Craig Posted November 2, 2023 Share Posted November 2, 2023 So I recently decided to try an all over oil wash with some of my leviathan termegants. 50/50 black and brown Windsor and Newton paint from the Range thinned with some standard white spirit I had in the garage (probably pound land stuff). When removing the excess with a wedged make up sponge some of the acrylic paint on the edges was coming away too and revealing the primer layer. I didn't varnish before applying the wash as I have seen many people say it's not necessary. Am I doing something wrong? Leaving the wash too long or not long enough? Should I be varnishing before applying wash? Am I being too aggressive when sponging off the wash? Anyone able to give me some advice? Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/ Share on other sites More sharing options...
Solution Bung Posted November 2, 2023 Solution Share Posted November 2, 2023 Did you Airbrush your miniatures? Thinner paint layers are more vulnerable to solvents and mechanic damage. What colors did you use waterbased acrylics are more vulnerable than something like Tamiya, Mr. Hobby, etc. I find the Varnish layer depends on your planned painting process. If you do only a controlled Pin wash, then you dont need a varnish layer in my eyes. If you do as you described and Paint the whole miniature in oil paint, then remove excess, i would do a Gloss varnish layer. Firedrake Cordova and Craig 2 Back to top Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-5999476 Share on other sites More sharing options...
madlibrarian Posted November 2, 2023 Share Posted November 2, 2023 I always gloss varnish before using oil washes and spirits to remove them. Had the same thing happen to Me as what you had, and this was an easy and quick fix. Lord Marshal and Craig 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-5999493 Share on other sites More sharing options...
Karhedron Posted November 2, 2023 Share Posted November 2, 2023 White spirit will dissolve acrylic paint. Rubbing it with a sponge will exacerbate the problem. Either varnish first or use acrylic washes instead. Craig 1 Back to top Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-5999502 Share on other sites More sharing options...
Craig Posted November 2, 2023 Author Share Posted November 2, 2023 3 hours ago, Bung said: Did you Airbrush your miniatures? Thinner paint layers are more vulnerable to solvents and mechanic damage. What colors did you use waterbased acrylics are more vulnerable than something like Tamiya, Mr. Hobby, etc. I find the Varnish layer depends on your planned painting process. If you do only a controlled Pin wash, then you dont need a varnish layer in my eyes. If you do as you described and Paint the whole miniature in oil paint, then remove excess, i would do a Gloss varnish layer. No airbrush, just citadel nagaroth night thinned with water. I think the consensus is to varnish before applying the wash. Will give that a try. Thanks all. madlibrarian 1 Back to top Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-5999536 Share on other sites More sharing options...
sarabando Posted November 2, 2023 Share Posted November 2, 2023 i always varnish a good coat of gloss before oils and let it dry too. Dont let the spirit sit on the mini too much too even with the varnish. But good on you for trying a new technique it was really scary the first time it did it and it has changed the way i paint i love them. Craig 1 Back to top Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-5999608 Share on other sites More sharing options...
andes Posted November 2, 2023 Share Posted November 2, 2023 I only varnish if I plan on removing some of the oil wash later with brush or sponge + spirits. If I'm being careful applying the wash, or just doing a pin wash, I don't bother. Craig and sarabando 2 Back to top Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-5999615 Share on other sites More sharing options...
Craig Posted November 2, 2023 Author Share Posted November 2, 2023 1 hour ago, sarabando said: i always varnish a good coat of gloss before oils and let it dry too. Dont let the spirit sit on the mini too much too even with the varnish. But good on you for trying a new technique it was really scary the first time it did it and it has changed the way i paint i love them. Thanks, I eventually want to try painting a mini with oils instead of acrylics. If I can't do a simple oil wash yet that seems a far way off though. Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-5999618 Share on other sites More sharing options...
andes Posted November 2, 2023 Share Posted November 2, 2023 It's not, I think they're unrelated. If you wanna dive into oils just queue up some NJM with Marco Frisoni at Youtube and get rolling. Firedrake Cordova, tinpact, Craig and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-5999624 Share on other sites More sharing options...
Craig Posted November 2, 2023 Author Share Posted November 2, 2023 1 hour ago, andes said: It's not, I think they're unrelated. If you wanna dive into oils just queue up some NJM with Marco Frisoni at Youtube and get rolling. I have been watching him for a couple months. What a voice. :D Antarius, Firedrake Cordova and andes 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-5999638 Share on other sites More sharing options...
Firedrake Cordova Posted November 3, 2023 Share Posted November 3, 2023 Is this any help? Maschinenpriester 1 Back to top Link to comment https://bolterandchainsword.com/topic/381137-oil-washes/#findComment-6000114 Share on other sites More sharing options...
