Inquisitor_Lensoven Posted July 25, 2023 Share Posted July 25, 2023 I’m moving across the country soon and don’t have any good ideas on how to transport inceptors safely. any advice? Link to comment https://bolterandchainsword.com/topic/379674-flight-stand-protection/ Share on other sites More sharing options...
Brother Tyler Posted July 25, 2023 Share Posted July 25, 2023 Foam. You can get both the kind where you pluck out "squares" as well as uncut sheets. Start by plucking out the "squares" to allow the bases to fit snugly, then use a hobby knife to cut away additional portions that allow the model to fit in snugly without having [a lot] of room to move around. Uncut sheets that are the same length and width of the cut foam can them be placed on top to protect the models (and you can get these in various sizes and thicknesses). You might even glue the pieces that you removed to the underside of the uncut sheets, making them both fit one way as a lid as well as protecting the tops/sides of the models, though this takes a lot of work. Then be sure to mark the exterior of the container as "fragile" to [hopefully] ensure gentle treatment (never a guarantee, but always worth a shot). Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/379674-flight-stand-protection/#findComment-5975387 Share on other sites More sharing options...
Cactus Posted July 25, 2023 Share Posted July 25, 2023 This is how I would do it on the cheap. Line a box with bubble wrap and some crumpled paper. Wrap each mini in soft toilet paper and put them in the box. Fill gaps between minis with more crumpled paper. If you shake the box there should be very little movement inside. The aim is to ensure enough cushioning that any hard objects don't impact any other hard objects (ie. other models or the box). If you're employing someone to move your stuff, rather than putting it all in your own car or whatever, consider insurance. skylerboodie and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/379674-flight-stand-protection/#findComment-5975389 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 25, 2023 Author Share Posted July 25, 2023 5 hours ago, Cactus said: This is how I would do it on the cheap. Line a box with bubble wrap and some crumpled paper. Wrap each mini in soft toilet paper and put them in the box. Fill gaps between minis with more crumpled paper. If you shake the box there should be very little movement inside. The aim is to ensure enough cushioning that any hard objects don't impact any other hard objects (ie. other models or the box). If you're employing someone to move your stuff, rather than putting it all in your own car or whatever, consider insurance. I’ve got a bunch of packing peanuts so I’ll do that Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/379674-flight-stand-protection/#findComment-5975489 Share on other sites More sharing options...
Cleon Posted July 26, 2023 Share Posted July 26, 2023 Honestly I think with Inceptors, this current generation of flight stand is so bad, you should set your expectations at 'minimise breakage' rather than 'prevent breakage' Mine barely survive being got off the shelf to the table. OpossumStrong, Starlight_Wolf, Inquisitor_Lensoven and 1 other 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/379674-flight-stand-protection/#findComment-5975563 Share on other sites More sharing options...
Orange Knight Posted July 27, 2023 Share Posted July 27, 2023 Foam trays and cases. KR are great. I've been able to transport everything safely. Flight stands, large models, etc. It does add up in cost, but I have always bought foam trays alongside any army expansion I do. Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/379674-flight-stand-protection/#findComment-5976064 Share on other sites More sharing options...
Grotsmasha Posted July 28, 2023 Share Posted July 28, 2023 Cotton wool. I've received 3D prints Internationally sent in nothing but cotton wool and they've been perfect. I'll be using the method if I ever need to send resin stuff in the post. Link to comment https://bolterandchainsword.com/topic/379674-flight-stand-protection/#findComment-5976426 Share on other sites More sharing options...
Valkyrion Posted July 28, 2023 Share Posted July 28, 2023 I won't buy any GW product that has one of those flight stands anymore. As a general PSA, when wrapping up minis for postage (ebay sale, for instance), individually wrapping each model in bubble wrap and sellotaping it shut will lead to more damages than having loose models and bubble wrap layered in a box like lasagna. Wrap up the expensive resin by all means, but pointy plastic gets caught in the bubble wrap and breaks as you try and cut it free from its bubbly tomb. Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/379674-flight-stand-protection/#findComment-5976442 Share on other sites More sharing options...
lhg033 Posted August 2, 2023 Share Posted August 2, 2023 The current GW cases are pretty good generally for packing most things but inceptors are a special case generally for how fragile they are on the stands. If you take a lot of care and give them plenty of room.... you're just as likely to break them off the stand in some other way. I got so fed up of mine breaking off the stand/re-gluing that I magnetized it instead. Works perfectly to separate the two and no issues with breaking any more. I just wish I'd done it earlier to actually recess the magnet on the marine then paint over. Link to comment https://bolterandchainsword.com/topic/379674-flight-stand-protection/#findComment-5978229 Share on other sites More sharing options...
