Inspired by the topic started by Lysimachus in the Astartes main hall, I figured I'd get the conversation going here. With our Codex due early next year, working out what Detachments we may get now could be a fun exercise.
Assuming we too get 6 Detachments, including our current Unforgiven Taskforce, I theorise the following:
  1. Unforgiven Taskforce - The catch all detachment for a mixed-wing force
  2. Deathwing Strikeforce - Self explanatory. Terminators, Dreadnoughts, Land Raiders and Repulsors. Bladeguard likely, Sternguard uncertain.
  3. Ravenwing Strikeforce - Second verse same as the first. Outriders, ATVs, Stormspeeders and Flyers.
  4. The Risen - Focusing on Primaris Veterans (Bladeguard and Sternguard) as "counts-as" Risen.
  5. Lionguard - Detachment focused around the Lion. Bladeguard/Deathwing Knights
I cannot, however, work out a 6th detachment unless I start borrowing from the Space Marine Codex and from my understanding we will not be a supplement but a standalone detachment this time.
How about my fellow denizens of the Rock? Think I guessed correctly? Far from it? What are your ideas?
"Lion: You Didn't Need to Slay Asmodai"
"Luther's Losers"
"Ezekiel's New Eye Psychic Strike Force"
I submit the above mentioned for the 6th detachment when our codex and other stuff goes live!
Sounds about right, though Risen and Lionguard could be combined. The one I think you're missing is the combined Deathwing and Ravenwing "Time to bring down the hammer" detachment.
Yeah, Combi-Wing is the whole reason I have any DA.   Of course I'm probably in the minority here - in that I have Ultras for my "Green Wing" play style, and only use DA for the Divergent style which was more or less duplicated by the Custodes - and I didn't switch.
Also I'd question if everyone else is going to get a half dozen detachments.
  • 1 month later...
12 minutes ago, Dracos said:
If DA no longer access the SM Codex and truly have only their own then six detachments make sense.
... and I don't think thats going to be the case. I see us keeping our current one and getting one for the Deathwing, and one for the Ravenwing.
I wonder if we will only get 3, since we have the Space Marine Ones as well. I imagine Deathwing, Raven Wing, Green Wing themed detachments, and if it's a deathwing refresh as rumored, probably the desthwing one will be by far the best.
Greenwing is the least likely, or from another perspective already covered by Unforgiven detachment. Deathwing+Ravenwing combined arms or one for each are, I think, the most likely. We may only get Unforgiven and one more detachment because Dark Angels have so many unique units which can be used to put a Dark Angel twist on otherwise Codex-detachments.
If GW stick to the one codex needed and Dark Angels is not a supplement, then it wouldn't surprise me if it was a copy of the Space Marine Codex just with none Dark Angel units/characters removed, then the Dark Angel Characters/Units added. Also all none Dark Angel Lore/Fluff/painting removed and replaced with its Dark Angel equivalent :woot:
Edit: Forgot to say that it would also get the Dark Angels detachment.
Edited by Vardus
See above.
Register a new account
Sign in
