Spyros Posted July 10, 2023 Share Posted July 10, 2023 (edited) So I own a Seraptek. This means I WANT/HAVE/MUST use it We play friendly but capable lists, and this is what I came up with: 2000 points exactly! 110 Overlord - Blade & Orb, Hypermaterial Ablator 60 Technomancer - Staff 190 Lychguard (10) - sword & shield 75 Lord - Blade & Orb, Sempiternal Weave 60 Technomancer - Staff 240 Warriors (20) - Flayers 120 Warriors (10) - Reapers 95 Canoptek Reanimator 80 Tomb blades (3) 90 Lokhust Hv.Destroyers - Gauss 125 Canoptek Doomstalker 125 Canoptek Doomstalker 90 Technomancer - Staff, Canoptek Cloak, Sovereign Coronal 540 Seraptek Heavy Construct - Singularity Generators The plan is simple. The Lychguard, the 20 Warriors, the Tomb Blades and the Seraptek advance forwards to objectives. The 10 Warriors hold the home objective. The Hv.Destroyers and Doomstalkers try to support the battleline and take advantage of the Lone operative Technomancer's Coronal, and of course so does the Seraptek. ----------------- A slightly altered list because I 'm unsure of the durability of the 3 Tomb blades (which are there to run to an objective and force the opponent's hand). Remove the Lokhust Hv.Destroyers to make the Tomb Blades 6 and replace the Lord's Sempiternal weave with Veil of Darkness (and thus propel the warriors on an objective as fast as the Tomb Blades). Edited July 10, 2023 by Spyros Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/379486-2000-pts-seraptek-semi-competitive-friendly-list/ Share on other sites More sharing options...
Nap time Necron Posted July 10, 2023 Share Posted July 10, 2023 This doesn't list how you've equipped your tomb blades but I recommend two particle beamers and a Tesla. The particle beamers are the best gun for them by far but Tesla is assault which means you can advance and still be eligible to shoot for all the secondaries that require such things. Spyros 1 Back to top Link to comment https://bolterandchainsword.com/topic/379486-2000-pts-seraptek-semi-competitive-friendly-list/#findComment-5970517 Share on other sites More sharing options...
Spyros Posted July 10, 2023 Author Share Posted July 10, 2023 8 minutes ago, Nap time Necron said: This doesn't list how you've equipped your tomb blades but I recommend two particle beamers and a Tesla. The particle beamers are the best gun for them by far but Tesla is assault which means you can advance and still be eligible to shoot for all the secondaries that require such things. Yes, I'm planning to build them with particle beams. The proposition for one with tesla is intuiging, what information do we have on such secondaries? Link to comment https://bolterandchainsword.com/topic/379486-2000-pts-seraptek-semi-competitive-friendly-list/#findComment-5970520 Share on other sites More sharing options...
Captain Idaho Posted July 11, 2023 Share Posted July 11, 2023 It's an interesting list actually, never thought about the Serpatek construct. It's basically a Knight we can heal which is pretty cool. The funny thing is we can essentially heal him for 3D3 a turn too, with the Reanimator, Reanimation Protocols and the Technomancer with a Canoptek Cloak. I like. Spyros 1 Back to top Link to comment https://bolterandchainsword.com/topic/379486-2000-pts-seraptek-semi-competitive-friendly-list/#findComment-5970606 Share on other sites More sharing options...
Spyros Posted July 11, 2023 Author Share Posted July 11, 2023 The only problem with the Seraptek is saturation and my bad rolls. I 've played one test game in 10th so far and it became the target of 3 IG Basilisks and 3 Leman Russ Executioners, all under orders... I must have failed ALL my saves, including the FNP from an accompanying Spyder... An my shooting was equally bad. This time i plan to push with all the army simultaneously and hope that, the opponent will be forced to spread his fire, I will roll better (having invested in the sovereign Coronal), and my opponent to roll a bit worse... I mean he's freaking lucky! I 've been using his dice too but nooo, no good rolls for me! LOL Link to comment https://bolterandchainsword.com/topic/379486-2000-pts-seraptek-semi-competitive-friendly-list/#findComment-5970615 Share on other sites More sharing options...
Nap time Necron Posted July 11, 2023 Share Posted July 11, 2023 19 hours ago, Spyros said: Yes, I'm planning to build them with particle beams. The proposition for one with tesla is intuiging, what information do we have on such secondaries? I believe you have a roughly 1 in 4 chance of drawing such a secondary. They're phrased "A unit that is eligible to shoot can do [X] while in [Y area], they cannot shoot or perform a charge for the rest of the turn." If you have an assault weapon in the unit they are still eligible after advancing which gives a nice boost to your ability to go the extra distance and still do the thing. Spyros 1 Back to top Link to comment https://bolterandchainsword.com/topic/379486-2000-pts-seraptek-semi-competitive-friendly-list/#findComment-5970777 Share on other sites More sharing options...
