Inquisitor_Lensoven Posted July 31, 2023 Share Posted July 31, 2023 Should the be a codex alternative to lasrifles again? what does the auto in autorifle stand for? Automatic obviously, but does that refer to an automatic firing function, or an automatic loading function? is there space for an autorifle that has stats to represent rounds more potent than a standard intermediate cartridge like most combat rifles today fire? Link to comment https://bolterandchainsword.com/topic/379822-autorifles/ Share on other sites More sharing options...
Blindhamster Posted July 31, 2023 Share Posted July 31, 2023 how would you differentiate an autorifle from a lasrifle without treading on the basic boltgun? Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5977793 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 31, 2023 Author Share Posted July 31, 2023 On 7/31/2023 at 9:59 PM, Blindhamster said: how would you differentiate an autorifle from a lasrifle without treading on the basic boltgun? Expand I’d leave the stats identical like it was in the past, but as it is models with autoguns instead of lasguns (aside from sgts) could technically be disallowed from play at tournaments with strict WYSIWYG rules. but for a higher caliber battle rifle DMR type auto rifle, I’d probably do something like this automarksmen <heavy, precision> 30” A1 S3 AP-1 D2 Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5977806 Share on other sites More sharing options...
Blindhamster Posted July 31, 2023 Share Posted July 31, 2023 I dont see why any tournament wouldn't allow autoguns on the models from that perspective, seeing as the models only have rules for one type of gun anyway. I misunderstood the purpose of the thread and assumed you were talking about making a new weapon profile :) Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5977818 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 31, 2023 Author Share Posted July 31, 2023 On 7/31/2023 at 11:28 PM, Blindhamster said: I dont see why any tournament wouldn't allow autoguns on the models from that perspective, seeing as the models only have rules for one type of gun anyway. I misunderstood the purpose of the thread and assumed you were talking about making a new weapon profile :) Expand For the larger caliber autogun I was. my OP had like 3 or 4 topics to discuss. Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5977830 Share on other sites More sharing options...
Emperor Ming Posted July 31, 2023 Share Posted July 31, 2023 larger calibre, like the heavy stubber? Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5977835 Share on other sites More sharing options...
Inquisitor_Lensoven Posted August 1, 2023 Author Share Posted August 1, 2023 On 7/31/2023 at 11:54 PM, Emperor Ming said: larger calibre, like the heavy stubber? Expand No, like a full sized rifle cartridge instead of an intermediate cartridge. like .308 instead of .223 though I guess a heavy stubber could be roughly .308. I have always considered it more like a .50 though Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5977879 Share on other sites More sharing options...
TheArtilleryman Posted August 1, 2023 Share Posted August 1, 2023 (edited) I always struggle with what the difference is between an infantry autogun/autopistol and the comparable stubbers. In the lore the stubbers are supposed to be like the kind of firearms we have around today, but I’m not sure how autoguns differ from that. Autocannons vs heavy stubbers are a bit easier to differentiate, with the heavy stubber being a light machine gun and the autocannon being more heavy calibre like a flak weapon. If I was going to do a different profile to separate them from lasguns I’d probably give them a shorter range and make them assault weapons. Like Assault 2 18” S3 AP0 Edited August 1, 2023 by TheArtilleryman Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5977924 Share on other sites More sharing options...
Arikel Posted August 1, 2023 Share Posted August 1, 2023 Fairly certain that an autogun and a stubgun are just different names for the same thing. In nearly all cases ruleswise I have seen they are generally statted identically to lasguns or laspistols, with the exception of a few one off unique weapons, like the sergeant drum fed autgoun, or the preacher’s autostubber pistol. For regular infantry, you should be able to use pretty much any long gun/smg type weapon as a lasgun equivalent, as they are essentially the same in the rules. The exception would be shotguns, which do have a separate profile. In regards to the “heavy” battle rifle, maybe something intermediate between the heavy stubber and the lasgun/autogun profile. I would look at using the bolter or hotshot lasgun profile for it, there isn’t much wiggle room with 40k stats really. Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5978096 Share on other sites More sharing options...
Dr. Clock Posted August 1, 2023 Share Posted August 1, 2023 On 8/1/2023 at 5:47 PM, Arikel said: Fairly certain that an autogun and a stubgun are just different names for the same thing. Expand Necromunda differentiates stubbers from 'auto' by having auto weapons be 'truly automatic': rapid fire dice means they can get more hits than a stubber, but may also jam. Stub weapons are single shot S4 'revolver' weapons. Indeed, the heavy stubber is the only stub weapon to have rapid fire in Necro, whereas the 'basic weapon' stub equivalent is the Goliath Stub Cannon - essentially an oversized long barrel revolver with no stock. A shotgun is pretty close to 'mainstream long arm stubber' So an autogun is roundly akin to your AKs and M-16s, relying on bursts or full-auto rather than sheer calibre. Auto-pistol would be machine pistols and SMGs - emphasis on auto. So heavy stubbers basically are the 'parent' to two lines in 40k: one (stubbers) keeps the big S4 round but has low shots, the other sacrifices some range for more blistering close-range blasting. On guard squads as sidegrades I'd suggest 'Stub rifles' as Heavy 24", BS4 S4 AP0 D1. For autoguns maybe Assault 2 18" S3 AP0 D1? Cheers, The Good Doctor. DemonGSides 1 Back to top Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5978131 Share on other sites More sharing options...
Arikel Posted August 3, 2023 Share Posted August 3, 2023 @Dr. Clock Makes sense that they would have differences in skirmish games like Necromunda. When it comes to individual characters rather than squads you generally have more stats to work with to differentiate weapons. I like your suggestions for the sidegrades as well as they don’t overshadow the more elite bolter. Maybe raise the bs on the stub rifle to 5 so it only hits on 4’s if you have time to aim by standing still? As a secondary ability, maybe give it rapid fire (0), so that if firing in an organized volley ordered by an officer using FRFSRF they get 2 shots instead of just one. As an aside, I always found it a bit silly that many SF games find the need to give basic firearms a special name like Stub Gun for a revolver. In the Star Wars rpg they call them Slug Throwers as an alternate example. Just sounds awkward most of the time when perfectly serviceable current terminology is available. Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5978598 Share on other sites More sharing options...
Inquisitor_Lensoven Posted August 3, 2023 Author Share Posted August 3, 2023 On 8/3/2023 at 4:31 AM, Arikel said: @Dr. Clock Makes sense that they would have differences in skirmish games like Necromunda. When it comes to individual characters rather than squads you generally have more stats to work with to differentiate weapons. I like your suggestions for the sidegrades as well as they don’t overshadow the more elite bolter. Maybe raise the bs on the stub rifle to 5 so it only hits on 4’s if you have time to aim by standing still? As a secondary ability, maybe give it rapid fire (0), so that if firing in an organized volley ordered by an officer using FRFSRF they get 2 shots instead of just one. As an aside, I always found it a bit silly that many SF games find the need to give basic firearms a special name like Stub Gun for a revolver. In the Star Wars rpg they call them Slug Throwers as an alternate example. Just sounds awkward most of the time when perfectly serviceable current terminology is available. Expand Sure there’s currently perfectly serviceable terminology, but when you’v incorporated hundreds let alone millions of other planets and tens of thousands of years like you have in 40K, terminology changes. in 500 years archeologists and anthropologists will look back and likely be curious as to what exactly an assault rifle or assault weapon meant to the people of our time frame, because while they likely will still exist then they’ll probably have a different term for it. Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5978724 Share on other sites More sharing options...
Harrowmaster Posted August 3, 2023 Share Posted August 3, 2023 In terms of modern 40k I don't think there is room for there to be differing ammo profiles, it seems the way GW has gone with the game they're cutting back on things like that (sternguard vets lost special ammo in 8th). I don't see different ammo types for a rifle for guardsmen fitting into the current game design. As for profiles, the Imperial Militia list has both the autogun and the lasgun as 24" STR 3 AP- Rapid Fire, this has been the traditional approach to the autogun in 40k and 30k, it having a separate but identical profile doesn't seem to fit with current 40k. As an aside the laspistol in 30k is 12" STR 3 AP- Pistol 1, while the autopistol is 9" STR 3 AP- Pistol 2 which is a nice distinction. Link to comment https://bolterandchainsword.com/topic/379822-autorifles/#findComment-5978834 Share on other sites More sharing options...
