I’ve managed to get a couple of games in with the list below, although they were both defeats to another space marine list. (96-85 and 86-74). The lancers were amazing while the hellblaster (with apothecary) and whirlwind seemed to be a little lack lustre.
Are there any possible useful alterations I could make to the list to make it better?
Thanks in advance.
Characters and attached unit:
Apothecary - Hellblasters (infiltrating)
Terminator Captain - Terminators (possible Deep Strike)
Phobos Librarian - Infiltrators (infiltrating)
Jump intercessors also possibly in deep strike reserve.
One of the intercessor squads to start in the Impulsor and push up to sticky a mid field objective.
Thanks in advance for the help!
Spoiler
Ultramarines (Novamarines)
Vanguard Spearhead
Strike Force (2000 Points)
CHARACTERS
Apothecary
    • 1x Absolvor bolt pistol
      1x Close combat weapon
      1x Reductor pistol
    • Enhancements: The Blade Driven Deep
Captain in Terminator Armour
    • Warlord
    • 1x Relic weapon
      1x Storm bolter
Librarian in Phobos Armour
    • 1x Bolt pistol
      1x Force weapon
      1x Smite
Lieutenant with Combi-weapon
    • 1x Combi-weapon
      1x Paired combat blades
BATTLELINE
Heavy Intercessor Squad
    • 1x Heavy Intercessor Sergeant
        • 1x Bolt pistol
          1x Heavy bolt rifle
    • 4x Heavy Intercessor
        • 4x Bolt pistol
          4x Close combat weapon
          4x Heavy bolt rifle
Intercessor Squad
    • 1x Intercessor Sergeant
        • 1x Bolt pistol
          1x Bolt rifle
          1x Power fist
    • 4x Intercessor
        • 1x Astartes grenade launcher
          4x Bolt pistol
          4x Bolt rifle
Intercessor Squad
        • 1x Bolt pistol
          1x Bolt rifle
          1x Power fist
    • 4x Intercessor
          4x Bolt pistol
          4x Bolt rifle
DEDICATED TRANSPORTS
Impulsor
    • 1x Armoured hull
      1x Ironhail heavy stubber
      1x Shield dome
      2x Storm bolter
OTHER DATASHEETS
Assault Intercessors with Jump Packs
    • 1x Assault Intercessor Sergeant with Jump Pack
        • 1x Heavy bolt pistol
          1x Power fist
    • 4x Assault Intercessors with Jump Packs
        • 4x Astartes chainsword
          4x Heavy bolt pistol
Eliminator Squad
    • 1x Eliminator Sergeant
        • 1x Bolt pistol
          1x Bolt sniper rifle
    • 2x Eliminator
        • 2x Bolt pistol
          2x Bolt sniper rifle
          2x Close combat weapon
Gladiator Lancer
    • 1x Armoured hull
      1x Icarus rocket pod
      1x Lancer laser destroyer
      2x Storm bolter
Gladiator Lancer
    • 1x Armoured hull
      2x Storm bolter
Hellblaster Squad
    • 1x Hellblaster Sergeant
        • 1x Bolt pistol
          1x Plasma incinerator
    • 4x Hellblaster
        • 4x Bolt pistol
          4x Plasma incinerator
Infiltrator Squad
    • 1x Infiltrator Sergeant
        • 1x Bolt pistol
          1x Marksman bolt carbine
    • 4x Infiltrator
        • 4x Bolt pistol
          1x Helix Gauntlet
          4x Marksman bolt carbine
Redemptor Dreadnought
    • 1x onslaught Gatling cannon
      1x Macro plasma incinerator
      1x Redemptor fist
      1x Twin storm bolter
Sternguard Veteran Squad
    • 1x Sternguard Veteran Sergeant
        • 1x Close combat weapon
          1x Sternguard bolt pistol
          1x Sternguard bolt rifle
    • 4x Sternguard Veteran
        • 4x Close combat weapon
          4x Sternguard bolt pistol
          4x Sternguard bolt rifle
Terminator Squad
    • 1x Terminator Sergeant
        • 1x Power fist
          1x Storm bolter
    • 4x Terminator
        • 1x Chainfist
          3x Power fist
          4x Storm bolter
Whirlwind
    • 1x Armoured tracks
      1x Whirlwind vengeance launcher
https://bolterandchainsword.com/topic/380968-novamarine-vanguard-spearhead/
I’ve thought about las fusils though they’re strength 9. I’ve thought that the strength 9 isn’t strong enough to punch through armour as you’d need 5’s to wound and at that point I’d rather take eradicators as they get re-rolls.
I'm not a fan of infiltrating Hellblasters - I think I'd rather put them in a pod or an Impulsor for some protection (between Deep Strike And/Or Impulsor Armor)  Infiltrating from Vanguard feels like it would be better used on some Gravis to get them in the middle as a bullet sponge.
That’s the main problem I found with infiltrating them. I ended up going second twice and in both games I ended up loosing 3 of them. I thought about a pod and putting it on an objective to hold.
I like the idea of an Impulsor/Firing Deck gimmick too.  Giving them T9 or so, and a 5++ seems like it wouldn't be bad I just haven't gotten around to it yet.   Infiltrating some Eradicators wouldn't be bad either with shorter range weapons + Gravis Toughness/armor save
I do like that idea, it seems like it could be good fun having 5 hellblasters driving around causing chaos!
if I remove the apothecary (blade driven deep) and the whirlwind it gives me 220 to play with. Which means I can add in a squad of aggressors and be spot on 2000. It does mean that they will have to walk up the board though.
Edited by strawberry fist
Aggressors are OK here, but they don't REALLY mesh well.  You want to be able to march up 2" away, unload, then charge and punch what's left.  Vanguard wants everything to be more than 12" away.   With that said, 18 TWIN-LINKED PRECISION power fist attacks into an Old One Eye who thinks he's protected by a squad of Carnifexes has some appeal.
I just started looking at the Anvil Seige Force too:
Hellblasters inside a 5++ Shield Dome Impulsor that race up the field then park on an objective marker.  Its now stationary with 6 Heavy +1 to wound plasma exterminators.
GravCan Devs into Twin LC and Twin HB Razorbacks.  Race up field, now stationary with twin linked (rerolling) +1 to wound Heavy Bolters and Lascannon and blowing the Battle Drill strat on them/it for 6 Sustained 1, Crit Hit on a 5+ GravCan shots - averaging now 2 extra hits with Anti-Vehicle 2+.
A Gigantic Land Raider/Repulsor/Predator/Gladiator support task force - you get the idea - but mostly the Land Raider (Classic) for the Twin Linked HB and pair of 2 shot Godhammers, or Gladiator Reaper with a Twin Linked +1 to wound.
A fair number of people didn't like the Anvil force because they were painting that force yellow and standing still.  Try painting it White with red lightning bolts and it starts looking different.   Anything with HEAVY weapons loves that formation, if they have enough movement (Vehicles/Transports), infiltrate(Eliminators), Deep Strike(Drop Pods?) to get to where they want to be (or the range/LOS to do it from the backfield (Firestrikes, Desolators, and Whirlwinds?) and then stay stationary they love it even more.
One of the things I enjoy doing with these new formations is "flipping the script" - how does a traditional "White Scars" unit do in the Anvil force, or an Imp Fist in the Vanguard etc - you're really just mixing and matching strengths and drawbacks.  So I look at what the formation boosts through its always on rule, or the strats or both and look at what gets helped.  Anvil doesn't help movement but it does help heavy shooting, so I thought of the tanks paired with a static infantry force in my backfield, or the White Scars "Rhino Rush".   Vanguard plays well into Infiltrating Gravis bullet sponge and infiltrating and/or long range shooting.
Edited by Tacitus
Forgot Razorbacks are only Firing Deck 2
Ooh an all Terminator Force (Probably Deathwing for extra unit types/Rule of 3 stuff) loaded up on Deep Striking Cyclone Missile Launchers -  Turn 1, deep strike, turn 2+ Stationary on the Objective 2/4 Krak Missiles that still wound T12 on 4's, wound T4 on 2's.
Land Speeder Vengeances if they stick around in the full new codex... But not aircraft.  Aircraft are laughable here because they always have to move.
And I just realized vehicle heavy weapons are not HEAVY - so this doesn't work for them same with Terminators which is silly because that's a staple of the typical Imp Fist army.  Instead of getting +1 to wound, they get HEAVY - which isn't horrible... 3+ to 2+ to hit isn't bad, but it was really about leaning into the +1 to wound on S8-10ish weaponry vs T10-12ish tanks and monsters. Also not Erads. Not Firestrikes, not Centurions, Not Cents/Dreads, Heavy Intercessors have it, but are slow and can't pod.
Eliminators(Infiltrate), Hellblasters in Impulsors (Still get the HEAVY), Suppressors (Deep Strike), Desolators... I'm suddenly realized Space Marines have very few HEAVY weapons with the way they've cancelled out HEAVY and Can-Move-And-Fire-Heavy-Weapons-Without-Penalty units like vehicles, Dreads, bikes and Termies/Heavy Infantry.
  • 1 month later...
I’ve enjoyed using the list, though I’ve found the heavy intercessors and the Phobos Lieutenant lacking. Mainly down to me forgetting his ability pre and during the game!
This is the list I’m currently intending to run at a tournament in the new year. What do you think?
Apothecary  - with aggressors
captain in terminator - with terminators
phobos lib - with infiltrators
Uriel - one of the intercessors
Spoiler
CHARACTERS
Apothecary Biologis
    • 1x Relic weapon
      1x Storm bolter
    • 1x Bolt pistol
      1x Force weapon
      1x Smite
    • Enhancements: Execute and Redeploy
Uriel Ventris
    • Warlord
    • 1x Bolt Pistol
      1x Invictus
      1x Sword of Idaeus
BATTLELINE
Intercessor Squad
        • 1x Bolt pistol
          1x Bolt rifle
          1x Power fist
    • 4x Intercessor
          4x Bolt pistol
          4x Bolt rifle
Intercessor Squad
        • 1x Bolt pistol
          1x Bolt rifle
          1x Power fist
    • 4x Intercessor
          4x Bolt pistol
          4x Bolt rifle
OTHER DATASHEETS
Aggressor Squad
    • 1x Aggressor Sergeant
        • 1x Auto boltstorm gauntlets
          1x Fragstorm grenade launcher
          1x Twin power fists
    • 5x Aggressor
        • 5x Auto boltstorm gauntlets
          5x Fragstorm grenade launcher
          5x Twin power fists
Centurion Devastator Squad
    • 1x Devastator Centurion Sergeant
        • 1x Centurion fists
          1x Centurion missile launcher
          1x Grav-cannon
    • 2x Devastator Centurion
        • 2x Centurion fists
          2x Centurion missile launcher
          2x Grav-cannon
Gladiator Lancer
    • 1x Armoured hull
      2x Storm bolter
Gladiator Lancer
    • 1x Armoured hull
      2x Storm bolter
Hellblaster Squad
        • 1x Bolt pistol
    • 4x Hellblaster
        • 4x Bolt pistol
Inceptor Squad
    • 1x Inceptor Sergeant
        • 1x Assault bolters
    • 2x Inceptor
        • 2x Assault bolters
Infiltrator Squad
        • 1x Bolt pistol
    • 4x Infiltrator
        • 4x Bolt pistol
          1x Helix Gauntlet
    • 1x Icarus rocket pod
      1x Onslaught gatling cannon
      1x Redemptor fist
Scout Squad
    • 1x Scout Sergeant
        • 1x Bolt pistol
          1x Boltgun
    • 4x Scout
        • 4x Bolt pistol
          4x Boltgun
Terminator Squad
        • 1x Power fist
          1x Storm bolter
    • 4x Terminator
        • 1x Chainfist
          1x Cyclone missile launcher
          3x Power fist
          4x Storm bolter
Register a new account
Sign in
