How to recreate the original scale of the Abomination Class from space crusade
NOTE: This is not my scaled-up version, this is just for fans wanting to use the old model.
Leviathan Dreadnought
Weapons:
Two Heavy Bolters
Any of the following (pick 4, repeats allowed)
Assault cannon
Conversion beam cannon
Multi-melta
Missile launcher
That'll do fine honestly, for balance purposes at least.
Edited by 40k_fan
It's almost verging into knight sized there no? Do you have any images of the original next to a marine, then a leviathan next to a modern marine to scale it right? Or are you intentionally going for massive?
Arguably the Leviathan is almost knight sized itself, I am just going for bigger knight size.
The original Malevolence/Abomination class wasn't much bigger than a regular Mortis dreadnought, but slightly taller, this is just my redesign of it to make it larger.
the Leviathan is about the same size as an Armiger knight, so this Abomination design is meant to be about the same size as a Questoris or Dominus, but probably smaller than the Cerastus.
  • 1 month later...
On 8/6/2023 at 9:10 PM, 40k_fan said:
Some art of my Abomination dreadnought redesign in scale comparison to the Leviathan Dreadnought.
Bigger is cooler.
I still have all three Space Crusade Dreadnoughts. Built two of them in the standard way and the third with long legs and four arms. There was an article in 3rd 40K to build any kind of custom vehicles.
Can you link the article or stats? I really want to see that now lol. Sounds really cool.
  • 2 weeks later...
  • 2 weeks later...
[ - Recreating Old Dreadnoughts - ]
Base: Deredeo-class Dreadnought
Melee: Armored Feet
Lower Weapon Mount: twin heavy bolters, twin multi-meltas, or twin heavy flamers
Upper Weapon Mounts: assault cannon, conversion beam cannon, grav-cannon, lascannon, multi-melta, plasma cannon, missile launcher
Marauder and Abomination Only: +2" Move
Example Stats:
Malevolence-Class Dreadnought
Move 8" | Toughness 9 | Save 2+ | 12 Wounds | Leadership 6+ | OC 4
1 Assault Cannon; 1 Conversion Beam Cannon; Twin Heavy Bolter; Armored Feet
Multi-Melta
2 Shots | Range 18" | Ballistic Skill 3+ | Strength 9 | AP -4 | Damage D6 | Melta 2
1 Shot | Range 24" | Ballistic Skill 3+ | Strength 7 | AP -1 | Damage 3 | Conversion, Sustained Hits D3
Twin Heavy Bolter
3 Shots | Range 36" | Ballistic Skill 3+ | Strength 5 | AP -1 | Damage 2 | Sustained Hits 1, Twin-Linked
Armored Feet
4 Attacks | Strength 6 | AP 0 | Damage 1
Deadly Demise (D3)
Oath of Moment
Damaged (1-4 Wounds Remaining)
Targeter Optics
Each time this unit Remains Stationary, until the start of your next Movement phase, ranged weapons equipped by models in this unit have the [IGNORES COVER] and [LETHAL WOUNDS] abilities.
Edited by 40k_fan
Register a new account
Sign in
