Valkyrion Posted July 17, 2023 Share Posted July 17, 2023 It might work better with some legions than others, but what about building a reivers or infiltrators kit up to the body, then putting on 30k arms, heads and back packs? Experimental or prototype armour maybe? Or is it just too different to pass? StratoKhan, Gorgoff and mooftak 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/ Share on other sites More sharing options...
Ripper.McGuirl Posted July 17, 2023 Share Posted July 17, 2023 I would do it the other way around and use their cool guns on 30k appropriate bodies. But I’m sure it would look cool with some modeling skill and paint! Valkyrion, Orion and Squark 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5972633 Share on other sites More sharing options...
Valkyrion Posted July 17, 2023 Author Share Posted July 17, 2023 I'd not considered that, but I think you might be on to something! Will the Phobos arms fit the mark VI bodies and shoulder pads? I have a feeling that the 40k phobos stuff has a bigger than average shoulder because they don't put a pad on it, but I may be wrong. Experimental helmets would be fine, (or the reiver skulls for a traitor vibe) Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5972652 Share on other sites More sharing options...
Squark Posted July 17, 2023 Share Posted July 17, 2023 (edited) 1 hour ago, Valkyrion said: I'd not considered that, but I think you might be on to something! Will the Phobos arms fit the mark VI bodies and shoulder pads? I have a feeling that the 40k phobos stuff has a bigger than average shoulder because they don't put a pad on it, but I may be wrong. Experimental helmets would be fine, (or the reiver skulls for a traitor vibe) The right shoulder pad on phobos armor is noticeably thicker than typical space marine arms and won't fit the standard pauldrons without some serious filing or snipping. Their left arm is compatible, though, since the pauldron is the same size minus the tiny cutout (which a handful of firstborn pauldrons have shared, actually). The infiltrator helmets and occulus bolt carbines would work quite well for seekers. Edited July 17, 2023 by Squark Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5972680 Share on other sites More sharing options...
Marshal Rohr Posted July 18, 2023 Share Posted July 18, 2023 This is a pretty common conversion I’ve seen online and it looks okay when well executed. The capri pants silhouette is similar to some of original rogue trader metals. This is comes from the same place as all the Primaris to heresy conversions - they’re just a bit too big. That’s can be solved with careful conversion and bulking but you run the risk of throwing off the whole model if you get that wrong. Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5972740 Share on other sites More sharing options...
Orion Posted July 18, 2023 Share Posted July 18, 2023 I'd avoid the legs and powerpack. The other parts look pretty decent though. Trimming shoulders shouldn't be too hard if you're covering them up with pauldrons after. Just do a hack job. Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5972743 Share on other sites More sharing options...
Orion Posted July 18, 2023 Share Posted July 18, 2023 Or go padless like this guy's dope squad. The legs might be a bit small looking here, but new mkvi would probably work fine. https://www.instagram.com/p/CH43HJgH3li/ Lord Marshal, Gorgoff, Agramar_The_Luna_Wolf and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5972744 Share on other sites More sharing options...
Ripper.McGuirl Posted July 18, 2023 Share Posted July 18, 2023 18 hours ago, JayJapanB said: Or go padless like this guy's dope squad. The legs might be a bit small looking here, but new mkvi would probably work fine. https://www.instagram.com/p/CH43HJgH3li/ Holy sweet mother of Magnus I love these. Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5972992 Share on other sites More sharing options...
StratoKhan Posted August 15, 2023 Share Posted August 15, 2023 On 7/17/2023 at 6:30 PM, Valkyrion said: It might work better with some legions than others, but what about building a reivers or infiltrators kit up to the body, then putting on 30k arms, heads and back packs? Experimental or prototype armour maybe? Or is it just too different to pass? Rivet counters might complain, but I think the idea has potential. Personally I'm not enamoured with the Phobos legs, so I would fill in that gap they have or straight up replace the shins. It all depends on how much cutting and filing you're willing to invest into the project. It also depends on how bothered you are about some details - details that maybe nudge the unit towards looking a little more 40k than 30k. I would say that with a few changes a unit based on Reivers can look like a very nice unit that 'fits' into 30k. One thing - I did the opposite and tried to use Eliminator arms on my MKVI-derived Recon Squad, and the Primaris arms are actually bigger than normal marines, it was quite noticeable to me and really threw the proportions of those models off, which led me to scrap that iteration of the project. So if you use 30k plastics for the body, I would recommend keeping standard marine arms, or you risk having gorilla armed models. If you use Primaris bodies, the 30k arms will probably still look fine imo. Noserenda and Gorgoff 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5981377 Share on other sites More sharing options...
Gorgoff Posted August 15, 2023 Share Posted August 15, 2023 On 7/17/2023 at 7:30 PM, Valkyrion said: It might work better with some legions than others, but what about building a reivers or infiltrators kit up to the body, then putting on 30k arms, heads and back packs? Experimental or prototype armour maybe? Or is it just too different to pass? They are too big to pass and on a personal note I think that Phobos armors are one of the worse models GW has every made. Starting with the sandals, ending with the ceop top to show artifical abs like 80s body builders at muscle beach. Some parts and bitz could work though. 2 hours ago, StratoKhan said: One thing - I did the opposite and tried to use Eliminator arms on my MKVI-derived Recon Squad, and the Primaris arms are actually bigger than normal marines, it was quite noticeable to me and really threw the proportions of those models off, which led me to scrap that iteration of the project. So if you use 30k plastics for the body, I would recommend keeping standard marine arms, or you risk having gorilla armed models. Haha yes. 2 hours ago, StratoKhan said: If you use Primaris bodies, the 30k arms will probably still look fine imo. But then the models end up being 1.5 times bigger than everyone else Bat33.1 and MegaVolt87 2 Back to top Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5981409 Share on other sites More sharing options...
sarabando Posted August 16, 2023 Share Posted August 16, 2023 MkX armour is just too indentifiable as primaris it just doesnt work imo. They arms are passable and ive used several myself. Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5981588 Share on other sites More sharing options...
Noserenda Posted August 16, 2023 Share Posted August 16, 2023 It can certainly work if done well, trying to judge a conversion is "appropriate" before its made is a bit of a stretch unless you are like, trying to base the model off grots or something :) TwinOcted 1 Back to top Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5981604 Share on other sites More sharing options...
MegaVolt87 Posted August 17, 2023 Share Posted August 17, 2023 The new mk VI with the Phobos bolters and accessories would work, but I wouldn't use anything else. The G36 style rifles are also usable. Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5981713 Share on other sites More sharing options...
sarabando Posted August 17, 2023 Share Posted August 17, 2023 16 hours ago, Noserenda said: It can certainly work if done well, trying to judge a conversion is "appropriate" before its made is a bit of a stretch unless you are like, trying to base the model off grots or something :) sure it could be done, if you cover up everything that makes a phobos marine a phobos marine. like how Doghouse used to make Chaos warriors into marines. but the title phobos = seekers is simply a no Noserenda 1 Back to top Link to comment https://bolterandchainsword.com/topic/379567-40k-phobos-30k-seekers/#findComment-5981724 Share on other sites More sharing options...
