Agramar_The_Luna_Wolf Posted September 8, 2023 Share Posted September 8, 2023 Hello! I'm looking for tutorials,ideas, counsels,.. about how to convert space marine backpacks. Specially, ways to make a Mk III "ferrum" from other models. Thanks! Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/380181-convert-space-marine-backpacks/ Share on other sites More sharing options...
Grotsmasha Posted September 9, 2023 Share Posted September 9, 2023 There was a GREAT thread by Gwain Veteris that I usually recommend for these types of questions, BUT, sadly all the images no longer work. But basically it's all Greenstuff work. Were you specifically looking to convert, or you just want the power packs? I ask because 3D printing would be a significantly easier option. Agramar_The_Luna_Wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/380181-convert-space-marine-backpacks/#findComment-5987449 Share on other sites More sharing options...
Nexus17 Posted September 9, 2023 Share Posted September 9, 2023 Sus.an.membrane on Instagram has built something similar, including comments around how they made the vents (small brass compression fittings). There are several similar posts but this one looked useful at first glance. Agramar_The_Luna_Wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/380181-convert-space-marine-backpacks/#findComment-5987489 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted September 9, 2023 Author Share Posted September 9, 2023 20 hours ago, Grotsmasha said: There was a GREAT thread by Gwain Veteris that I usually recommend for these types of questions, BUT, sadly all the images no longer work. But basically it's all Greenstuff work. Were you specifically looking to convert, or you just want the power packs? I ask because 3D printing would be a significantly easier option. I'm looking to convert. Just to give some use to other backpacks I have, like CSM models. Link to comment https://bolterandchainsword.com/topic/380181-convert-space-marine-backpacks/#findComment-5987623 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted September 9, 2023 Author Share Posted September 9, 2023 (edited) 13 hours ago, Nexus17 said: Sus.an.membrane on Instagram has built something similar, including comments around how they made the vents (small brass compression fittings). There are several similar posts but this one looked useful at first glance. What kind of metal pieces is using? Brass olives?? Awesome Edited September 9, 2023 by AGRAMAR Link to comment https://bolterandchainsword.com/topic/380181-convert-space-marine-backpacks/#findComment-5987625 Share on other sites More sharing options...
Nexus17 Posted September 10, 2023 Share Posted September 10, 2023 22 hours ago, AGRAMAR said: What kind of metal pieces is using? Brass olives?? Awesome I suspect it's this kind of thing. Various sizes are available so short of contacting the OP on Instagram, you're probably down to doing a bit of suck-it-and-see buying and experimentation with parts in hand. Agramar_The_Luna_Wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/380181-convert-space-marine-backpacks/#findComment-5987844 Share on other sites More sharing options...
