dicebod Posted August 15, 2023 Share Posted August 15, 2023 File this under "I've had this question for so long at this point I'm afraid to ask..." I have a unit of three rapier laser destroyers with six total crew. How do I take casualties on that unit? Do I kill the crew then the battery? Could I kill three of the crewmembers before losing the ability to shoot with all three of the batteries? Link to comment https://bolterandchainsword.com/topic/379988-how-do-i-take-casualties-on-rapier-batteries/ Share on other sites More sharing options...
Gorgoff Posted August 16, 2023 Share Posted August 16, 2023 14 hours ago, dicebod said: File this under "I've had this question for so long at this point I'm afraid to ask..." I have a unit of three rapier laser destroyers with six total crew. How do I take casualties on that unit? Do I kill the crew then the battery? Could I kill three of the crewmembers before losing the ability to shoot with all three of the batteries? You apply wounds as you like. Link to comment https://bolterandchainsword.com/topic/379988-how-do-i-take-casualties-on-rapier-batteries/#findComment-5981490 Share on other sites More sharing options...
apologist Posted August 16, 2023 Share Posted August 16, 2023 (edited) This is a bit of an edge case – but while it might be a bit unclear using the core rules, the card helps clear it up. In short, you allocate all successfully wounding attacks to one Rapier model until it is destroyed. In your example above, you couldn't remove 'spare' crew members leaving all guns functional. The crew are, in effect, simply wound tokens for the relevant Rapier. Ah, derp – just realised this was posted in the Horus Heresy section, so assume that you meant for Ago of Darkness rules, right? Sorry, clicked through from the front page. I've spoilered my initial answer (for 10th edition 40k). In AoD, I believe as @Gorgoff says, you can apply the wounds as you like – so yes, you can kill off three crew members while still leaving three functional guns. Edited August 16, 2023 by apologist Gorgoff and StratoKhan 2 Back to top Link to comment https://bolterandchainsword.com/topic/379988-how-do-i-take-casualties-on-rapier-batteries/#findComment-5981546 Share on other sites More sharing options...
Gorgoff Posted August 16, 2023 Share Posted August 16, 2023 56 minutes ago, apologist said: Reveal hidden contents This is a bit of an edge case – but while it might be a bit unclear using the core rules, the card helps clear it up. In short, you allocate all successfully wounding attacks to one Rapier model until it is destroyed. In your example above, you couldn't remove 'spare' crew members leaving all guns functional. The crew are, in effect, simply wound tokens for the relevant Rapier. Ah, derp – just realised this was posted in the Horus Heresy section, so assume that you meant for Ago of Darkness rules, right? Sorry, clicked through from the front page. I've spoilered my initial answer (for 10th edition 40k). In AoD, I believe as @Gorgoff says, you can apply the wounds as you like – so yes, you can kill off three crew members while still leaving three functional guns. You were right in one thing though: if you apply one wound to a rapier you have to keep doing so unless it is dead. apologist 1 Back to top Link to comment https://bolterandchainsword.com/topic/379988-how-do-i-take-casualties-on-rapier-batteries/#findComment-5981554 Share on other sites More sharing options...
dicebod Posted August 16, 2023 Author Share Posted August 16, 2023 So I guess the "ideal" way to do this would be: First three wounds the unit takes = kill three crewmembers. This leaves you with three crewmembers and three batteries, along with the ability to continue shooting with all three, in addition to making the unit T5 vs. shooting attacks since there are an equal number of T5 and T4 models. Next wound would kill a crewmember, leaving you with the ability to only shoot with two batteries. The next two wounds you take after that would go on to the battery itself (since @Gorgoff notes above you have to keep taking wounds on a multiwound model once you've started allocating wounds to it). From there, you would follow this pattern until the unit is destroyed. Link to comment https://bolterandchainsword.com/topic/379988-how-do-i-take-casualties-on-rapier-batteries/#findComment-5981572 Share on other sites More sharing options...
SkimaskMohawk Posted August 16, 2023 Share Posted August 16, 2023 1 hour ago, dicebod said: So I guess the "ideal" way to do this would be: First three wounds the unit takes = kill three crewmembers. This leaves you with three crewmembers and three batteries, along with the ability to continue shooting with all three, in addition to making the unit T5 vs. shooting attacks since there are an equal number of T5 and T4 models. Next wound would kill a crewmember, leaving you with the ability to only shoot with two batteries. The next two wounds you take after that would go on to the battery itself (since @Gorgoff notes above you have to keep taking wounds on a multiwound model once you've started allocating wounds to it). From there, you would follow this pattern until the unit is destroyed. Thats exactly the best way to do it. Just watch out for leadership tests, especially during night. Gorgoff 1 Back to top Link to comment https://bolterandchainsword.com/topic/379988-how-do-i-take-casualties-on-rapier-batteries/#findComment-5981619 Share on other sites More sharing options...
Gorgoff Posted August 17, 2023 Share Posted August 17, 2023 Because apparently Astartes are afraid of the night in 2ed. Link to comment https://bolterandchainsword.com/topic/379988-how-do-i-take-casualties-on-rapier-batteries/#findComment-5981681 Share on other sites More sharing options...
TheTrans Posted August 17, 2023 Share Posted August 17, 2023 22 hours ago, Gorgoff said: Because apparently Astartes are afraid of the night in 2ed. And can't see very well in it with their multi-spectrum occular sensoria in their helmets, let alone their 'naturally' amazing transhuman eye sight. Gorgoff 1 Back to top Link to comment https://bolterandchainsword.com/topic/379988-how-do-i-take-casualties-on-rapier-batteries/#findComment-5981886 Share on other sites More sharing options...
Gorgoff Posted August 18, 2023 Share Posted August 18, 2023 3 hours ago, TheTrans said: And can't see very well in it with their multi-spectrum occular sensoria in their helmets, let alone their 'naturally' amazing transhuman eye sight. Or at least not better than the militia hoomies. Gaming wise it is a nice rule but the image from a squad of bioengineered transhumans huddling arount their Vox operator is just too funny. "Co....command? Are you still there? It is so spooky arount here!" Link to comment https://bolterandchainsword.com/topic/379988-how-do-i-take-casualties-on-rapier-batteries/#findComment-5981900 Share on other sites More sharing options...
