Mithrilforge Posted July 2, 2023 Share Posted July 2, 2023 (edited) I, Mumeishi, Racer of Glaciers... heed the Call to Arms and pledge- To Convert & Paint 1x Ork Blitza-Bommer *(Master of the Forge Entry) for the Glory of the Orks forum and the Xenos Stronghold on or before 30th September 2023, or bear the badge of the Snotling (failure) until years end. WiP - Cheers, M. Edited July 2, 2023 by Mumeishi Lord Marshal, TrawlingCleaner, ZeroWolf and 7 others 8 2 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5967771 Share on other sites More sharing options...
Halandaar Posted July 3, 2023 Share Posted July 3, 2023 @Grotsmasha@Triszin - I was typing up my vow and wasn't sure on how a couple of things might score, so I checked a few previous posters to see what they'd come up with and it looks like different people are using different point scores for the same things. Any chance you can clarify how I should attribute points to these models? Ripper Swarms - Is it 1 because it's a single infantry-sized base, or 2 because it's multiple models on the same base like a Heavy Weapons Team? Screamer-Killer - I would have presumed 3 like a Dreadnought, is this correct? Psychophage - Same as above, I'd called it a "walker" at 3 points but others have used 5 for this Cheers! Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5967967 Share on other sites More sharing options...
ZeroWolf Posted July 3, 2023 Share Posted July 3, 2023 7 minutes ago, Halandaar said: @Grotsmasha@Triszin - I was typing up my vow and wasn't sure on how a couple of things might score, so I checked a few previous posters to see what they'd come up with and it looks like different people are using different point scores for the same things. Any chance you can clarify how I should attribute points to these models? Ripper Swarms - Is it 1 because it's a single infantry-sized base, or 2 because it's multiple models on the same base like a Heavy Weapons Team? Screamer-Killer - I would have presumed 3 like a Dreadnought, is this correct? Psychophage - Same as above, I'd called it a "walker" at 3 points but others have used 5 for this Cheers! I took my points from the list in the Call to Arms thread in the Tyranid sub-forum. Rippers are listed as being 2pts there. Both Screamer-Killer and Psychophage are also both listed there as 5s (same as the neurotyrant and little friends). Halandaar and Grotsmasha 2 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5967970 Share on other sites More sharing options...
Halandaar Posted July 3, 2023 Share Posted July 3, 2023 22 minutes ago, ZeroWolf said: I took my points from the list in the Call to Arms thread in the Tyranid sub-forum. Rippers are listed as being 2pts there. Both Screamer-Killer and Psychophage are also both listed there as 5s (same as the neurotyrant and little friends). I completely missed that the forums had dedicated points breakdowns, so thanks for that! I, HALANDAAR, heed the Call to Arms and pledge to paint the following models for a total of 114 POINTS for the Glory of the TYRANIDS and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until years end. CONSUME! Neurotyrant (5pts) 2 Neuroloids (2pts) Winged Tyranid Prime (5pts) 40 Termagants (40pts) 4 Ripper Swarms (8pts) 6 Von Ryan's Leaper (12pts) 22 Neurogaunts (22pts) 10 Barbgaunts (10pts) Screamer-Killer (5pts) Psychophage (5pts) The only conversion I've done in this batch; mild repose on the Prime to get the wings above the arms like the are on the Hive Tyrant: Brother Casman, ZeroWolf, Rusted Boltgun and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5967989 Share on other sites More sharing options...
ZeroWolf Posted July 3, 2023 Share Posted July 3, 2023 4 hours ago, Halandaar said: I completely missed that the forums had dedicated points breakdowns, so thanks for that! I, HALANDAAR, heed the Call to Arms and pledge to paint the following models for a total of 114 POINTS for the Glory of the TYRANIDS and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until years end. CONSUME! Hide contents Neurotyrant (5pts) 2 Neuroloids (2pts) Winged Tyranid Prime (5pts) 40 Termagants (40pts) 4 Ripper Swarms (8pts) 6 Von Ryan's Leaper (12pts) 22 Neurogaunts (22pts) 10 Barbgaunts (10pts) Screamer-Killer (5pts) Psychophage (5pts) The only conversion I've done in this batch; mild repose on the Prime to get the wings above the arms like the are on the Hive Tyrant: No problem and good luck! Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5968080 Share on other sites More sharing options...
Guest Triszin Posted July 3, 2023 Share Posted July 3, 2023 Pip 1: Most of the base colors on Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5968104 Share on other sites More sharing options...
Foremole Posted July 3, 2023 Share Posted July 3, 2023 I, Foremole, heed the call to arms and pledge to paint: 1 Farseer (5pts) 1 Wraithlord (4pts) 6 Windriders (12pts) 3 Dire Avengers (3pts) ...for 24 points for the Glory of of the Craftworlds and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until year's end. ZeroWolf, TrawlingCleaner, Brother Casman and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5968128 Share on other sites More sharing options...
Marius Perdo Posted July 4, 2023 Share Posted July 4, 2023 (edited) I, Marius Perdo, heed the Call to Arms and pledge to paint: - Winged Tyranid Prime x1 (5pts) - Neurotyrant x1 (5pts) - Neurolids x2 (2pts) - Screamer Killer Carnifex x1 (5pts) - Von Ryans Leapers x6 (12pts) - Termagants x40 (40pts) - Ripper Swarms x9 (18pts) - Neurogaunts x22 (22pts) - Barbgaunts x10 (10pts) - Physcophage x1 (5pts) - Forge Word Tyranid Capilliary Tower x3 (?pts) - Forge World Tyranid Brood Nest (?pts) for {124+? pts} for the Glory of the Tyranids and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Edit 1: @Grotsmasha what do the FW terrain pieces counts as points wise? Edit 2: Sunday 09/07/2023 - Phase 1 so far: Edited July 10, 2023 by Marius Perdo Chronicle of updates. ZeroWolf, Brother Casman, Dwango and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5968407 Share on other sites More sharing options...
Azaiel Posted July 4, 2023 Share Posted July 4, 2023 "I, Azaiel, heed the Call to Arms and pledge to paint: 1 Ork warboss (5pts) Also Master of the Forge Vow 1 Big Mek with SAG (5pts) 1 Kustom Boosta blasta (5pts) 1 Big Mek with KFF and 1 assistant (5pts +1) 1 Painboy and 1 assistant (5pts +1) Also Master of the Forge vow 1 Mek Gun (2pts) 5 Gretchin crew for Mek gun (5pts) 1 Bonus Gretchin (1pts) Total: 35pts for the Glory of Gork/Mork and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until years end." The Painboy WIP: And his plucky assistant: And my Bad Moon Warboss with Cybork Squig friend: Mithrilforge, N1SB, andes and 6 others 6 3 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5968467 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2023 Author Share Posted July 5, 2023 * UPDATED TO THIS POINT * Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5968639 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2023 Author Share Posted July 5, 2023 I, Grotsmasha, heed the Call to Arms and pledge to paint 15 Nobz (15), 10 Kommandos (10), 10 Stormboyz (10), 1 Kill Rig (6), 2 Killa Kans (6), Zagstrukk (5), Grukk Face-Rippa and Squig (6), Ghazghull and Makari (11), 1 Chronomancer (5), 1 Shard of the Deceiver (5), 1 Harpy (7), 1 Winged Hive Tyrant (10) for 91pts for the Glory of the Orks and the Xenos Stronghold on or before September 30th, or bear the badge of failure until year's end." Orks Necrons The Deceiver is a commission piece, pictured is one I'd previously started, and as you can see there's some pretty serious model-slip in the print. I've requested a replacement and when that arrives I'll be starting fresh. Tyranids TrawlingCleaner, Mithrilforge, andes and 5 others 7 1 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5968673 Share on other sites More sharing options...
Bouargh Posted July 5, 2023 Share Posted July 5, 2023 "I, Bouargh, heed the Call to Arms and pledge to paint {10 Guardians Defenders 1 Platform; & Farseer; 1 WaveSerpent; 1 Warlock skyrunner and 7 Jetbikes} for 41pts for the Glory of Aeldari and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until years end." Spoiler ZeroWolf, Firedrake Cordova, Trokair and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5968751 Share on other sites More sharing options...
Guest Triszin Posted July 6, 2023 Share Posted July 6, 2023 Pip 2 Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5969093 Share on other sites More sharing options...
Guest Triszin Posted July 6, 2023 Share Posted July 6, 2023 (edited) Vow 1 is done. Only thing left is the black trim on the base, but that's for a later date. And my favorite guy Edited July 6, 2023 by Triszin Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5969407 Share on other sites More sharing options...
Foremole Posted July 10, 2023 Share Posted July 10, 2023 First half of my vow is finished! Six Windriders painted and highlighted. I'm quite pleased with how they turned out, though I might add transfers if my friends who've been in the hobby longer than I am are willing to part with some of the older transfer sheets with Lugganath symbols. (I like freehanding, but I do not want to paint black over a curved orange surface. ) TrawlingCleaner, Rogue, Grotsmasha and 8 others 8 3 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5970246 Share on other sites More sharing options...
Grotsmasha Posted July 10, 2023 Author Share Posted July 10, 2023 * UPDATED TO THIS POINT * Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5970319 Share on other sites More sharing options...
Brother Argent Posted July 10, 2023 Share Posted July 10, 2023 Have updated my initial post of with the photos of the Leviathan box contents (the rest of my vow I have for now) ZeroWolf and Grotsmasha 2 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5970354 Share on other sites More sharing options...
Urkh Posted July 11, 2023 Share Posted July 11, 2023 "I, Urkh, heed the Call to Arms and pledge to paint: Two units of 10 guardian defenders with weapon platforms (22) 10 wraith guard and 5 wraith blades (15) 5 Rangers (5) 3 guardian windriders (6) Two farseers (10) A spiritseer (5) A wraithlord (4) for 67 points for the Glory of the Aeldari and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until years end. i also unofficially vow to finish the storm guardians in the front of the photo. andes, Dwango, ZeroWolf and 2 others 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5970569 Share on other sites More sharing options...
Xenith Posted July 11, 2023 Share Posted July 11, 2023 Make sure all you lovely nid players share you images in the tyranids section also! I'll make my vow soon, just need to assemble the Levi Nids! TrawlingCleaner and ZeroWolf 2 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5970613 Share on other sites More sharing options...
Dwango Posted July 11, 2023 Share Posted July 11, 2023 Maugan Ra done. Much progress on the infantry too but not quite finished yet. The vehicles are pretty much prepped waiting for priming. ZeroWolf, Cactus, Dr_Ruminahui and 9 others 10 2 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5970837 Share on other sites More sharing options...
Ace Debonair Posted July 12, 2023 Share Posted July 12, 2023 Oh boy it's happening Let's get to it then! "I, Ace Debonair, heed the Call to Arms and pledge to paint 8 Hearthkyn Salvagers for Eight (8) Points for the Glory of The Ancestor Cores (Or the LoV forum) and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until years end." As much as I want to go big and vow all Eighteen of my remaining Dwarves (and the fancy Store Birthday Kahl I just got) I think it's a better idea to start small with less models so I don't fall short burn out too fast. Let the Painting begin! ZeroWolf, Foremole, andes and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5971011 Share on other sites More sharing options...
Xenith Posted July 13, 2023 Share Posted July 13, 2023 (edited) Aright @Grotsmasha, here we go: I, Xenith, overlord of Hive Fleet Jabberwocky, heed the Call to Arms and pledge to paint the following for 55pts for the Glory of It Who Hungers and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until years end. 1x Neurotyrant (5pts) 2x neurospore things (2pts) 11x Neurogaunts (11pts) 5x Barbgaunts (5pts) 3x VRL's (3pts) 1x Screamer Killer (5pts?) 1x Winged Tyranid Prime (5pts) 1x Psychophage (5pts) 5x Wraithguard (5pts) 1x Spiritseer (5pts) 1x Webway gate (4pts* 6pts?) Total = 55pts* 57pts *corrected by Grot I'm starting with the nid units from Leviathan that I dont already have versions of, then will do the rest as a second vow if time permits - summers already getting busy! Objective is still to get the entire nid side painted within CTA! Edited July 16, 2023 by Xenith TrawlingCleaner, andes, Dwango and 2 others 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5971314 Share on other sites More sharing options...
Grotsmasha Posted July 13, 2023 Author Share Posted July 13, 2023 22 minutes ago, Xenith said: 1x Neurotyrant (5pts) 2x Neurospore things (2pts) 11x Neurogaunts (11pts) 5x Barbgaunts (5pts) 3x Von-Ryans Leapers's (3pts) 1x Screamer Killer (5pts) 1x Winged Tyranid Prime (5pts) 1x Psychophage (5pts) 5x Wraithguard (5pts) 1x Spiritseer (5pts) 1x Webway gate (6pts) Total = 57pts Xenith 1 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5971330 Share on other sites More sharing options...
Madao Posted July 14, 2023 Share Posted July 14, 2023 (edited) I, Madao, heed the Call to Arms and pledge to paint 3x Crisis Battlesuit (3x2=6p) 1x Broadside Battlesuit (1x3=3p) 1x Haemotrope Reactor (1x3=3p ?) 2x Thermic Plasma Regulators (2x3=6p ?) 1x Sanctum Administratum (1x8=8p) for 26 pts for the Glory of Tau forum and the Xenos Stronghold on or before 30th September 2023, or bear the badge of failure until years end. Edited July 14, 2023 by Madao Forgot to attach the photo :facepalm: Xenith, Grotsmasha, Dwango and 4 others 6 1 Back to top Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5971707 Share on other sites More sharing options...
Grotsmasha Posted July 16, 2023 Author Share Posted July 16, 2023 (edited) * UPDATED TO THIS POINT * Edited July 16, 2023 by Grotsmasha Link to comment https://bolterandchainsword.com/topic/379217-call-to-arms-xenos-stronghold/page/2/#findComment-5972208 Share on other sites More sharing options...
