Khorneeq Posted July 2, 2023 Share Posted July 2, 2023 Space Marines Terminators have Fury of the First rule which allows them to ignore modifiers to ballistic skill and hit roll. Overwatch says only unmodified hit roll off 6 Hits. Which takes precedence? What if unit gets Critical Hits on roll of 5+(critical hits always hit the target) Can this improve chances of hit while overwatching? Link to comment https://bolterandchainsword.com/topic/379366-overwatch-with-fury-of-the-firstcritical-hits/ Share on other sites More sharing options...
Solution Commander Dawnstar Posted July 2, 2023 Solution Share Posted July 2, 2023 To quote the Rules Commentary document: "Modifiers are rules that change a numerical value from one value to another." Overwatch making you hit only on unmodified 6s isn't a modifier as it isn't altering your BS or applying a penalty to your To Hit roll; it isn't setting you to BS 6+. There are no modifiers in play here, it's just that only unmodified 6s to hit matter for the purposes of the rule. The Rules Commentary document also states that: "While resolving attacks using the Fire Overwatch Stratagem, Critical Hits are only ever scored on unmodified Hit rolls of 6." Khorneeq and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379366-overwatch-with-fury-of-the-firstcritical-hits/#findComment-5967623 Share on other sites More sharing options...
