hd3 Posted November 1, 2023 Share Posted November 1, 2023 Can I use the old cultist models from 6th edition with the rules of cultists in the current edition? Or are the weapons different? I need two units and I was thinking of using the old models for visual variety. Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/ Share on other sites More sharing options...
Solution gaurdian31 Posted November 1, 2023 Solution Share Posted November 1, 2023 The old cultists don't have all the special weapon options (grenade launcher is missing) but they do have either cultist firearms and close combat weapons or autopistols and brutal assault weapons so it should be fine. Muskie, Khulu, hd3 and 1 other 1 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-5999194 Share on other sites More sharing options...
TrawlingCleaner Posted November 1, 2023 Share Posted November 1, 2023 As long as you're clear on what each model represents and there's no confusing proxies (Melta guns are plasma guns and flamers are meltas in this squad, for example), go nuts! Bouargh, Khulu, gaurdian31 and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-5999196 Share on other sites More sharing options...
FashaTheDog Posted November 2, 2023 Share Posted November 2, 2023 This is a resound it depends answer. Some places are going to require the most recent models to avoid the modeling for advantage or confusion line. When the new Guard codex came out last edition there were tournaments that required the new Sentinel, never you mind it was only available in the Cadia Stands box at the time. Other tournaments took the line of who cares what you use so long as your foe knows what is what and if you are rocking old models, such as the original metal Sentinel, all the better since many folks like seeing the history of the game. In pickup games this comes down to the group and how they feel. Most groups probably say yes to old, heavily converted, or even third party stuff because they like the creativity and expanded player base. Some might be a strict WYSIWYG group, and others still might insist on the current models for some or all things for whatever reason they feel like. To sum, ask where you intend to use them. That will be your best guide as we here on the internet will all have different experiences and possibly house rules; some of us have laid back groups when it comes to what you use or strict groups on the subject or somewhere in between. Oxydo 1 Back to top Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-5999542 Share on other sites More sharing options...
tychobi Posted November 2, 2023 Share Posted November 2, 2023 You can! Those models are perfect suited for tenth ed . Special weapons on cultist are mostly a waste of time but extra points for converting if that's your jam. Wisiwig is a bit awkward in tenth especially for collectors, most folks I know are fine with pocket thunderhammers, legacy basing, shadow sponsons on tanks and such. Be clear, considerate, and consistent and you should be fine. Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-5999603 Share on other sites More sharing options...
Rogue Posted November 2, 2023 Share Posted November 2, 2023 Legacy basing is a funny thing. GW general say that models should be on the base they came with. But my terminators are old enough that they came with 25mm bases. So as far as I'm concerned, that makes them legit. I suspect the tournament organisers might disagree, but for playing friends it's fine. Karhedron, Kallas, Brother Carpenter and 3 others 5 1 Back to top Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-5999617 Share on other sites More sharing options...
Dark Legionnare Posted November 2, 2023 Share Posted November 2, 2023 (edited) 15 minutes ago, Rogue said: Legacy basing is a funny thing. GW general say that models should be on the base they came with. But my terminators are old enough that they came with 25mm bases. So as far as I'm concerned, that makes them legit. I suspect the tournament organisers might disagree, but for playing friends it's fine. I'll likely never rebase my 130+ ork boyz with all their custom individually unique bases per boy. For where it matters (More stakes tournaments and such) I just tend to space them out like they're on 32's. Like @tychobi said; being concise ahead of time is what matters most. There's also printable (and pretty cheap to buy too I've seen on Etsy before) adapters to upsize bases! Edited November 2, 2023 by Dark Legionnare Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-5999620 Share on other sites More sharing options...
Brother Carpenter Posted November 2, 2023 Share Posted November 2, 2023 55 minutes ago, Dark Legionnare said: @tychobi There's also printable (and pretty cheap to buy too I've seen on Etsy before) adapters to upsize bases! Or just stick then with the original base on the larger base, this also settles the size creep issue and potential discussion LSM, Cactus, Muskie and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-5999631 Share on other sites More sharing options...
happyslugger Posted November 2, 2023 Share Posted November 2, 2023 I have 40 of the old cultist models which I will be using. I have 20 with a pistol and some form of close combat weapon and the other 20 have the ranged weapons. Worst case, those last 20 ran out of rifle ammo and now have a pistol and use the rifle as a beatstick. tychobi 1 Back to top Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-5999633 Share on other sites More sharing options...
Rain Posted November 2, 2023 Share Posted November 2, 2023 (edited) Modelling for advantage vs aesthetics is like art. It's difficult to define, but you know it when you see it. Someone modelling crouching* (or, Khorne forbid, crawling) Wraithlords? Not someone I'd even bother playing. Using old models because you enjoy the aesthetic, or, having old models based on the smaller bases that they originally came with? Perfectly fine. Especially if the entire army is retro, and it's a theme followed throughout. I'd rather play someone with cute little 3rd edition gun eyes Obliterators than someone using some of the more...divisive modern sculpts from an aesthetic point of view, and if you really care that much about winning or losing your game of toy soldiers outside of money tournaments, well, that's on you. *unless it's an Alaitoc army with a converted crouching Wraithlord with a camo cloak, and holding its gun all sneaky-sniper like to represent a Wraithlord made with a Ranger's spirit stone. That would be very cool, and I'd gladly face that even if makes for a smaller target or whatever. Edited November 2, 2023 by Firedrake Cordova Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-5999640 Share on other sites More sharing options...
Abanshee Posted November 6, 2023 Share Posted November 6, 2023 (edited) On 11/2/2023 at 4:06 PM, Rain said: Modelling for advantage vs aesthetics is like art. It's difficult to define, but you know it when you see it. Someone modelling crouching* (or, Khorne forbid, crawling) Wraithlords? Not someone I'd even bother playing. Using old models because you enjoy the aesthetic, or, having old models based on the smaller bases that they originally came with? Perfectly fine. Especially if the entire army is retro, and it's a theme followed throughout. I'd rather play someone with cute little 3rd edition gun eyes Obliterators than someone using some of the more...divisive modern sculpts from an aesthetic point of view, and if you really care that much about winning or losing your game of toy soldiers outside of money tournaments, well, that's on you. *unless it's an Alaitoc army with a converted crouching Wraithlord with a camo cloak, and holding its gun all sneaky-sniper like to represent a Wraithlord made with a Ranger's spirit stone. That would be very cool, and I'd gladly face that even if makes for a smaller target or whatever. I'm not too concerned with how big my opponents models are, but at least make it comparable to the original model. That's really all I care about when it comes to old models/conversions/proxies. Also, that's a really neat idea for a conversion. Edited November 6, 2023 by Abanshee Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-6000610 Share on other sites More sharing options...
Evil Eye Posted November 9, 2023 Share Posted November 9, 2023 On 11/2/2023 at 8:06 PM, Rain said: *unless it's an Alaitoc army with a converted crouching Wraithlord with a camo cloak, and holding its gun all sneaky-sniper like to represent a Wraithlord made with a Ranger's spirit stone. That would be very cool, and I'd gladly face that even if makes for a smaller target or whatever. I recall someone did that in an example army in the 5E rulebook! Very cool it was too. Blindhamster 1 Back to top Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-6001285 Share on other sites More sharing options...
Helias_Tancred Posted November 11, 2023 Share Posted November 11, 2023 On 11/1/2023 at 11:15 AM, hd3 said: Can I use the old cultist models from 6th edition with the rules of cultists in the current edition? Or are the weapons different? I need two units and I was thinking of using the old models for visual variety. At the end of the day (something I've been fond of saying lately lol) it comes down to two people; you and your opponent at that given time ... unless its a tournament with its pre-determined rules. Then you can add in the TO too ;) lol. Link to comment https://bolterandchainsword.com/topic/381008-question-about-using-old-models-in-a-current-edition/#findComment-6001582 Share on other sites More sharing options...
