Lork Posted July 3, 2023 Share Posted July 3, 2023 "I, DrGlove, heed the Call to Arms and pledge to paint a Black Templars Marshal, 3 Bladeguard Veterans and a Land Speeder for 11 pts for the Glory of the Adeptus Astartes and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end." Rusted Boltgun, Elimelech, Halandaar and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968034 Share on other sites More sharing options...
MadGreek Posted July 3, 2023 Share Posted July 3, 2023 I, Mad Greek, heed the Call to Arms and pledge to paint 1 Redemptor and 1 Ballistus Redepmtor Dread for 6 pts for the Glory of the Adeptus Astartes and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Lork, Grotsmasha, Brother Lunkhead and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968078 Share on other sites More sharing options...
Grotsmasha Posted July 4, 2023 Author Share Posted July 4, 2023 12 hours ago, Spazmolytic said: I, Spazzmolytic, heed the Call to Arms and pledge to paint 11 stompy robots for XXX points for the Glory of and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end! Now I won't be using that armour plate as it was done before this started, will swap out. But previously I asked about points and was stated "base size is my friend" at 105mm I'm not sure what this would count as...possibly a Armiger???? Guessing these lads would be counted as Dreadnaughts??? 60mm base I may have placed a couple of these guys on wrong bases, is that going to be a problem? Guessing these will count as cavalry 50mm base And these guys just infantry ? 40mm base If I assumed correctly that would make it 25 points Sorry for the delayed response, I have these models at home and will do a comparison and get back to you ASAP with points 12 hours ago, Spazmolytic said: I, Spazzmolytic, heed the Call to Arms and pledge to paint 11 stompy robots for XXX points for the Glory of and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end! Now I won't be using that armour plate as it was done before this started, will swap out. But previously I asked about points and was stated "base size is my friend" at 105mm I'm not sure what this would count as...possibly a Armiger???? Guessing these lads would be counted as Dreadnaughts??? 60mm base I may have placed a couple of these guys on wrong bases, is that going to be a problem? Guessing these will count as cavalry 50mm base And these guys just infantry ? 40mm base If I assumed correctly that would make it 25 points Sorry for the delayed response, I have these models at home and will do a comparison and get back to you ASAP with points Lork 1 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968178 Share on other sites More sharing options...
Elimelech Posted July 4, 2023 Share Posted July 4, 2023 I, ELIMELECH, heed the Call to Arms and pledge to paint 10 Iron Hands Tactical Marines, 5 scouts, and 10 Tech-Thralls for 25 pts for the Glory of the Loyalists fighting in this Age of Darkness and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Additionally, I would consider it a betrayal of my oaths to Lord Manus not to put myself forward for consideration as Master of the Forge, as humble as my efforts may be (in light of the fact that almost all the models will be converted in some way, I hope). TheHyperion, Halandaar, Firedrake Cordova and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968296 Share on other sites More sharing options...
time_of_flight Posted July 4, 2023 Share Posted July 4, 2023 I, Time_of_flight, heed the Call to Arms and pledge to paint 5 Sternguard, 5 Terminators, 1 Apothecary Biologis, 1 Lieutenant, and 1 Ballistus Dreadnought for 23 pts for the Glory of The Adeptus Astartes and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Spazmolytic, Grotsmasha, Forté and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968309 Share on other sites More sharing options...
Rhavien Posted July 4, 2023 Share Posted July 4, 2023 I, Rhavien, heed the Call to Arms and pledge to paint one Baal Predator for 5 pts for the Glory of Adeptus Astartes and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Let's get this started already . I will start cautiously with only a single model. But there are several in the pipeline I plan to finish. Spazmolytic, Grotsmasha, Elimelech and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968343 Share on other sites More sharing options...
Orion Posted July 4, 2023 Share Posted July 4, 2023 I, JayJapanB, heed the Call to Arms and pledge to paint: 3 Medusa Carriages 15pt 15 Heavy Artillery Crew 15pt 18 Field Gun Crew 18pt 48pts? Do the crews count like that? I'm new and I don't know what I'm doing. Otherwise I can minus 15pts. The Thudds and Heavy Mortars are already done. Either way, hopefully should make some good progress Elimelech, Rhavien, Grotsmasha and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968390 Share on other sites More sharing options...
jkoczan42 Posted July 4, 2023 Share Posted July 4, 2023 It begins! Brother Lunkhead and Rhavien 2 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968507 Share on other sites More sharing options...
Lord_Ikka Posted July 5, 2023 Share Posted July 5, 2023 Updated my initial post with pics and two Sisters characters I forgot to include. Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968579 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2023 Author Share Posted July 5, 2023 On 7/2/2023 at 2:05 PM, ThePenitentOne said: I, ThePenitentOne pledge to complete the following models by Sept 30 for the honour of the Adepta Sororitas: A Canoness leading 10 BSS (11 Points) A Palatine leading 10 Doms (11 Points) 22 points Good news, the Canoness and Palantine are both worth 5pts each, and I've recorded the Vow as 30pts Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968589 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2023 Author Share Posted July 5, 2023 (edited) On 7/3/2023 at 10:22 PM, Spazmolytic said: I, Spazzmolytic, heed the Call to Arms and pledge to paint 11 stompy robots for XXX points for the Glory of and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end! Now I won't be using that armour plate as it was done before this started, will swap out. But previously I asked about points and was stated "base size is my friend" at 105mm I'm not sure what this would count as...possibly a Armiger???? Guessing these lads would be counted as Dreadnaughts??? 60mm base I may have placed a couple of these guys on wrong bases, is that going to be a problem? Guessing these will count as cavalry 50mm base And these guys just infantry ? 40mm base If I assumed correctly that would make it 25 points Ok, so, Questoris 2pts each Cerastus 2pts each Arcastus 3pt each Warhound 4pt each Reaver 5pt each Warlord 7pts each Worth a little more than their size due to excessive detail Edited July 5, 2023 by Grotsmasha Spazmolytic 1 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968593 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2023 Author Share Posted July 5, 2023 On 7/3/2023 at 11:58 PM, Halandaar said: I, HALANDAAR, heed the Call to Arms and pledge to paint the following models for a total of 138 POINTS for the Glory of the ADEPTUS ASTARTES and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. IN NOMINE EIUS! Reveal hidden contents Leviathan Captain in Terminator Armour (5pts) Leviathan Librarian in Terminator Armour (5pts) Leviathan Apothecary Biologis (5pts) Leviathan Lieutenant with Combi-Weapon (5pts) Leviathan 5-Man Terminator Squad with Teleport Homer (6pts) Leviathan 5-Man Terminator Squad with Teleport Homer (6pts) Leviathan 5-Man Sternguard Veteran Squad (5pts) Leviathan 5-Man Sternguard Veteran Squad (5pts) Leviathan 10-Man Infernus Squad (10pts) Leviathan Ballistus Dreadnought (3pts) Leviathan Ballistus Dreadnought (3pts) Agastus Primaris Lieutenant with Power Fist (5pts) Agastus Primaris Lieutenant with Bolt Rifle (5pts) Agastus 5-Man Desolation Squad (5pts) Agastus Brutalis Dreadnought (3pts) <--- I'm putting this one forward for the "Master of the Forge" comp because why not! Indomitus Primaris Captain with Relic Shield (5pts) Indomitus Bladeguard Ancient (5pts) Indomitus Primaris Chaplain (5pts) Indomitus Judiciar (5pts) Indomitus Primaris Lieutenant with Storm Shield (5pts) Indomitus 3-Man Bladeguard Veteran Squad (3pts) Supreme Grand Master Azrael (5pts) Primaris "Bladeguard" Apothecary (5pts) Primaris "Bladeguard" Librarian (5pts) 3-Man Bladeguard Veteran Squad (3pts) 5-Man Devastator Squad with Plasma Cannons (5pts) 2x Invader ATVs (8pts?) Redemptor Dreadnought (3pts) The Brutalis kitbash/conversion below; uses some 3d printed parts, the faceplate of a Death Company dreadnought, Guilliman's tactical rock and some chains, and I hacked up the Stubbers to turn them into Heavy Bolters because it looks way cooler ATV's are @ 3pts each, I have the Vow at 136pts Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968597 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2023 Author Share Posted July 5, 2023 * UPDATED TO THIS POINT * Forté 1 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968608 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2023 Author Share Posted July 5, 2023 I, Grotsmasha, heed the Call to Arms and pledge to paint 10 Battle Sisters, 1 Canoness, 1 Exorcist, 1 Captain, for 25pts for the Glory of the Adeptus Astartes and the Imperium Stronghold on or before September 30th, or bear the badge of failure until year's end." Brother Lunkhead, Elimelech, Rhavien and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968676 Share on other sites More sharing options...
Spazmolytic Posted July 5, 2023 Share Posted July 5, 2023 7 hours ago, Grotsmasha said: Ok, so, Questoris 2pts each Cerastus 2pts each Arcastus 3pt each Warhound 4pt each Reaver 5pt each Warlord 7pts each Worth a little more than their size due to excessive detail Thank you. On my vow you have one Arcastus, it's 2 actually . Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968681 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2023 Author Share Posted July 5, 2023 31 minutes ago, Spazmolytic said: Thank you. On my vow you have one Arcastus, it's 2 actually . I'll correct Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968689 Share on other sites More sharing options...
Cactus Posted July 5, 2023 Share Posted July 5, 2023 I, Cactus, heed the Call to Arms and pledge to paint Janus Draik, Espern Locarno, Rein and Raus for 20 points for the Glory of The Imperium of Mankind and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Elimelech, Grotsmasha, Spazmolytic and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5968707 Share on other sites More sharing options...
Warden-Paints Posted July 6, 2023 Share Posted July 6, 2023 A few days late to the party, but here nonetheless! I, WardenPaints, heed the Call to Arms and pledge to paint one unit of Space Marine Terminators and one Ballistus Dreadnought} for 8 points for the Glory of The Black Templars and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Forté, Brother Lunkhead, Grotsmasha and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5969247 Share on other sites More sharing options...
Grotsmasha Posted July 6, 2023 Author Share Posted July 6, 2023 58 minutes ago, Warden-Paints said: A few days late to the party, but here nonetheless! I, WardenPaints, heed the Call to Arms and pledge to paint one unit of Space Marine Terminators and one Ballistus Dreadnought} for 8 points for the Glory of The Black Templars and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. The Teleport Homer is worth 1pt too Warden-Paints and Forté 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5969268 Share on other sites More sharing options...
Forté Posted July 6, 2023 Share Posted July 6, 2023 3 hours ago, Grotsmasha said: The Teleport Homer is worth 1pt too Add one to mine too please Grotsmasha 1 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5969351 Share on other sites More sharing options...
Gederas Posted July 8, 2023 Share Posted July 8, 2023 Well, I'll throw my hat into this ring once I've gotten the 3D printed bases I need to actually vow the minis Grotsmasha 1 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5969895 Share on other sites More sharing options...
ShortCircuit Posted July 8, 2023 Share Posted July 8, 2023 I, ShortCircuit, heed the Call to Arms and pledge to paint 1 Skorpius Disintegrator, 1 Tech-Priest, 1 skitarri ranger, 5 electro-priests, and 3 Serberys Sulphurhounds for 22 points for the Glory of The Adeptus Mechanicus and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Brother Lunkhead, Grotsmasha and Spazmolytic 3 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5969926 Share on other sites More sharing options...
DemonGSides Posted July 8, 2023 Share Posted July 8, 2023 (edited) I, DemonGSides, do heed the call and pledge this mess of bladeguard and bladeguard adjacent power armored bodies. Specifically; 6 Bladeguard Veterans - 6 Points 2 Primaris LT's - 10 pts 2 Primaris Captains - 10 pts 1 Judiciar - 5 pts 1 Bladeguard Ancient - 5 pts 1 Primaris Chaplain - 5 pts 13 models total, 41 pts total? Seems high, someone double check me. For the Glory of The Blood Angels and the Imperium Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Hopefully sooner! Edited July 9, 2023 by DemonGSides Grotsmasha, Brother Lunkhead, Spazmolytic and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5969999 Share on other sites More sharing options...
Cactus Posted July 9, 2023 Share Posted July 9, 2023 @DemonGSides a bunch of those are characters which I believe are worth 5 each. @Grotsmasha please correct me if I'm wrong because that means I've miscounted my own. Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5970017 Share on other sites More sharing options...
DemonGSides Posted July 9, 2023 Share Posted July 9, 2023 4 hours ago, Cactus said: @DemonGSides a bunch of those are characters which I believe are worth 5 each. @Grotsmasha please correct me if I'm wrong because that means I've miscounted my own. No I think you're right; I didn't read far enough down the points and just stopped at infantry bodies. Will update my post! Link to comment https://bolterandchainsword.com/topic/379215-call-to-arms-imperium-stronghold/page/2/#findComment-5970040 Share on other sites More sharing options...
