Viridium IV Posted July 10, 2023 Share Posted July 10, 2023 Recently got a box of Adepta Sororitas Combat Patrol, but when I calculate all the points, including the weapons that are listed in the assembly instructions, I get 330 points. I've ran through it a couple times and I don't believe I've made any mistakes with the equippment, but every where I look it says that it should be around 500 points, one source even said fully equipped it was 540 points, so I'm very confused about the point value of the army. Here's my calculations if needed: Canoness is 50, equipped with plasma pistol, power sword, rod of office, frag grenades, and krak grenades. this appears to match molded gear Battle Sisters are 22 base, but equipped with a lot base equipped with bolt pistol, boltgun, frag grenades, and krak grenades. equippment based of labels from assembly is: 1 sister with a simulacrum imperialis per the wargear options, so +5 1 sister with a stormbolter per the second wargear option, so +5 1 sister with a flamer per the third wargear option, also +5 the rest have standard equippment, the total comes to: 37 points Seraphim Squad is 24 base, equipped with 2 bolt pistols, frag grenades, and krak grenades. the seraphim supierors bolt pistols have been replaced with a plasma pistol and a power sword, being +5 each for a total of +10 the rest are equipped with standard gear so the total is: 34 points Repentia Superior is 40 points, has neural whips, frag grendades, and krak grenades. Sisters repentia is 16, base equipped with penitent eviscerator Technically different units, lumped together in building. arco flagellants are 13, equipped with arco-flails assuming 1 is equipped with +5 endurant implants, per the options total of: 18 points penitent engine is 50, equipped with 2 ministorum heavy flamers and 2 penitent buzz-blades this seems to match sororitas rhino is 80, equipped with storm bolter hunter killer missile for +5 in accordance to the options. has some transport options and abilities. Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/ Share on other sites More sharing options...
Solution Foremole Posted July 10, 2023 Solution Share Posted July 10, 2023 So, two things (and bear in mind I'm new to 40,000 myself so I may be getting this wrong): 1) It looks like you're using the points for 9th edition as opposed to 10th. 10th has all the points based on preset unit sizes, where your Battle Sisters squad is always 10 models and always 110 points. 2) It looks like you're not paying for each model in the squad. 10 Battle Sisters costs 110 points in 9th - 11 points for each Sister + 11 points for the Sister Superior. The Battle Sisters, Seraphim Squad, Sisters Repentia, and Arco Flagellants should all be much higher costs if you're taking all the models in the box in each unit. Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970227 Share on other sites More sharing options...
Viridium IV Posted July 10, 2023 Author Share Posted July 10, 2023 (edited) Yes, I am using the 9th edition points system instead of the new power rating system, as 9th has more readily available information without purchasing a rulebook or codex. I believe that I am paying for each model, as you don't need to pay that much, for example with the battle sisters squad, the Sister Superior is 11 points whereas between 4-19 battle sisters is 11 points per that many, so if you have 38 battle sisters you would have 22 points for all of them, plus the 11 for the Sister Superior, but in this case since I have less than 19 models total in the unit so the unit should only be 22 points without gear. At least, this is how I interpreted the stats on games-workshop. This makes sense to me because a Sister Superior would have more points than a regular sister since she's more powerful. Edited July 10, 2023 by Viridium IV Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970239 Share on other sites More sharing options...
Foremole Posted July 10, 2023 Share Posted July 10, 2023 From page 241 of the 9th Edition Core Book: "A unit's points value is calculated by adding together the points value of every individual model (emphasis mine) in that unit and the points value of every individual weapon equipped by a model in that unit." So you should be spending 11 points per Sister. Think of the Sister Superior's extra strength as being like a free upgrade. Also, the 10th edition rules and army lists are available for free on the Warhammer Community website, no need to buy any books. Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970241 Share on other sites More sharing options...
Viridium IV Posted July 10, 2023 Author Share Posted July 10, 2023 Interesting, I'll try recalculating the points and see if it comes out to a better number. Do you think the number next to the model for the units stats is how many you can have per unit? Thanks for the help! Foremole 1 Back to top Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970244 Share on other sites More sharing options...
Foremole Posted July 10, 2023 Share Posted July 10, 2023 I believe it is how many models you can have in the unit. And I'm glad I could help! Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970245 Share on other sites More sharing options...
Viridium IV Posted July 10, 2023 Author Share Posted July 10, 2023 Calculated the points, a much more reasonable 543 points, thanks! Now I can use this for the future! Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970247 Share on other sites More sharing options...
Dusktiger Posted July 10, 2023 Share Posted July 10, 2023 (edited) your points are still wrong for what's in the box; Cannoness (1 model) - 60pts Battle Sister Squad (10 models) - 110pts Repentia squad (5 models) - 75pts Arco-flagellants (3 models) - 45pts Seraphim squad (5 models) - 70pts Penitent Engine (1 model) - 60pts Sororitas Rhino (1 model) - 80pts that comes out to exactly 500pts using the point values from the MUNITORUM FIELD MANUAL - VERSION 1.2 pdf on the official site at the time of writing this. addendum - all of the Combat Patrol boxes come out to exactly 500pts with the new point values for 10th edition. this was done purposely when they were making the point values and reboxing the starter box sets for all the factions. Edited July 10, 2023 by Dusktiger Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970263 Share on other sites More sharing options...
Blurf Posted July 10, 2023 Share Posted July 10, 2023 17 hours ago, Viridium IV said: Calculated the points, a much more reasonable 543 points, thanks! Now I can use this for the future! Don't do that? Combat Patrol is its own game mode that doesn't use points. 9th is no longer a supported ruleset. Foremole and Emperor Ming 2 Back to top Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970521 Share on other sites More sharing options...
Corvus Fortis Posted July 11, 2023 Share Posted July 11, 2023 On 7/10/2023 at 5:43 AM, Viridium IV said: Yes, I am using the 9th edition points system instead of the new power rating system, as 9th has more readily available information without purchasing a rulebook or codex. Almost all rules for 10th edition are free, including core rules, army rules and points. Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970830 Share on other sites More sharing options...
Lemondish Posted July 11, 2023 Share Posted July 11, 2023 (edited) On 7/9/2023 at 10:43 PM, Viridium IV said: Yes, I am using the 9th edition points system instead of the new power rating system, as 9th has more readily available information without purchasing a rulebook or codex. Points and rules for both 10th edition 40k and Combat Patrol are free and readily available from either the official app or the Warhammer Community website under downloads. Please note that combat patrol is a separately balanced game format that does not use points. Take everything in the box and match it up against everything in any other combat patrol box. The rules are therefore a tad different than the index rules for 40k. Edited July 11, 2023 by Lemondish Link to comment https://bolterandchainsword.com/topic/379481-adepta-sororitas-combat-patrol-box-not-500-points/#findComment-5970831 Share on other sites More sharing options...
