman Russ, Rhino Variants)
6pts   Large Tanks (Rogal Dorn, Sicaran, Land Raider)
8pts   Superheavies (Baneblades etc)
10pts  Imperial Knight etc
5pts   Leader and Unit Composition: 1 OR Epic Hero
10pts Primarchs
NOTE: Characters with Retinue, I.E. Saint Celestine. Celestine is the EPIC HERO, and is worth 5pts, her two Sister Superiors are Seraphim, which are worth 1pt each.
20pts Warhound Titan
30pts Reaver Titan
40pts  Warbringer Titan
50pts Warlord Titan
Terrain
1pt    3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges
2pts   Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade
3pts   Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks
4pts   Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls
5pts   Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier
6pts   Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent
8pts   Fronteris Hab Bunker, Manufactorum Administratus,
10pts Zone Morialtis Gang Stronghold
Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing.
You may vow ANY MODEL that is covered by THIS STRONGHOLD, but you must allocate your points to only one FORUM.
Please make your vows in this thread in the following format;
"I, {insert username}, heed the Call to Arms and pledge to paint {insert units/models} for {xxx pts} for the Glory of {insert Forum} and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end."
example;
I, Grotsmasha, heed the Call to Arms and pledge to paint 20 Battle Sisters, 3 Outriders, 1 Lieutenant, and 1 Redemptor Dreadnought for 34pts for the Glory of the Adeptus Astartes and the Imperium Stronghold on or before September 30th, or bear the badge of failure until year's end."
The post that contains your Vow must include starting pictures that contain all the models from the Vow.
Starting models may be in any of the following conditions;
  • In the box
  • On the Sprue
  • Assembled
  • Single Colour Primed
  • For Tanks / Titans, Sub-assemblies primed in different colours will be acceptable, I.E. chassis in Leadbelcher, with armour plates in secondary colour.
Additionally, you may pledge models you have not yet received I.E. Warhammer: Imperium Subscription, just make sure a image is edited in to your Vow post once you've received the models, and make a post indicating that you have done so.
Your Vow is considered complete when you declare it so, and post completed pictures of all models contained within the Vow. Although "Complete" is to your own standard, we would like you to aim for GW's "Battle Ready", with the miniatures based. If basing is something you don't do, or won't be doing within the Event's timeline, please return the bases to flat black or brown as this will greatly enhance the Completed presentation.
Required Completion Pictures: Please include 1 image with a complete shot of the entire Vow, I also encourage everyone to include additional images for each squad/unit in the vow, please post these within Spoiler / Hidden tags.
Once you have made your vow, pop this badge of Participation into your Signature,
Will there be any awards?
Yes!!  There will be Badges and Achievements within the Imperium Stronghold,
Event Failed: Servitor
10 points:  Veteran
25 points  Sergeant
45 points:  Lieutenant
75 points:  Master
100+ points:  Regent of the Imperium
Artificer - Top 1, 2, or 3 best painted models from each Forum, chosen by the Moderators.
Princeps - Awarded to all completed Titans
Imperium Champion - Awarded to the Frater who individually paints the most points worth of models in the Imperium Stronghold
Champions of the Horde - The Imperium Forum with the highest overall points worth of models
Champion of the Call - The Imperium Forum that has the Highest Participation vs. Completion Percentage.
As to the overall competition between the Strongholds, there will also be Badges awarded for the following;
Masters of the Horde - The Stronghold that completes the highest overall points worth of models.
Masters of the Call - The Stronghold that has the Highest Participation vs. Completion Percentage.
Master Artificer - Voted best painted Model, chosen from the 3 Stronghold Artificers.
In addition to the Badges and Achievements above, Triszin has provided / organised some Sponsored Physical Prizes, which will awarded in the following categories;
Favourite Young Blood - This category is for Participants who have been building and/or painting models for less than 12 months. Anyone wishing to participate as A Young Blood will need to specifically declare that are are doing so within their Vows. At the conclusion of the Event all Young Blood Entries will be placed into a Poll for the B&C at large to vote on and pick a Favourite. The voting criteria for this category is not about picking the best painted model, but the model that inexplicably pulls a smile on your face, one that makes you think, damn that's cool..
1 Combat Patrol Box (1 Prize across all three Strongholds)
Master of the Forge - Best Conversion or Kit-bash. Anyone wishing to participate for the Master of the Forge Badge and Prize will need to specifically declare that they are doing so within their Vows.
1 Leviathan Starter Box (1 Prize across all three Strongholds)
Stronghold Artificer - Best Painted Model
1 Character Model Blister/Clam (1 Prize per Stronghold, chosen by Frater Poll)
Grand Marshal - Individual with the Most Points of Models Painted across all Strongholds
1 Character Model Blister/Clam (1 Prize across all three Strongholds)
That's it, you've done it, you've made it to the end!!!
If you have any questions or queries, just @Grotsmasha or @Triszin and we'll be more than happy to help you out, now, go on, get, don't you have models to be painting?
F.A.Q.s
Q- If I have models with different coloured heads or shoulder pads, can they be primed different colours IE. Black templars or Eldar Guardians?
A- Yes, this is acceptable.
Q- I want to paint Traitor Guard, is there a way to pledge them to Chaos?
A- Yes, for the purposes of Traitor Guard, the Astra Militarum units may be pledged to Chaos. The Realm of Chaos is the most appropriate forum.
Q- Are 3D prints allowed?
A- Yes, as long as they are board appropriate, 3D prints can be pledged to the Call to Arms. Use the points associated with the unit they represent.
Edited by Grotsmasha
https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/
PARTICIPANTS
Adepta Sororitas  - Pledged: 131pts / Complete:  22pts / Secured: 22/131pts (16%)
Participants: 3
FelipeFlops - Vow 1: 22pts - Complete  |
Spoiler
Trajan Valoris (5)
5 Custodian Wardens (5)
6 Paragon Warsuits (12)
Mard - Vow 1: 79pts - Not Completed  |
Spoiler
:9x Battle Sisters - 9pts
:1x Canoness - 5pts
:5x Seraphim - 5pts
:5x Repentia - 5pts
:1x Repentia Superior - 1pts
:3x Arco Flagellant - 3pts
:1x Rhino - 5pts
:1x Penitent Engine - 3pts
In Addition
4x Battle Sisters - 4pts
1x Cannoness - 5pts
1x Palantine - 5pts
1x Missionary - 5pts
1x Dialogus - 5pts
4x Death Cult Assassins - 4pts
1x Vindicare Assassin - 5pts
1x Culexus Assassin - 5pts
1x Callidus Assassin - 5pts
ThePenitentOne - Vow 1: 30pts - Not Completed  |
Spoiler
1 Canoness (5pts)
1 Palantine (5pts)
10 Battle Sisters (10 pts)
10 Dominions (10 pts)
Adeptus Astartes - Pledged: 964pts / Complete:  582pts / Secured: 572/964pts (59%)
Participants: 32
Bouargh _ Vow 1: 20pts - Complete  |  Vow 2: 38pts - Complete   |  Vow3: 39pts - Complete  |
Spoiler
4 Rhinos (20)
Spoiler
- 10 Kit bashed Scions (10)
- 3 Rhinos Chassis tanks (15)
- 1 LR Executioner (6)
- Some Scrap piles from Bitz box (7)
Spoiler
- Cawl (10)
- 2 Kastellns (6)
- 1 Datasmith (5)
- 10 Skitarii (10)
- 2 Pieces of scenery/small scrap type (4)
-1 Piece of Scenery/Munitorum Container type (4)
Brother Captain Arkley - Vow 1: 5pts - Complete  |  Vow 2: 5pts - Complete  |  Vow 3: 5pts - Not Complete  |
Spoiler
5 Terminators (5)
Spoiler
Terminator Librarian (5)
Spoiler
5 Intercessors (5)
Brother Christopher - Vow 1: 10pts - Complete  |  Vow 2: 6pts - Completed  |
Spoiler
1 Terminator Castelan (5)
1 Terminator Ancient (5)
Spoiler
Master of the Forge: 1 LR Executioner (6)
Castlerock - Vow 1: 33pts - Not Completed  |
Spoiler
Captain in Terminator Armour (5)
Librarian in Terminator Armour (5)
5 Terminators (5)
5 Sternguard (5)
10 Infernus Marines (10)
1iBallustus Dreadnought (3)
Cleon - Vow 1: 30pts - Complete - Complete   |  Vow 2: 30pts - Complete  |  Vow 3: 28pts - Complete
Spoiler
Phoebus Lt, 5pts
Five Sternguard, 5pts
Five Infernus Marines, 5pts
Four Zone Mortalis Columns, 4pts
Two Zone Mortalis 'double' walls, 4pts
Seven Zone Mortalis 'single' walls 7pts
Spoiler
Terminator Captain (5)
Five Terminators and a Teleport homer, (6)
Five Infernus Marines (5)
Three Zone Mortalis narrow doors (3)
Three Zone Mortalis Double doors (6)
Spoiler
Lord Commander Dante, (5)
Inquisitor Cartavolnus, (5)
Apothecary Biologus, (5)
Company Champion, (5)
Five Heavy Intercessors, (5)
Ballistus Dreadnought, (3)
Daimyo-Phaeron Lenoch - Vow 1: 29pts - Complete  |
Spoiler
4 Chaplains (20)
1 Grey Knight (1)
5 Guardsmen (5)
1 HWT (2)
1 Enforcer (1)
DemonGSides - Vow 1: 41pts - Complete  |
Spoiler
6 Bladeguard Veterans - 6 Points
2 Primaris LT's - 10 pts
2 Primaris Captains - 10 pts
1 Judiciar - 5 pts
1 Bladeguard Ancient - 5 pts
1 Primaris Chaplain - 5 pts
Disruptor_fe404 - Vow 1: 10pts - Not Completed  |
Spoiler
- 5 Infiltrators
- 5 Intercessors
DrGlove - Vow 1: 11pts - Complete  |
Spoiler
Black Templars Marshal (5pts)
3 Bladeguard Veterans (3pts)
1 Land Speeder (3pts)
firestorm40k - Vow 1: 5pts - Complete  |
Spoiler
5 Assault Intercessors
Forté - Vow 1: 26pts - Complete  |
Spoiler
- 1 Captain in Terminator Armour,
- 1 Librarian in Terminator Armour,
- 5 Terminators,
- 1 Teleport Homer
- 10 Infernus Marines
Galron - Vow 1: 42pts - Complete  |
Spoiler
9x terminators, (9)
5x Cenobium Knights, (5)
9 Infernus, (9)
10 Sternguard, (10)
5 Desolators (5)
1 Terminator Chaplain (5)
Gederas - Vow 1: 45pts - Complete  |
Spoiler
Apothecary Biologus (5)
Lieutenant (5)
10Sternguard (10)
10 Terminators (10)
2 Teleport homers (2)
Dreadnought (3)
Vindicare Assassin (5)
Grotsmasha - Vow 1: 25pts - Complete  |
Spoiler
1 Dark Angel Captain (5pts)
1 Canoness (5pts)
10 Battle Sisters (10pts)
1 Exorcist (5pts)
Halandaar - Vow 1: 136pts - Not Completed  |
Spoiler
Leviathan Captain in Terminator Armour (5pts)
Leviathan Librarian in Terminator Armour (5pts)
Leviathan Apothecary Biologis (5pts)
Leviathan Lieutenant with Combi-Weapon (5pts)
Leviathan 5-Man Terminator Squad with Teleport Homer (6pts)
Leviathan 5-Man Sternguard Veteran Squad (5pts)
Leviathan 10-Man Infernus Squad (10pts)
Leviathan Ballistus Dreadnought (3pts)
Agastus Primaris Lieutenant with Power Fist (5pts)
Agastus Primaris Lieutenant with Bolt Rifle (5pts)
Agastus 5-Man Desolation Squad (5pts)
Indomitus Primaris Captain with Relic Shield (5pts)
Indomitus Bladeguard Ancient (5pts)
Indomitus Primaris Chaplain (5pts)
Indomitus Judiciar (5pts)
Indomitus Primaris Lieutenant with Storm Shield (5pts)
Indomitus 3-Man Bladeguard Veteran Squad (3pts)
Supreme Grand Master Azrael (5pts)
Primaris "Bladeguard" Apothecary (5pts)
Primaris "Bladeguard" Librarian (5pts)
5-Man Devastator Squad with Plasma Cannons (5pts)
2x Invader ATVs (6pts)
Redemptor Dreadnought (3pts)
Agastus Brutalis Dreadnought (3pts) <--- I'm putting this one forward for the "Master of the Forge" comp because why not!
Iron Father Ferrum - Vow 1: 11pts - Not Completed  |
Spoiler
1 Apothecary Biologis (5)
1 Landraider (6)
jkoczan42 - Vow 1: 28pts - Not Completed  |
Spoiler
1 Leviathan siege dread
2 bolter support squad
3 despoilers
1 TDA Librarian
1 TDA Captain
5 infernus
5 Terminators
Jolemai - Vow 1: 25pts - Completed - Complete  |
Spoiler
5 Terminators (5pts)
Jobs a Big'un - 1 Thunderhawk (20pts)
Karhedron - Vow 1: 15pts - Complete  |
Spoiler
10 Sternguard
5 Vanguard with Jump Packs
Large and Moving Torb - Vow 1: 30pts - Not Completed  |
Spoiler
10 Assault Marines (10pts),
10 Deathwing Terminators (10pts),
1 Razorback (5pts),
1 Chaplain (5pts)
Mad Greek - Vow 1: 6pts - Not Completed  |
Spoiler
- 1 Redemptor 3pts
- 1 Ballistus 3pts
Majkhel - Vow 1: 21pts - Not Completed  |
Spoiler
- 1 TDA Captain,
- 1 TDA Librarian,
- 5 Archangels Terminators
- 1 Repulsor tank
Mandragola - Vow 1: 25pts - Not Completed  |
Spoiler
5 heavy intercessors (5)
1 Aggressor (1)
5 Desolators (5)
1 stormspeeder thunderstrike (4)
1 Pedro Kantor (5)
Paladin777 - Vow 1: 34pts - Complete  |
Spoiler
- 5 Heavy Intercessors,
- 1 terminator captain,
- 1 terminator librarian,
- 1 Sanguinary Priest,
- 1 Ironclad Dreadnought
Rhavien - Vow 1: 5pts - Complete  |  Vow 2: 10pts - Complete  |
Spoiler
1 Baal Predator
Spoiler
2 Gladius (10)
Raychu - Vow 1: 3pts - Complete  |
Spoiler
1x Leviathan Dreadnought (3)
Tankus Wokus - Vow 1: 10pts - Complete  |
Spoiler
Jobs a Big'Un - 1 Knight Valiant (10)
TheArtilleryman - Vow 1: 22pts - Complete  |
Spoiler
- 4 Vanguard Veterans,
- 10 Infiltrators,
- 3 Eliminators,
- 1 Phobos Lieutenant
TheBloodSpitter - Vow 1: 10pts - Complete  |
Spoiler
- 5 Crimson Fist Terminators
- 1 Terminator Captain
Time_of_flight - Vow 1: 23pts - Complete  |
Spoiler
- 5 Sternguard,
- 5 Terminators,
- 1 Apothecary Biologis,
- 1 Lieutenant,
- 1 Ballistus Dreadnought
WAR - Vow 1: 58pts - Not Completed  |
Spoiler
2x5 man Grey Knights Paladin squads (10pts),
2x6 man Terminator squads (12pts),
1 Terminator for previous squad (1 pt) ,
2 Apothecaries (10 pts),
Librarian (5 pts),
2 Ancients (10 pts)
1 Mystic (5pts)
1 Acolyte (5pts)
Warden-Paints - Vow 1: 9pts - Not Completed
Spoiler
1 Teleport Homer (1pt)
1 Ballistus Dreadnaught (3pts)
Adeptus Mechanicus - Pledged:  32pts / Complete: 32pts / Secured: 32/32pts (100%)
Participants: 2
Brother Carpenter - Vow 1: 10pts - Complete  |
Spoiler
10 Skitarii (10)
ShortCircuit - Vow 1: 22pts - Complete  |
Spoiler
1 Tech-Priest, 5pts
1 Skitarri Ranger, 1pt
5 Electro-Priests, 5pts
1 Skorpius Disintegrator, 5pts
3 Serberys Sulphurhounds, 6pts
Astra Militarum - Pledged: 282pts / Complete: 224pts / Secured: 224/282pts (79%)
Participants: 4
JayJapanB - Vow 1: 48pts - Not Completed
Spoiler
3 Medusa Carriages 15pts
15 Heavy Artillery Crew 15pts
18 Field Gun Crew  18pts
Mike Zulu - Vow: 10pts - Complete  |
Spoiler
10 Guardsmen (10)
our_baz - Vow 1: 10pts - Not Completed  |
Spoiler
1 Castellan (5pts)
5 Rough Riders (5pts)
Sgtsharp - Vow 1: 98pts - Complete |  Vow 2: 116pts - Complete  |
Spoiler
- 20 cadian shock troop (20pts)
- 40 Death Korps of Krieg Korpsmen (40pts)
- Gaunts ghosts   (10pts? 5 for gaunt and 5 for the other ghosts)
- Cadian Comand Squad (5pst)
- Death Korps of Krieg Quatermaster (5pts?)
- 1 Death Korps of Krieg HQ Command Squad (5pts)
- 2 Primaris Psykers (10pts?)
- 1 Armoured Sentinel (old) (3pts)
- 1 Basalisk (5pts)
Spoiler
10 x Infernus Marines (10pts)
5 x Sternguard Veterans (5pts)
5x Terminators (5pts)
1 x Termi Librarian (5pts)
1x Termi Captain (5pts)
1x Ballistas Dread (3pts)
1 x Leviathan Apothecary Biologis (can't remember its name) (5 pts)
1 Phobos Lt with combi weapon (5pts?)
1 Bjorn Fellhanded (5pts?)
1 SW Ven Dread, (3pts)
20 Longfangs (20pts)
3 Eradicators (3pts)
5 x Kitbashed Agressors (5pts)
1 Kitbashed Agressor Capt. (5pts?)
10 x SW Termis (10pts)
1 x Outrider (2pts)
2 x SW termi Rune Priests (10pts?)
1x Nijal Stormcaller (5pts)
1x Termi Wolfguard battle leader (5pts)
Imperial Knights - Pledged:  191pts / Complete: 162pts / Secured: 162/191pts (84%)
Participants: 2
Lord-Ikka - Vow 1: 162pts - Complete  |
Spoiler
Units
(all worth 1 aside from Outriders/Dread/Penitent)
3-man Aggressor squad
10-man Infiltrator squad
3-man Suppressor squad
3-man Eliminator squad
5-man Terminator squad
5-man Sternguard Veterans squad
10-man Infernus Squad
2 Victrix Guard*
1 Ballistus Dreadnought (3 points)
3-man Outrider squad (6 points)
10-man Sisters of Battle
22 Sisters Repentia + 1 Repentia Superior
5 Seraphim
1 Penitent Engine (3 points)
Characters
(worth 5 each)
1 Chapter Master in Gravis Armour (Marneus Calgar)*
1 Chaplain in Terminator Armor*
1 Librarian in Terminator Armor
1 Primaris Librarian*
1 Lieutenant with Combi-Weapon
1 Lieutenant in Phobos Armor
1 Primaris Ancient*
1 Canoness
1 Dialogus
1 Hostpitaller
1 Imagifier
1 Dogmata
Terrain (maybe, don't know if this counts Grot...?)
1 Teleport Homer (1 point?)
Spazmolytic - Vow 1: 29pts - Not Completed  |
Spoiler
1 AT Reaver 5pts
2 AT Arcastus 6pts
6 AT Cerastus 12pts
3 AT Questoris 6pts
Talons of the Emperor - Pledged: 000pts / Complete: 000pts / Secured: 000pts
Participants: 0
The Imperium of Mankind - Pledged: 134pts / Complete:  134pts / Secured: 134/134pts (100%)
Participants: 3
Brother Argent -Vow 1: 84pts - Complete  |
Spoiler
- Terminator Captain x1 (5pts)
- Terminator Librarian x1 (5pts)
- Phobos Lt x1 (5pts)
- Apothecary Biologus x1 (5pts)
- Terminators x5 (5pts)
- Teleport Homer x1 (1pts)
- Sternguard Veterans x5 (5pts)
- Infernus Marines x10 (10pts)
- Ballistarus Dreadnought x1 (3pts)
- Kataphron Destroyers x2 (4pts)
- Canoness x1 (5pts)
- Battle Sisters x3 (3pts)
- Seraphim x2 (2pts)
- Sister Repentia x1 (1pts)
- Arcoflagelant x1 (1pts)
- Manufactorum Ruins x2 (8pts)
- Thermic Plasma Conduits x8 (Pipes) + 4x Plasma Cell thingies (16 pts)
Cactus - Vow 1: 20pts - Complete  |
Spoiler
BSF Janus Draik 5pts
BSF Rein and Rauss 10pts
BSF Esperno Locano 5pts
librisrouge - Job's a Big'un: 20pts - Complete  |  Vow 1: 10pts - Complete  |
Spoiler
Jobs a Big'Un - Warhound Titan, Legio Atarus, Persecutor Ignis
Spoiler
5 Rough Riders (10)
Age of Darkness Loyalists - Pledged:  25pts / Complete: 0pts / Secured: 0/25pts (0%)
Participants: 1
ELIMELECH - Vow 1: 25pts - Not Completed  |
Spoiler
- 10 Iron Hands Tactical Marines 10pts
- 5 scouts 5pts
-10 Tech-Thralls 10pts
I, Brother Argent, Master of Procrastinations, Forger of the Iron Gauntlet, Keeper of the Argent Forge, Unofficial Reclusiarch of the Liber (Not that I have been there in a while) and all round nutter, heed the Call to Arms and pledge to paint:
- Teleport Homer x1 (1pts?)
- Manufactorum Ruins x2 (8pts I think)
- Thermic Plasma Conduits x8 (Pipes) + 4x Plasma Cell thingies (16 pts I think...)
for 84 points (I think) for the Glory of The Liber, The Imperium of Man Sub Forum (as I am doing a mixed force and will try to do an Inquisitor in a later vow if I can) and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end.
I don't have photos of all of this at once.  Indeed I only have a few separate photos of the first few bits (kataphron x1, pipes) as the rest are yet to arrive (Leviathan for my birthday in a few days and the next two Imperium deliveries).  I hope that isn't an issue.   If so I can make this into smaller vows.  Let me know and I will start posting pics.
PICS: (So far)
large.Kataphron2Before.jpg.fc06340430bf24ffba3c87b4cc1ca61d.jpg.58391d93668bfeae110328277efae132.jpglarge.ThermicPlasmaConduits1Before.jpg.2d495ba98cc04a59b681d58cf2216c7b.jpg.b14ae74aff8cc61b91412614e71a1638.jpglarge.ThermicPlasmaConduitsConquestBefore.jpg.53484e46e74b1e5f0b979fd2f670e8d8.jpg.a1eb41f10bbcd899ff80beb3b609ccf9.jpg
large.LeviathanMarinesBefore.jpg.d82a3491345668be35f133b2cd17fe51.thumb.jpg.5be9efcfe1b78efc2b73394d8dd0f9ea.jpg
large.Repentia1Before.jpg.43f5b5563837db9073df6f3b33266499.jpg.0723449f59d5bdadebdbb787e4d44f9a.jpglarge.Arcoflagellant1Before.jpg.40c96419c2be87f1f5835ff78a34f298.jpg.269313dd92bc6fbb4fe0f5b5b049d59a.jpglarge.CanonessBefore.jpg.b1e05ed75732e28bc5ef1d9bdd4db479.jpg.eac3d40c716868422814ee4145cecdd4.jpglarge.Kataphron3Before.jpg.9427f149c8390ea50231e2813e8eaa87.jpg.012b2a73e037c078f659f7722f0b9753.jpglarge.Sisters1Before.jpg.c7fb3651d28f85619377ad4c3004d542.jpg.7397a4bc8724980c995d186636b95a5f.jpglarge.Building3Before.jpg.f8378a90054ddd2716cfcdc849e7f773.jpg.e826450c3e013c5d8530450fa8f9defd.jpg
Edited by Brother Argent
I, Disruptor_fe404, architect of the Heliovault and Guardian of Antios, heed the Call to Arms and pledge to paint 5 Infiltrators and 5 Intercessors, for 10 points for the Glory of Adeptus Astartes and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end.
Starting photos to be edited in once I've got everything together!
Fitting that the Anzacs are first to answer the call, I think!
EDIT: Beginning photo:
Edited by Disruptor_fe404
I, Lord_Ikka, heed the Call to Arms and will pledge the following for the glory of the Imperial Knights sub-forum of the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end.-
Units
2 Victrix Guard*
5 Seraphim
Characters
(worth 5 each)
1 Primaris Ancient*
1 Canoness
1 Dialogus
1 Hostpitaller
1 Imagifier
1 Dogmata
* Imperium magazine/other deliveries, will not have units until later
Total- 99 models, 162 points
I will update this post with my vow pictures sometime this week/when I get the * items, as I'm still building the Leviathan/Imperium phobos stuff.
Main pics-
Marines
Sisters of Battle
Edit- Calgar and Victrix Guard
Individual unit pics
Infiltrators
Outriders
Aggressors
Eliminators
Suppressors
Terminators (and teleport homer)
Sternguard Veterans
Infernus Marines (split into two 5-mans)
Ballistus Dread
Terminator Librarian, Apothecary Biologis, Terminator Captain, Lieutenant w/combi-weapon, Lieutenant in Phobos Armour
Primaris Librarian, Primaris Ancient, Chaplain in Terminator Armour
22 Sisters Repentia (and 1 Repentia Superior)
Seraphim
10 man Sisters of Battle
Penitent Engine
Dogmata, Imagifier, Canonness, Hospitaller, Dialogus
Edited by Lord_Ikka
"I, Mard, heed the Call to Arms and pledge to paint the models listed below for {79pts} for the Glory of Adepta Sororitas and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end."
My frist Vow contains the following
Combat Patrol (Minus 1 sister for test paint scheme)
:1x Canoness - 5pts
:5x Seraphim - 5pts
:5x Repentia - 5pts
:1x Rhino - 5pts
In Addition
1x Cannoness - 5pts
1x Palantine - 5pts
1x Dialogus - 5pts
Super keen for the spiritual successor to ETL
I, TheArtilleryman, digger of tunnels, player of cards and visionary of the new beginning, heed the Call to Arms and pledge to paint 4 Vanguard Veterans, 10 Infiltrators, 3 Eliminators and 1 Phobos Lieutenant for 22 points for the Glory of the Adeptus Astartes and the Imperium Stronghold on or before July 31st, or bear the badge of failure until year's end."
(Painted models at the back not included in the pledge)
Edited by TheArtilleryman
"I, Forté, heed the Call to Arms and pledge to paint 1 Captain in Terminator Armour, 1 Librarian in Terminator Armour, 5 Terminators, 1 teleport homer, and 10 Infernus Marines for 26 pts for the Glory of the Adeptus Astartes and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end."
Ignore the Dread...
Edited by Forté
Added 5 Infurnus
I, Majkhel of the Blood Angels, heed the Call to Arms and pledge to paint:
- 1 TDA Captain,
- 1 TDA Librarian,
- 1 Repulsor tank
(for the total of 21pts)
for the glory of the Adeptus Astartes Forum, the Imperium Stronghold, the Great Angel and Him on Terra on or before 30th September 2023, or bear the badge of failure until years end.
I, Paladin777, heed the Call to Arms and pledge to paint 5 Heavy Intercessors, 1 terminator captain, 1 terminator librarian, 1 Sanguinary Priest, and 1 Ironclad Dreadnought for 34pts for the Glory of the Adeptus Astartes and the Imperium Stronghold on or before September 30th, or bear the badge of failure until year's end.
Edited by Paladin777
I, jkoczan42, heed the Call to Arms and pledge to paint
Loyalist IW for HH:
3 despoilers
TBD for 40k (still mulling over paint options):
1 TDA Librarian
1 TDA Captain
5 infernus
5 Terminators
for 28 points for the Glory of the Adeptus Astares and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end.
Edited by jkoczan42
I, Sgtsharp, heed the Call to Arms and pledge to paint:
1 Basalisk (5pts)
for 98 pts for the Glory of  the Guard and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end.
Edited by SgtSharp
I’ll join this with my Crimson Fists. I made a start on some models today so we’ll see how far I get, and whether I’ll add other stuff.
I pledge:
1 Aggressor (1) - because I only ever painted 5/) of them when I first got them!
5 Desolators (5)
A stormspeeder thunderstrike (4)
An Apothecary Biologis (5)
A converted Pedro Kantor (5)
That seems to add up to 25 points, happily. I may add other stuff as I’ve recenty built several other character options for my Crimson Fists. We’ll see.
Edit, I failed an intelligence check there, but now there’s enough stuff for 25 points.
Edited by Mandragola
I, ThePenitentOne pledge to complete the following models by Sept 30 for the honour of the Adepta Sororitas:
A Canoness leading 10 BSS (11 Points)
A Palatine leading 10 Doms (11 Points)
30 points
Edited by ThePenitentOne
Well, I figure three pledges is three months of hobby July, August and September, so lets see if I can get back on track.
"I, Cleon, heed the Call to Arms and pledge to paint a Phoebos Lt, 5 Sternguard, 5 infernus marines and 13 pieces of Zone Mortalis terrain for 30 pts for the Glory of The Blood angels and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end."
If I've understood the points correctly, that breaks down as:
  • Phoebus Lt, 5 points as a single model leader
  • Five Sternguard, 5 points as 1 ppm infantry
  • Four Zone Mortalis Columns, 4 points at 1 each
  • Two Zone Mortalis 'double' walls, 4 points at 2 each
  • Seven Zone Mortalis 'single' walls - I don't know if these count as Columns or walls, so I'm assuming Columns at 1 each for 7.
Please ignore the traitors lurking on the edge of the pictures.... (and shame the annoying sternguard who had slipped off the box they were sitting on and didn't get undercoated...)
WIPJulmarines.thumb.jpg.c944667d57477eeba8b97068c2c67756.jpgWIPJulwalls.thumb.jpg.835ae0f9d6f40fa0bf04e293188ffd2e.jpg
I, librisrouge, heed the Call to Arms and pledge to paint a Warhound Titan of the Legio Atarus, known as the Persecutor Ignis for 20 pts for the Glory of The Imperium of Man and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end."
I, TheBloodSpitter, heed the Call to Arms and pledge to paint 5 Crimson Fist Terminators and a Terminator Captain for 10 for the Glory of Imperial Fists and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end.
I, Spazzmolytic, heed the Call to Arms and pledge to paint 11 stompy robots for XXX points for the Glory of  and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end!
Now I won't be using that armour plate as it was done before this started, will swap out. But previously I asked about points and was stated "base size is my friend" at 105mm I'm not sure what this would count as...possibly a Armiger????
Guessing these lads would be counted as Dreadnaughts??? 60mm base
I may have placed a couple of these guys on wrong bases, is that going to be a problem? Guessing these will count as cavalry 50mm base
And these guys just infantry ? 40mm base
If I assumed correctly that would make it 25 points
I, HALANDAAR, heed the Call to Arms and pledge to paint the following models for a total of 138 POINTS for the Glory of the ADEPTUS ASTARTES and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. IN NOMINE EIUS!
  • Leviathan Captain in Terminator Armour (5pts)
  • Leviathan Librarian in Terminator Armour (5pts)
  • Leviathan Apothecary Biologis (5pts)
  • Leviathan Lieutenant with Combi-Weapon (5pts)
  • Leviathan 5-Man Terminator Squad with Teleport Homer (6pts)
  • Leviathan 5-Man Sternguard Veteran Squad (5pts)
  • Leviathan 10-Man Infernus Squad (10pts)
  • Leviathan Ballistus Dreadnought (3pts)
  • Agastus Primaris Lieutenant with Power Fist (5pts)
  • Agastus Primaris Lieutenant with Bolt Rifle (5pts)
  • Agastus 5-Man Desolation Squad (5pts)
  • Agastus Brutalis Dreadnought (3pts) <--- I'm putting this one forward for the "Master of the Forge" comp because why not!
  • Indomitus Primaris Captain with Relic Shield (5pts)
  • Indomitus Bladeguard Ancient (5pts)
  • Indomitus Primaris Chaplain (5pts)
  • Indomitus Judiciar (5pts)
  • Indomitus Primaris Lieutenant with Storm Shield (5pts)
  • Indomitus 3-Man Bladeguard Veteran Squad (3pts)
  • Supreme Grand Master Azrael (5pts)
  • Primaris "Bladeguard" Apothecary (5pts)
  • Primaris "Bladeguard" Librarian (5pts)
  • 3-Man Bladeguard Veteran Squad (3pts)
  • 5-Man Devastator Squad with Plasma Cannons (5pts)
  • 2x Invader ATVs (8pts?)
  • Redemptor Dreadnought (3pts)
The Brutalis kitbash/conversion below; uses some 3d printed parts, the faceplate of a Death Company dreadnought, Guilliman's tactical rock and some chains, and I hacked up the  Stubbers to turn them into Heavy Bolters because it looks way cooler
Edited by Halandaar
I, firestorm40k, heed the Call to Arms and pledge to paint 5 Assault Intercessors for 5 points for the Glory of the Adeptus Astartes forum and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end.
(I'm batch painting 15 of these, if I can finish more than these 5 I'll expand my vow - otherwise I think this is a realistic target to start with! :biggrin:)
Edited by firestorm40k
Pressed the Post button prematurely..!
Register a new account
Sign in
