strawberry fist Posted June 29, 2023 Share Posted June 29, 2023 I’m starting a new army and elected to go for the Sons of Horus and ultimately would like them to be used in competitive tournaments, if I can ever get tickets to events. I’ve got 123 point left to use to get me to 2000. Would you suggest a scorpius or xyphon interceptor or anything different? what are people thoughts on the list below as I’m not 100% sure on using the long march as a rite of war as the heavy support squad will have to start in a rhino/ off the board which mitigates their output for a turn. Thanks in advance. Sons of Horus Rite of War: The Long March 1877 points HQ Centurion Master of Signals -artificer armour Praetor Warlord Banestrike Bolter, Bolt Pistol, Thunder hammer Retinue - Justaerin Terminator Squad 1x multi-melta and thunder hammer 1x standard and thunder hammer 3x banestrike combi-bolter and carsoran power axe Transport- Land Raider Proteus Carrier: Twin-linked Heavy Bolter Elites: Contemptor Dreadnought: Combi-Bolter, Gravis Lascannon, Gravis Power Fist with in-built ranged weapon Troops Reconnaissance Squad [135Pts][/b] 5x Nemesis Bolter Tactical Squad Legion Tactical Sergeant: Artificer Armour, Bolt Pistol, Bolter, Power Fist 9x Legionaries - Bolt Pistol, Bolter Legion Vexilla Rhino Transport: Dozer Blade, Multi-Melta Tactical Squad Legion Tactical Sergeant: Artificer Armour, Bolt Pistol, Bolter, Power Fist 9x Legionaries - Bolt Pistol, Bolter Legion Vexilla Rhino Transport: Dozer Blade, Multi-Melta Heavy Support Heavy Support Squad 10x Lascannon Rhino Transport Starlight_Wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/379319-sons-of-horus-beginners-army/ Share on other sites More sharing options...
Starlight_Wolf Posted June 30, 2023 Share Posted June 30, 2023 A few points off the top of my head (All personal opinion) Drop the Thunder hammer from the Praetor, probably switch into a Paragon blade (same points and has insta death at initiative, really helps, and the squad he's with have a lot of brutal attacks) I'd swap the Axes on the terminators, +1 extra strength really adds up (and you don't really lose anything from two handed) With the Contemptor, I'd suggest switching the LC for a melta partly as I imagine he'll be stomping up the board and given the amount of LC's you have he's likely to want to get in close making the LC a little less useful Swap your Vexillias for Augury scanners (gives defence against Deep strike (via intercept) and counters night fight), if your Master of Signals isn't with the Heavy support squad throw on on them too Drop the multi meltas from your rhinos, they won't live long enough to make good use of them (search lights may be a good alternative to allow your Proteus to pot shot vehicles as it moves up) I'd potentially add a second Recon squad for a second source of pinning (which denies reactions and can help break squads), though a Scorpius is also a good choice for this too. Also provides another good objective holder for backline. Still finding my way through Heresy currently also, but from experience the above should prove helpful (maybe review the fist on Tac Sarges as you could possibly use the points better else where) Link to comment https://bolterandchainsword.com/topic/379319-sons-of-horus-beginners-army/#findComment-5966739 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted July 16, 2023 Share Posted July 16, 2023 I have little to add. The only thing I can add is, if you're going to use that RoW, maybe is better to spend the Proteus points in other unit(s), Troops if it's possible and maintain the Vexilas. Link to comment https://bolterandchainsword.com/topic/379319-sons-of-horus-beginners-army/#findComment-5972347 Share on other sites More sharing options...
