Dark_Vengeant Posted October 3, 2023 Share Posted October 3, 2023 (edited) As I mentioned in other posts, I recently returned to the Hobby, and alot has changed. I have toyed around with starting a new Catachan army but since the models are all old web order models, the basing rules have changed. For instance the characters come with small bases and nowadays it seems all characters use at least 40mm. After a google search, the resources out there seem to conflict with each other due to several editions of the game. For instance: Blasted Horizons: Guide to 40k bases (en-blastedhorizons.blogspot.com) Basing Guidelines for Warhammer 40,000 - Articles - DakkaDakka | Please don't feed the trolls! One site says Heavy weapons teams use 60mm while the other says 50mm. I need help with verifying base size for the following: Catachan Jungle Fighters (troops) - Guessing 25 mm? Heavy Weapons Teams - * EDIT * Looks like the ones I just ordered come on 60mm so they match the Cadians now. Command squad - Are these different than troops? Blasted Horizons says they should be since Cadian Command squad uses 28mm. Iron Hand Straken - Sly Marbo - Sgt Harker - Edited October 3, 2023 by Dark_Vengeant Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/ Share on other sites More sharing options...
Solution Trokair Posted October 3, 2023 Solution Share Posted October 3, 2023 Games Workshop website normally states the base size a kit comes with. So I personally would use that as a starting point, then for older models/kits I would look at modern equivalent. So looking at your list: Catachan Jungle Fighters (troops) – They do come with 25mm and as the new Cadian Shock troop come on 25mm as well I would guess any future update for Catachan would have the infantry remain on 25mm Command squad – in the old days they would have been the same as infantry, but judging by the Cadian Command squad they would now use 28mm. Heavy Weapons Teams – the plastic kit officially come on 50mm, though I think the metal Steel Legion Made to Order a while back had heavy bolter and lascannon teams on 60mm (and missile launcher on two 25mm) Iron Hand Straken and Sgt Harker – the old ones come on 25mm but I would say 28mm is probably better from them, the new plastic commissar and castellan are on 28mm Sly Marbo – the current plastic kit comes on a 32mm Dark_Vengeant 1 Back to top Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5992804 Share on other sites More sharing options...
Emperor Ming Posted October 3, 2023 Share Posted October 3, 2023 You can pick up base extenders up on eBay I recently bought some to update my eldar to 28.5mm from 25mm Trokair 1 Back to top Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5992806 Share on other sites More sharing options...
Dark_Vengeant Posted October 3, 2023 Author Share Posted October 3, 2023 (edited) 19 minutes ago, Emperor Ming said: You can pick up base extenders up on eBay I recently bought some to update my eldar to 28.5mm from 25mm That's a neat idea, I didn't know those were available. I am starting fresh so I will likely just buy the bases I need. On another note the 3 boxes of Heavy Wpns teams I just bought are in fact on 60mm base so no need to change them. I intend to kitbash a whole bunch of mortar and missile launcher teams with the remaining bits so I will have to buy more bases for this as well. Edited October 3, 2023 by Dark_Vengeant Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5992808 Share on other sites More sharing options...
Dr_Ruminahui Posted October 3, 2023 Share Posted October 3, 2023 (edited) The kitbashing works well, and you provided you do the following you can get all of the the following heavy weapons out of one kit except for having to choose between the lascannon/autocannon. 1. For the missile launcher, use standing models and don't use the bipod for the launcher. 2. For the mortar, use standing models. 3. For the heavy bolter, prop it up on sandbags or a log or some other bit of low lieing terrain, then use standing guys lieing prone. 4. You only get 1 tripod, so build it normally with either the lascannon or the autocannon. If you make the loader standing, you can use the kneeling guy with one of the other weapons. 5. You could probably could use the second weapon from step #4 if you mounted it on a low wall or on the ground like the heavy bolter. You might need to get extra gun handles/arms for the heavy weapon from a vehicle kit, though. I did this for my cadians, but don't really have any photos, but I can take some if you want. Edited October 3, 2023 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5992852 Share on other sites More sharing options...
jarms48 Posted October 4, 2023 Share Posted October 4, 2023 I don't see the need to rebase them. I doubt many would kick up a fuss. They're still genuine models. Mana 1 Back to top Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5992906 Share on other sites More sharing options...
Emperor Ming Posted October 4, 2023 Share Posted October 4, 2023 I would suggest rebasing the heavy weapons teams, I did mine and 50mm is way better than 60 SteveAntilles 1 Back to top Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5992918 Share on other sites More sharing options...
duz_ Posted October 6, 2023 Share Posted October 6, 2023 On 10/4/2023 at 3:53 AM, Emperor Ming said: I would suggest rebasing the heavy weapons teams, I did mine and 50mm is way better than 60 Really? How so? The 50s seem too cramped? Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5993337 Share on other sites More sharing options...
SteveAntilles Posted October 6, 2023 Share Posted October 6, 2023 I just rebased my HW teams, they look so much better on the 50mm bases, and they're easier to put into cover and move around. CyderPirate, duz_ and Emperor Ming 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5993338 Share on other sites More sharing options...
duz_ Posted October 6, 2023 Share Posted October 6, 2023 Hard to argue with someone who's already rebased their Mordians I was worried the old metals might not fit as well... I may have been wrong Now I have many nice and expensive 60mm bases I have no use for Emperor Ming and SteveAntilles 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5993340 Share on other sites More sharing options...
Emperor Ming Posted October 6, 2023 Share Posted October 6, 2023 4 hours ago, duz_ said: Really? How so? The 50s seem too cramped? As others have said, they look better, easier to hide, its just better all round really I've always disliked the 60s, always created issues, there was always lots of unused space on the 60mm as well. I could go on.. Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5993366 Share on other sites More sharing options...
FashaTheDog Posted October 12, 2023 Share Posted October 12, 2023 On 10/3/2023 at 1:25 PM, Trokair said: Sly Marbo – the current plastic kit comes on a 32mm I thought that kit comes fully assembled, painted to the highest of standards, and occupies whatever base size, also done to the highest standards, that Marbo wants in any given phase. Also, you do not get to disagree as he is right behind you, but if you turn around you still will not see him. Dark_Vengeant 1 Back to top Link to comment https://bolterandchainsword.com/topic/380745-old-astra-militarum-basing-woes/#findComment-5994513 Share on other sites More sharing options...
