firestorm40k Posted October 7, 2023 Share Posted October 7, 2023 Greetings Frater As I subscribed to Imperium Magazine, I have a number of Ad Mech units that I plan to use as a Boarding Patrol; I added another box of Skitarii and Sicarians (which I'll run as Ruststalkers), which at the time gave me a 500 point list (or thereabouts). Following recent points updates, I've got points spare to add either another unit of Skitarii, or Sicarians. Which would the seasoned Cohort Marshals and Tech Adepts of the B&C recommend I take? Or should I hang on and see what happens to the points when their Codex is released..? If it helps, I've got the following: - 2x Skitarii - Destroyers - Sicarians - Marshal - Engineseer Thanks for any advice! Link to comment https://bolterandchainsword.com/topic/380765-finishing-a-boarding-patrol-skitarii-or-sicarians/ Share on other sites More sharing options...
Bouargh Posted October 7, 2023 Share Posted October 7, 2023 What flavours are your Skitarii? Rangers, Vanguards, both? I, personnaly, do not like how Sicarians look. But I can see their usefulness. I do rather infiltrators however... I never had great results with dusters, but maybe, surely, I am using them in an under optimized way... firestorm40k 1 Back to top Link to comment https://bolterandchainsword.com/topic/380765-finishing-a-boarding-patrol-skitarii-or-sicarians/#findComment-5993426 Share on other sites More sharing options...
firestorm40k Posted October 7, 2023 Author Share Posted October 7, 2023 22 minutes ago, Bouargh said: What flavours are your Skitarii? Rangers, Vanguards, both? Going for all Vanguard, for reasons I can't remember at the moment I don't have enough points for Rangers. Unless I swap one of the other Vanguard for Rangers, then I'd have to go for more Sicarians to keep within 500 points. Having not played with Ad Mech before, I honestly don't know whether Vanguard or Rangers are better! Link to comment https://bolterandchainsword.com/topic/380765-finishing-a-boarding-patrol-skitarii-or-sicarians/#findComment-5993427 Share on other sites More sharing options...
Bouargh Posted October 7, 2023 Share Posted October 7, 2023 In a boarding game, ranger will probably not bring anything vs. Vanguards. They may even be worse. In open field they swap short range to long range fire. They are also a unit done to go forward while rangers are better as supporting and annoying ennemies around objectives. Rangers go firward while vaguard secure the gains... My own views... Being in a config like yours, well, go sicarians. They will balance your army and be your objective grabbers and holders. firestorm40k, Dr. Clock and walter h 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/380765-finishing-a-boarding-patrol-skitarii-or-sicarians/#findComment-5993437 Share on other sites More sharing options...
