Brother Kraskor Posted October 20, 2023 Share Posted October 20, 2023 Fraters, What happens when you have multiple models in a unit which must always issue/accept challenges? Say, for example, Fulgrim Ascended is riding with a Champion. You can't issue with both, so who goes first? And equally if receiving a challenge, who has to step up? Link to comment https://bolterandchainsword.com/topic/380903-multiple-models-which-must-issue-a-challenge/ Share on other sites More sharing options...
Dark Legionnare Posted October 21, 2023 Share Posted October 21, 2023 (edited) You can only ever have one challenge per combat. Rules cover both the fact that you can only issue one challenge per round of a combat, and that if an existing challenge is ongoing you can't issue another. That's pg 198. Every other time you have a "must" effect but two sources or destinations you pick which of the two. For instance, if you must charge the closest unit, but there's two enemy units equidistant you pick which one. As for receiving, it's the same but the inverse. One of your "musts" has to accept. You pick which one. -------------- Thematically, I would say of the musts in either declaring or accepting, if Fulgrim is around he should always be the one. That absolutely self-obsessed, self-aggrandizing maniac would likely give anybody else the Eidolan wine-barrel treatment if they issued or accepted in his stead. From a fluff standpoint. Edited October 21, 2023 by Dark Legionnare Noserenda, Brother Kraskor and Cactus 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/380903-multiple-models-which-must-issue-a-challenge/#findComment-5996707 Share on other sites More sharing options...
Brother Kraskor Posted October 21, 2023 Author Share Posted October 21, 2023 Ok so we are essentially saying, when there are two 'musts' it works as 'you pick' in other rules situations, so it would be sensible to do it the same for challenges. But in terms of concrete rules, we don't have any. Thematically of course I agree Fulgrim should do it! Link to comment https://bolterandchainsword.com/topic/380903-multiple-models-which-must-issue-a-challenge/#findComment-5996735 Share on other sites More sharing options...
Cleon Posted October 21, 2023 Share Posted October 21, 2023 I mean thematically, it depends who is issuing the challenge - If some Imperial fist Sgt is calling out a challenge, but Sigismund is in the fight, I would totally accept Fulgrim not even noticing the Sgt and slicing his way through the squad towards his real opponent - but that rolls back to a lot of the 'crunch' of HHv2 that I don't like - weak Challenges as tar pits to minimise incoming damage is up there with artificer sgts dancing around catching every bolt round on their better armour. Link to comment https://bolterandchainsword.com/topic/380903-multiple-models-which-must-issue-a-challenge/#findComment-5996741 Share on other sites More sharing options...
Brother Kraskor Posted October 21, 2023 Author Share Posted October 21, 2023 Yes actually I like that, kind of a defence against 'gamey' opponents. If its not at least WS6, Fulgrim doesn't bother! Link to comment https://bolterandchainsword.com/topic/380903-multiple-models-which-must-issue-a-challenge/#findComment-5996742 Share on other sites More sharing options...
Dark Legionnare Posted October 21, 2023 Share Posted October 21, 2023 5 hours ago, Brother Kraskor said: Ok so we are essentially saying, when there are two 'musts' it works as 'you pick' in other rules situations, so it would be sensible to do it the same for challenges. But in terms of concrete rules, we don't have any. Thematically of course I agree Fulgrim should do it! Aye. The "musts" for challenges are so rare an effect my money is on GW just not even caring to clarify because it never crossed their radar. There is no hard clarification, but based on the "One challenge per combat" stance and all the other Ph 198-199 rules that's the logical result. Brother Kraskor 1 Back to top Link to comment https://bolterandchainsword.com/topic/380903-multiple-models-which-must-issue-a-challenge/#findComment-5996789 Share on other sites More sharing options...
