Interrogator Stobz Posted July 4, 2023 Share Posted July 4, 2023 (edited) Do you have a link for that leaked sprue pic please? I am inspired by these poses seen at WHW. I may need to get resin ones whilst available. Edited July 4, 2023 by Interrogator Stobz Pics Noserenda 1 Back to top Link to comment Share on other sites More sharing options...
Grotsmasha Posted July 4, 2023 Share Posted July 4, 2023 1 hour ago, Interrogator Stobz said: Do you have a link for that leaked sprue pic please? I am inspired by these poses seen at WHW. I may need to get resin ones whilst available. Undoubtedly there will be 3rd party posable legs in both physical and digital availability either on launch or within days. Hell, there's probably already some available.... Interrogator Stobz 1 Back to top Link to comment Share on other sites More sharing options...
Interrogator Stobz Posted July 4, 2023 Share Posted July 4, 2023 Hope is a painful drug Brother. Although I'm not afraid of resin, in fact I love it, I'd prefer plastic Cerastus over resin, so bring the pain. Link to comment Share on other sites More sharing options...
Interrogator Stobz Posted July 4, 2023 Share Posted July 4, 2023 (edited) Just from the whole model pics it looks like each Cerastus has different poses, so that's a plus. Or maybe I can't see properly Edited July 4, 2023 by Interrogator Stobz Please merge. :) Link to comment Share on other sites More sharing options...
Brother_Angelus Posted July 4, 2023 Share Posted July 4, 2023 (edited) They said on stream that there were lots of ball joints. I'd also be interested to see this "leaked sprue" since they'll all be 80% the same model and the promo pictures so far don't really suggest monopose. Edited July 4, 2023 by Brother_Angelus Interrogator Stobz 1 Back to top Link to comment Share on other sites More sharing options...
Noserenda Posted July 5, 2023 Share Posted July 5, 2023 Im hoping we get good leg movement, or at least its as easy to repose as the questoris! Those WHW knights are soo pretty, bit annoyed i saw them after building my Acheron and Atrapos because next cerastus is getting that level on crouching coolness. Interrogator Stobz 1 Back to top Link to comment Share on other sites More sharing options...
Fire Golem Posted July 5, 2023 Share Posted July 5, 2023 The only leaked sprue we saw was the Acheron (or whichever one it was) parts, wasn’t it? None of the actual chassis. Link to comment Share on other sites More sharing options...
Nova-V Posted July 6, 2023 Share Posted July 6, 2023 On 7/5/2023 at 7:48 AM, fire golem said: The only leaked sprue we saw was the Acheron (or whichever one it was) parts, wasn’t it? None of the actual chassis. Correct no chassis shots yet. Which is kinda odd that someone had the weapons sprue but not the chassis to show off. I'm interested in how they do the ammo feed. They were saying on the stream it could follow the arm to almost any position, which reminds me of the classic tank track issue. Do you provide the parts in a flexible material that is impossible to work with or do you provide many individual links that are a pain to build? I'm really intrigued to see what they do. Link to comment Share on other sites More sharing options...
Grotsmasha Posted July 6, 2023 Share Posted July 6, 2023 5 minutes ago, Nova-V said: do you provide many individual links that are a pain to build? Hopefully this specific section is designed to be push-fit, and not require glue. Magos Takatus and Interrogator Stobz 1 1 Back to top Link to comment Share on other sites More sharing options...
Magos Takatus Posted July 6, 2023 Share Posted July 6, 2023 5 hours ago, Grotsmasha said: Hopefully this specific section is designed to be push-fit, and not require glue. Back in the nineties I owned a model kit of Gundam Epyon and it had a whip-like weapon that could work very similarly. While much more detailed than the kit I owned back then this gives an idea. In the kit I owned (and I think all modern Gundam kits) this is all push fit and it works well. The Castigator ammo feed does not need to be this flexible so the bladed sections can be ignored and the jointed section can be a little thicker. If it will be a ball joint it might allow some wiggle room sideways. I am confident that the Cerastus ammo feeds will not be that difficult to build from looking at the photographs but they might be a little bit time consuming. I suppose Bandai push fit and GW push fit are not the same thing though so I could be wrong. Modern GW push fit can be a bit more finicky from my experience. Mind you that's because GW likes to fit honking great push-fit cylinders onto the same model parts that have small, fragile details for some reason. Great, I am talking myself down from it being an easy job to assemble them. ZeroWolf and Interrogator Stobz 1 1 Back to top Link to comment Share on other sites More sharing options...
Redcomet Posted July 7, 2023 Share Posted July 7, 2023 21 hours ago, Grotsmasha said: Hopefully this specific section is designed to be push-fit, and not require glue. It will require glue on some parts, but not others, is my guess. A hinge that you sandwich between two parts of each link. Don’t put glue on the hinge, but glue the link together. Link to comment Share on other sites More sharing options...
Focslain Posted July 7, 2023 Share Posted July 7, 2023 On 7/6/2023 at 12:33 PM, Magos Takatus said: Back in the nineties I owned a model kit of Gundam Epyon and it had a whip-like weapon that could work very similarly. While much more detailed than the kit I owned back then this gives an idea. In the kit I owned (and I think all modern Gundam kits) this is all push fit and it works well. The Castigator ammo feed does not need to be this flexible so the bladed sections can be ignored and the jointed section can be a little thicker. If it will be a ball joint it might allow some wiggle room sideways. I am confident that the Cerastus ammo feeds will not be that difficult to build from looking at the photographs but they might be a little bit time consuming. I suppose Bandai push fit and GW push fit are not the same thing though so I could be wrong. Modern GW push fit can be a bit more finicky from my experience. Mind you that's because GW likes to fit honking great push-fit cylinders onto the same model parts that have small, fragile details for some reason. Great, I am talking myself down from it being an easy job to assemble them. Speaking of Bandai, they might have just gave GW the plan/mold for the ammo belt for the Gravis Captain they had commissioned Bandai to do. Would do the trick nicely. Magos Takatus 1 Back to top Link to comment Share on other sites More sharing options...
Jamafore Posted July 8, 2023 Share Posted July 8, 2023 On 7/6/2023 at 11:33 AM, Magos Takatus said: Back in the nineties I owned a model kit of Gundam Epyon and it had a whip-like weapon that could work very similarly. While much more detailed than the kit I owned back then this gives an idea. In the kit I owned (and I think all modern Gundam kits) this is all push fit and it works well. The Castigator ammo feed does not need to be this flexible so the bladed sections can be ignored and the jointed section can be a little thicker. If it will be a ball joint it might allow some wiggle room sideways. I am confident that the Cerastus ammo feeds will not be that difficult to build from looking at the photographs but they might be a little bit time consuming. I suppose Bandai push fit and GW push fit are not the same thing though so I could be wrong. Modern GW push fit can be a bit more finicky from my experience. Mind you that's because GW likes to fit honking great push-fit cylinders onto the same model parts that have small, fragile details for some reason. Great, I am talking myself down from it being an easy job to assemble them. When I saw the posable ammo links in the community page I thought of the same setup. Only thing would be that over time and use, the polycaps Bandai uses get wiggly. How long depends a lot on the weight of the pieces Link to comment Share on other sites More sharing options...
Redcomet Posted July 8, 2023 Share Posted July 8, 2023 5 hours ago, Jamafore said: When I saw the posable ammo links in the community page I thought of the same setup. Only thing would be that over time and use, the polycaps Bandai uses get wiggly. How long depends a lot on the weight of the pieces Hence why you almost never find them in new kits outside the cheap HG line. They do wizardry with plastic that makes GW look like beginners Link to comment Share on other sites More sharing options...
Jukkiz Posted July 8, 2023 Share Posted July 8, 2023 5 hours ago, Redcomet said: Hence why you almost never find them in new kits outside the cheap HG line. They do wizardry with plastic that makes GW look like beginners and with half a price of GWs HQ kits Could it be like tank tread connection? A wiggly belt that allows it movement with alot hollow parts to reduce weight? Link to comment Share on other sites More sharing options...
Nova-V Posted July 8, 2023 Share Posted July 8, 2023 On 7/6/2023 at 11:55 AM, Grotsmasha said: Hopefully this specific section is designed to be push-fit, and not require glue. To be fair it's not the gluing that is the issue it's the clean up! Snipping off 10s of small hard to handle prices removing the sprue gates and mould lines is an absolute pain. sarabando 1 Back to top Link to comment Share on other sites More sharing options...
Interrogator Stobz Posted July 8, 2023 Share Posted July 8, 2023 7 minutes ago, Nova-V said: To be fair it's not the gluing that is the issue it's the clean up! Snipping off 10s of small hard to handle prices removing the sprue gates and mould lines is an absolute pain. Oh the gluing will be a pain too. How hard is it going to be getting it to hang right and meet each end unless there is some snap fit ball joint? Link to comment Share on other sites More sharing options...
Matcap86 Posted July 9, 2023 Author Share Posted July 9, 2023 Another thing I just thought of: the knight lancer has transfers for house devine. We haven't seen those before have we? Might we get a new transfer sheet with more HH prevalent households? Interrogator Stobz 1 Back to top Link to comment Share on other sites More sharing options...
CL_Mission Posted July 9, 2023 Share Posted July 9, 2023 During a previous Knight release GW put out transfer sheets for a few different houses for a limited time, right? Or am I misremembering? They might be doing that again for these lanky lads. Link to comment Share on other sites More sharing options...
