N1SB Posted July 27, 2023 Share Posted July 27, 2023 So with my 10 Necron Warriros, I've got those 3 Scarab Swarms. Are they worth keeping as a unit or should I use them for bases of converted miniatures please? Link to comment https://bolterandchainsword.com/topic/379690-scarab-swarms-useful-unit-or-just-neat-basing-material/ Share on other sites More sharing options...
Ahzek451 Posted July 27, 2023 Share Posted July 27, 2023 Unless you plan to buy more scarabs and expand beyond 3 models, I would consider basing. I did both, but to be fair I had a pile of scarabs. I don't get crazy with basing in general, but I found adding a scarab every once in awhile to certain models looks good. I made a point to sprinkle in a couple on my spyder bases. But then again....the way GW modeled scarabs makes it somewhat difficult to seperate them individually. I had to get super surgical and use green stuff to fill in certain parts. My 2 cents anyway. N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/379690-scarab-swarms-useful-unit-or-just-neat-basing-material/#findComment-5976089 Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted July 27, 2023 Share Posted July 27, 2023 With another three bases, they’re great. They can’t hold objectives without a Catacomb Command Barge buffing their OC, unfortunately, but they are fun little mortal wound bombs, if chaffier than they used to be. at three, though, they’re too small to be effective beyond small games. N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/379690-scarab-swarms-useful-unit-or-just-neat-basing-material/#findComment-5976297 Share on other sites More sharing options...
Dread Posted July 27, 2023 Share Posted July 27, 2023 Softened up a tank with my doom stalker the popped it with scarab unit. Tall about getting a can opener. They move really fast so reach in turn one usually not a problem. N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/379690-scarab-swarms-useful-unit-or-just-neat-basing-material/#findComment-5976352 Share on other sites More sharing options...
Lord_Ikka Posted July 28, 2023 Share Posted July 28, 2023 Most Necron players will wind up with a surplus of scarabs- every Warrior box comes with 3 and you usually want a couple of full 20-man bricks of Warriors to cover all gaming options, so getting 12 bases is going to happen. Right now scarabs aren't nearly as useful as they used to be in 9th because they can't hold objectives, but they are still good little annoyances to tie up the enemy every once in a while. Its hard to recommend using them as basing material unless you have a few already, as they are units that you can use in the game regardless of their utility. N1SB and Khulu 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379690-scarab-swarms-useful-unit-or-just-neat-basing-material/#findComment-5976400 Share on other sites More sharing options...
march10k Posted August 17, 2023 Share Posted August 17, 2023 I used them to bubble wrap DDAs in 9th, haven't played Necrons in 10th yet. N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/379690-scarab-swarms-useful-unit-or-just-neat-basing-material/#findComment-5981820 Share on other sites More sharing options...
