Commander Nicky Posted October 17, 2023 Share Posted October 17, 2023 Which points values should you use when building your SM army? I notes there are significant differences between vaules in the new codex and the Munitorium field manual release a couple of weeks ago. Has there like been a communication from GW? Also, as I read it, is it possible to split a tacitcal squad into two unit and have each of them being bodyguard to two different leaders? I read it as such... Link to comment https://bolterandchainsword.com/topic/380865-space-marine-points-and-2-leaders-in-a-tactical-squad/ Share on other sites More sharing options...
Karhedron Posted October 17, 2023 Share Posted October 17, 2023 The latest and correct points are in version 1.4 of the MFM. Commander Nicky and Emperor Ming 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/380865-space-marine-points-and-2-leaders-in-a-tactical-squad/#findComment-5995862 Share on other sites More sharing options...
BluejayJunior Posted October 17, 2023 Share Posted October 17, 2023 The QR code in the codex directs you to the correct points to use. For the tactical squad, that doesn't sound right, but I'll have to look at the rule again and see when leaders are declared and work out the timing. Link to comment https://bolterandchainsword.com/topic/380865-space-marine-points-and-2-leaders-in-a-tactical-squad/#findComment-5995896 Share on other sites More sharing options...
BluejayJunior Posted October 18, 2023 Share Posted October 18, 2023 I stand corrected about the tactical squad. It says it happens at the start of the Declare Battle Formations step, so would happen right before you assign Leaders to their squads. So looks like you could split them and then add a Leader to each half of the squad. Karhedron and Commander Nicky 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/380865-space-marine-points-and-2-leaders-in-a-tactical-squad/#findComment-5995952 Share on other sites More sharing options...
