arnesh88 Posted June 28, 2023 Share Posted June 28, 2023 One of the ideas I want to try out for 2k lists was to have Vulkan He'stan in a full Infernus Squad travel in a Land Raider Redeemer as one of my methods to take out infantry. I've debated whether or not it's a good idea to have another full Infernus Squad in a Drop Pod to drop in so that I have 3 flame units benefiting from his Forgefather ability. While I think this can do a lot of damage to infantry, I'm worried that it will be clunky with that many marines in a relatively small area, and that it might end up being overkill. I also considered including other flame units like Invictor Tactical Warsuits, or to even have additional Land Raider Redeemers to focus fire both infantry and tougher units (the single land raider redeemer i had did a lot of work when I went up against Carnifexes and Old One Eye). I can also use his ability for Melta weapons, but I thought it would be more efficient to use Oath of Moment for Melta and big guns on one big target, and use his Forgefather on another target. What are your thoughts? Any other units you would recommend to run alongside him? Lathe Biosas 1 Back to top Link to comment https://bolterandchainsword.com/topic/379312-vulkan-hestan-infernus-whats-the-right-amount/ Share on other sites More sharing options...
CCE1981 Posted June 28, 2023 Share Posted June 28, 2023 If you go Land Raider Crusader you can have a 10- man Infernus Squad plus a Multi-Melta Devestator Squad all in the same tank. Link to comment https://bolterandchainsword.com/topic/379312-vulkan-hestan-infernus-whats-the-right-amount/#findComment-5966325 Share on other sites More sharing options...
Malakithe Posted July 2, 2023 Share Posted July 2, 2023 On 6/28/2023 at 11:26 AM, arnesh88 said: One of the ideas I want to try out for 2k lists was to have Vulkan He'stan in a full Infernus Squad travel in a Land Raider Redeemer as one of my methods to take out infantry. I've debated whether or not it's a good idea to have another full Infernus Squad in a Drop Pod to drop in so that I have 3 flame units benefiting from his Forgefather ability. While I think this can do a lot of damage to infantry, I'm worried that it will be clunky with that many marines in a relatively small area, and that it might end up being overkill. I also considered including other flame units like Invictor Tactical Warsuits, or to even have additional Land Raider Redeemers to focus fire both infantry and tougher units (the single land raider redeemer i had did a lot of work when I went up against Carnifexes and Old One Eye). I can also use his ability for Melta weapons, but I thought it would be more efficient to use Oath of Moment for Melta and big guns on one big target, and use his Forgefather on another target. What are your thoughts? Any other units you would recommend to run alongside him? I was thinking of doing the drop pod + full Infernus too just for any chapter. 10d6 auto-hitting attacks is great use for everyone. For me im making a fun list on the app and leaning fully into the Torrent side of things. Probably 2 Redeemers but not sure if I want to go GravisCaptain + Aggressors or Adrax + AInts for a melee unit Link to comment https://bolterandchainsword.com/topic/379312-vulkan-hestan-infernus-whats-the-right-amount/#findComment-5967491 Share on other sites More sharing options...
CCE1981 Posted July 2, 2023 Share Posted July 2, 2023 Not trying to take over your post, but I thought I might try to playa round a bit: Melta Burn (1990 Points) Space Marines Salamanders Gladius Task Force Strike Force (2000 Points) CHARACTERS Primaris Lieutenant (75 Points) • 1x Master-crafted power weapon 1x Neo-volkite pistol 1x Storm Shield Primaris Lieutenant (75 Points) • 1x Master-crafted power weapon 1x Neo-volkite pistol 1x Storm Shield Vulkan He’stan (95 Points) • Warlord • 1x Bolt Pistol 1x Gauntlet of the Forge 1x Spear of Vulkan OTHER DATASHEETS Bladeguard Veteran Squad (200 Points) • 1x Bladeguard Veteran Sergeant • 1x Master-crafted power weapon 1x Plasma pistol • 5x Bladeguard Veteran • 5x Heavy bolt pistol 5x Master-crafted power weapon Bladeguard Veteran Squad (200 Points) • 1x Bladeguard Veteran Sergeant • 1x Master-crafted power weapon 1x Plasma pistol • 5x Bladeguard Veteran • 5x Heavy bolt pistol 5x Master-crafted power weapon Devastator Squad (120 Points) • 1x Devastator Sergeant • 1x Close combat weapon 1x Plasma pistol 1x Power fist • 4x Devastator • 4x Bolt pistol 4x Close combat weapon 4x Multi-melta Devastator Squad (120 Points) • 1x Devastator Sergeant • 1x Close combat weapon 1x Plasma pistol 1x Power fist • 4x Devastator • 4x Bolt pistol 4x Close combat weapon 4x Multi-melta Devastator Squad (120 Points) • 1x Devastator Sergeant • 1x Close combat weapon 1x Plasma pistol 1x Power fist • 4x Devastator • 4x Bolt pistol 4x Close combat weapon 4x Multi-melta Infernus Squad (180 Points) • 1x Infernus Sergeant • 1x Bolt pistol 1x Close combat weapon 1x Pyreblaster • 9x Infernus Marine • 9x Bolt pistol 9x Close combat weapon 9x Pyreblaster Land Raider (275 Points) • 1x Armoured tracks 2x Godhammer lascannon 1x Hunter-killer missile 1x Multi-melta 1x Storm bolter 1x Twin heavy bolter Land Raider (275 Points) • 1x Armoured tracks 2x Godhammer lascannon 1x Hunter-killer missile 1x Multi-melta 1x Storm bolter 1x Twin heavy bolter Land Raider Crusader (255 Points) • 1x Armoured tracks 1x Hunter-killer missile 2x Hurricane bolter 1x Multi-melta 1x Storm bolter 1x Twin assault cannon That’s three full Land Raiders, and I think some significant Firepower to throw around. The 10-man Infernus Squad is for Overwatch, maybe split into 2x 5-man units to cover more ground. Link to comment https://bolterandchainsword.com/topic/379312-vulkan-hestan-infernus-whats-the-right-amount/#findComment-5967749 Share on other sites More sharing options...
