Helias_Tancred Posted August 12, 2023 Share Posted August 12, 2023 poorly performing and unpleasant. So what is a better brush to use in basing miniatures? I'm inquiring for basing marines. Thanks. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/ Share on other sites More sharing options...
Solution andes Posted August 12, 2023 Solution Share Posted August 12, 2023 I use el cheapo synthetics I get from Amazon by the bag, that way if they get ruined by basing compound, glue, washes, etc. I just chuck 'em out and grab a fresh one. Emperor Ming, Knightsword, ZeroWolf and 2 others 1 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5980775 Share on other sites More sharing options...
ZeroWolf Posted August 13, 2023 Share Posted August 13, 2023 36 minutes ago, andes said: I use el cheapo synthetics I get from Amazon by the bag, that way if they get ruined by basing compound, glue, washes, etc. I just chuck 'em out and grab a fresh one. This is what I do as well, and honestly, they can survive a lot of punishment. andes and Helias_Tancred 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5980780 Share on other sites More sharing options...
carnosaur93 Posted August 16, 2023 Share Posted August 16, 2023 (edited) i think the "base brush" is for basecoating, not scooping paste onto bases, they even sell a little spatula for that purpose... never use a brush like a spoon. I personally just use wooden coffee stirrers as a spatula for base-paste, i've used the same one for a whole army's worth of models at this point, so they go a long way, and are generally free to find a handful of... and if you need a pointier shape for finer control, just cut one end into a point Edited August 16, 2023 by carnosaur93 Mithrilforge, Ramell, Firedrake Cordova and 3 others 2 4 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981448 Share on other sites More sharing options...
Xenith Posted August 16, 2023 Share Posted August 16, 2023 The small brushes I don't rate, however their large base brush with the wedge was amazing https://www.games-workshop.com/en-GB/L-Base-Brush Though it seems to be discontinued?! I use this broad brush with a point for 90% of my painting now - great coverage and the sharp wedge end to get into crevices and such. Things go fast! https://travellingman.com/products/wargamer-brush-large-drybrush? Detail work I do with a W&N series 7 size 0 or 00 brush, old reliables. Adendum: I know it says it's a drybrush, but the bristles are really smooth and paint flows beautifully from it, I use it for contrast work, and then paintng flat armour panels like on marines. Really flexible. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981472 Share on other sites More sharing options...
Firedrake Cordova Posted August 16, 2023 Share Posted August 16, 2023 I'm wondering if the old Base brushes are being replaced with the STC Base brushes, as both are 100% synthetic fibres? Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981506 Share on other sites More sharing options...
Grotsmasha Posted August 16, 2023 Share Posted August 16, 2023 Base, as in Texture paints? I use GWs texture spreader and it works just fine. There's even 3d files out there to print your own, but, the Base Brush is for base layer paints, nott textures. Mithrilforge and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981524 Share on other sites More sharing options...
andes Posted August 16, 2023 Share Posted August 16, 2023 (edited) Coffee stirrers, etc. are great for getting the basing compound from the pot onto the base but a damp/wet junk brush is by far my favorite way of smooshing the stuff into nooks and crannies without me encrusting the mini up to the waist (and useful for 'washing' off bits that do make their way too far north). Edited August 16, 2023 by andes Mithrilforge and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981561 Share on other sites More sharing options...
Guest Posted August 16, 2023 Share Posted August 16, 2023 Sold to the audience they are intended for... But overall hit and miss like most companies. I picked up a pack of 5 brushes on Amazon for £2.95, Not spectacular, but work for metallics which saves my Ro&C ones. Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981574 Share on other sites More sharing options...
WrathOfTheLion Posted August 16, 2023 Share Posted August 16, 2023 For basecoating models, a lot of times I use the shade brush, as I prefer something with a decent body. For basing, I have one of the texture spreaders from back when they had the sculpting tools set, and I've just used that for a long time. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981590 Share on other sites More sharing options...
Urauloth Posted August 16, 2023 Share Posted August 16, 2023 I think the shade brush is the best thing GW sell for basecoating. It's probably my fav brush they do, it's very versatile. Any similar brush from an art store will work fine - bigger tends to be better, as you want a lot of body, like WrathOfTheLion says. (Also, there's a very limited number of brush manufacturers in the world, so when you buy similar brushes from different brands there's a non-zero chance you're actually buying the same product with a different handle anyway. I'm not sure who makes the current GW line, but they're not exclusive.) Firedrake Cordova and Helias_Tancred 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981614 Share on other sites More sharing options...
Firedrake Cordova Posted August 16, 2023 Share Posted August 16, 2023 1 hour ago, Urauloth said: I'm not sure who makes the current GW line, but they're not exclusive Apparently, it's Crown Artist Brush for the main line (and has been forever), and Winsor & Newton Series 7's for the Artificer series (according to ex-GW Tom Hibberd). Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981632 Share on other sites More sharing options...
Helias_Tancred Posted August 17, 2023 Author Share Posted August 17, 2023 To clarify I meant to primer a model and to add the base color. Not having to do with using texture paints on the model's base. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981693 Share on other sites More sharing options...
Grotsmasha Posted August 17, 2023 Share Posted August 17, 2023 42 minutes ago, Eilio Tiberius said: To clarify I meant to primer a model and to add the base color. Not having to do with using texture paints on the model's base. I like using the Shade brush for that Firedrake Cordova and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981696 Share on other sites More sharing options...
Firedrake Cordova Posted August 17, 2023 Share Posted August 17, 2023 I'll add another vote for the GW Shade brush being quite good. I also like the Rosemary & Co Series 99's (sable), and Winsor & Newton Cotman Series 101 (synthetic). If you've got a local art supply shop, you could try having a look for some artist's watercolour brushes of a reasonable size. Or, as @andes said, you could get a bag of cheap ones from Amazon. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5981698 Share on other sites More sharing options...
Mithrilforge Posted August 22, 2023 Share Posted August 22, 2023 I use Ammo by Mig Jimeniz brushes for base coating, cheap enough but better than normal quality and I found keep a point well even though I base coat with them. https://www.migjimenez.com/en/tools-brushes/1715-starter-brush-set.html Cheers, M. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5982613 Share on other sites More sharing options...
Orion Posted August 22, 2023 Share Posted August 22, 2023 Citadel Shade brush is probably my most used brush. Firedrake Cordova, Grotsmasha, andes and 2 others 2 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5982622 Share on other sites More sharing options...
lhg033 Posted August 22, 2023 Share Posted August 22, 2023 +1 for the citadel shade brush. It's a pretty good workhorse though I mainly use it for contrasts and/or base layer below these it's fairly chonky so holds a decent amount of paint for base layers without to much back and forward but still has a decent point on it when needed too... normally (looking at @JayJapanB's above and reconsidering this) I've got through about 2-3 of these in a few years but keep coming back to them. I do still use ye olde faithful too - the 'standard' brush. I've got a good few of these in various states going back 20+ years. I dont think I've ever bought one separately so they must have come from sets or magazines. After that - I have a selection of W&N's if I need any real precision Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5982669 Share on other sites More sharing options...
Mithrilforge Posted August 24, 2023 Share Posted August 24, 2023 On 8/22/2023 at 4:43 PM, JayJapanB said: Citadel Shade brush is probably my most used brush. So.... do you do eyes with your fav Brush ... that looks like a Mixing brush to me... please tell me you don't seriously use that to paint with?!?... M. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/379962-citadel-base-brushes-are/#findComment-5983023 Share on other sites More sharing options...
