Sambojin Posted October 30, 2023 Share Posted October 30, 2023 (edited) Rubric Marines... I mean, they can dark pact, but not usefully (with warpflamers). They can't use their cabal points, but they fit in a Rhino. Yet they don't get magic moves. What are pure Chaos player's thoughts on them? Is a 5++ and Icon of Flame and a minigun worth 105pts on the heavy/ vehicle meta, with all the points changes compared to others? Is the Minigun even worth it, or would you rather an extra warpflamer? Just questions. Micro-mini flamer terminators, or trash outside their list? (The chaos gods totally understand if you just use Infernus Marines for this. Because they're cheap. Meh, they'll do) Edited October 30, 2023 by Sambojin Link to comment https://bolterandchainsword.com/topic/380984-what-are-the-thoughts-of-rubrics-in-chaos-lists/ Share on other sites More sharing options...
LSM Posted October 30, 2023 Share Posted October 30, 2023 As far as I know, none of the Cult Troops can Dark Pact (it's not on their datasheets - while their FACTION keyword gets replaced with Heretic Astartes, their Faction Ability does not get changed to Dark Pacts... even though it really should...). Warpflamer Rubrics are the only Cult Troop that are even a possibility for me - marked Legionaries/Chosen do pretty much everything that all the others can do but better.* The Warpflamers open up a new role, so aren't immediately out of the question. How valuable that role is though... it's a pretty niche trick. *I haven't reappraised this opinion since points adjustments were made. Plague Marines are down to 80pts for 5, for example, and can bring two Plasma Guns and a Blight Launcher. Maybe useful? Iron Father Ferrum 1 Back to top Link to comment https://bolterandchainsword.com/topic/380984-what-are-the-thoughts-of-rubrics-in-chaos-lists/#findComment-5998464 Share on other sites More sharing options...
Iron Father Ferrum Posted October 31, 2023 Share Posted October 31, 2023 Sadly, I haven't really felt the need to find room for any of the Cult Marine squad types. I know Noise Marines are used fairly often for the Blast Masters, but the actual outside-the-codex choices? I haven't seen anyone field them in a CSM army recently. Link to comment https://bolterandchainsword.com/topic/380984-what-are-the-thoughts-of-rubrics-in-chaos-lists/#findComment-5998971 Share on other sites More sharing options...
Dark_Vengeant Posted December 31, 2023 Share Posted December 31, 2023 You won't benefit from all their army list rules but they are totally canon if you're using a Black Legion army! Have you read the Black Legion books? Link to comment https://bolterandchainsword.com/topic/380984-what-are-the-thoughts-of-rubrics-in-chaos-lists/#findComment-6012683 Share on other sites More sharing options...
Indy Techwisp Posted March 10, 2024 Share Posted March 10, 2024 Chiming in here a bit late. Outside of TSons, you're probably taking Rubrics for the Flamer Brick more than anything else. Most likely in 5-man squads too, without Soulreaper (as cool as the minigun is), and with a Warpflame Pistol on the Aspiring Sorc, so everyone in that unit has a Flamer. Add in the Icon of Flame as well, so those flamers hit AP-2 on the crit. (Good luck finding the spare points to actually fit them in your lists tho...) LSM 1 Back to top Link to comment https://bolterandchainsword.com/topic/380984-what-are-the-thoughts-of-rubrics-in-chaos-lists/#findComment-6026967 Share on other sites More sharing options...
