march10k Posted August 10, 2023 Share Posted August 10, 2023 My question is about disembarking vs withdrawing. It's clear from the rules that you may not disembark after your transport withdraws. But what about before? Can you get out and then have the transport back up? It reads to me that that would be allowed, but then it makes me wonder why you can disembark before, but not after, the transport withdraws. Link to comment https://bolterandchainsword.com/topic/379944-rules-question-movement-phase/ Share on other sites More sharing options...
TrawlingCleaner Posted August 10, 2023 Share Posted August 10, 2023 =][= I've shifted this over to Official Rules as it's a better fit here =][= Link to comment https://bolterandchainsword.com/topic/379944-rules-question-movement-phase/#findComment-5980298 Share on other sites More sharing options...
Kallas Posted August 10, 2023 Share Posted August 10, 2023 (edited) 26 minutes ago, march10k said: Can you get out and then have the transport back up? Yes, the rules have no restriction on this. As you noted, the only restrictions on disembarkation are for when a transport model has already Advanced or Fallen Back. Edit: To add a little more specificity, the rules specifically say that you can disembark from a model that "has not yet made a [...] Fall Back move this phase". So yes, you are 100% allowed to dismbark before a transport Falls Back. Spoiler 26 minutes ago, march10k said: it makes me wonder why you can disembark before, but not after, the transport withdraws. Eh, trying to divine GW's rules intentions is a path fraught with insanity Edited August 10, 2023 by Kallas Added specifics Dr_Ruminahui and Karhedron 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379944-rules-question-movement-phase/#findComment-5980306 Share on other sites More sharing options...
DemonGSides Posted August 10, 2023 Share Posted August 10, 2023 Because a Fall Back move, for most situations, is supposed to show the inherent danger of trying to leave combat with a unit. In the past this involved sweeping advances, which was often a death sentence for the falling back unit. Now, you just don't get to do other things. Most times falling back the penalty is that's the entirety of that unit's "Turn", which is an abstract of "It's not exactly easy to disengage a bunch of 9 Foot Genetic Freaks mobbing your car." Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/379944-rules-question-movement-phase/#findComment-5980371 Share on other sites More sharing options...
Rogue Posted August 10, 2023 Share Posted August 10, 2023 Notice also that the disembarking unit must still set up wholly within 3" of the transport, and not within 1" of enemy units. So if the enemy are partially wrapping the transport, and you have a big squad in there, they may not be able to disembark at all. Xenith and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379944-rules-question-movement-phase/#findComment-5980393 Share on other sites More sharing options...
blacksnapt Posted August 16, 2023 Share Posted August 16, 2023 So if a transport is in combat, the unit inside can still disembark aslong as the disembarking unit does not end in engagement range??? Link to comment https://bolterandchainsword.com/topic/379944-rules-question-movement-phase/#findComment-5981471 Share on other sites More sharing options...
Dr_Ruminahui Posted August 16, 2023 Share Posted August 16, 2023 Yup - that's the scenario as described by the OP, just without the vehicle then withdrawing. Link to comment https://bolterandchainsword.com/topic/379944-rules-question-movement-phase/#findComment-5981486 Share on other sites More sharing options...
