CrusiusFin Posted November 5, 2023 Share Posted November 5, 2023 Hi, I'm thinking about doing another Legion after my Night Lords (although an army is never fully completed) and I thought about maybe a late heresy World Eaters. With the coming Christmas box set of World Eaters (just want to paint Angron) I thought if the Berzerkers were the same size as the new MK3 and MK6? I was thinking about mixing bits cutting and sawing. Some being fully Berzerker, some having bits of both and some being fully HH marines. And maybe trying to convert Red Butchers from Eigth Bound. Paint scheme could be a mix of red, white and blue. If any one has both Berzerkers and legionaries are comparative sizes let me know. And if anyone has more converting ideas for example bigger non-daemon Angron alternative (model or 3d printable alternative). Link to comment https://bolterandchainsword.com/topic/381562-new-legionaries-and-40k-khorne-berzerkers-compatible/ Share on other sites More sharing options...
Lautrec the Embraced Posted November 5, 2023 Share Posted November 5, 2023 In my opinion they are rather comparable. They are a little bit bigger than Mk6 (don't know about Mk3 I'm waiting for my box to arrive) but they have very dynamic poses, jumping, running, some are more inclined etc makes their height rather varied. Some look exactly as tall as Mk6, others are slightly shorter or much taller. Here is a quick comparison between some NLs I am working on and some Berzerkers (I'm gonna paint them as SoH Reavers hence some weird bits - with the original Berzerkers helmets they'd look much, much bigger!) LameBeard and N1SB 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/381562-new-legionaries-and-40k-khorne-berzerkers-compatible/#findComment-6000384 Share on other sites More sharing options...
Marshal Rohr Posted November 5, 2023 Share Posted November 5, 2023 On Instagram several posters have used Chaos Marines and Bezerkers mixed with resin bits to make some pretty cool Veterans, Reavers, and Rampagers with all the chaos stuff shaved off. Definitely worth a try. Link to comment https://bolterandchainsword.com/topic/381562-new-legionaries-and-40k-khorne-berzerkers-compatible/#findComment-6000397 Share on other sites More sharing options...
Noserenda Posted November 5, 2023 Share Posted November 5, 2023 Seem about the same, plus the kit comes with a load of butchers nails laden heads which is perfect for world eaters Link to comment https://bolterandchainsword.com/topic/381562-new-legionaries-and-40k-khorne-berzerkers-compatible/#findComment-6000406 Share on other sites More sharing options...
CrusiusFin Posted November 5, 2023 Author Share Posted November 5, 2023 6 hours ago, Lautrec the Embraced said: In my opinion they are rather comparable. They are a little bit bigger than Mk6 (don't know about Mk3 I'm waiting for my box to arrive) but they have very dynamic poses, jumping, running, some are more inclined etc makes their height rather varied. Some look exactly as tall as Mk6, others are slightly shorter or much taller. Here is a quick comparison between some NLs I am working on and some Berzerkers (I'm gonna paint them as SoH Reavers hence some weird bits - with the original Berzerkers helmets they'd look much, much bigger!) Just built my first MK3 and it's as tall as MK6, but a bit bulkier so could be a good fit. Thanks for the replies. It seems I might start World Eaters Noserenda 1 Back to top Link to comment https://bolterandchainsword.com/topic/381562-new-legionaries-and-40k-khorne-berzerkers-compatible/#findComment-6000449 Share on other sites More sharing options...
Urauloth Posted November 6, 2023 Share Posted November 6, 2023 Yeah, the CSM kits are slightly bigger than the new Mk III, but I don't think the difference is enough to make them incompatible if you're prepared to put the work in. Link to comment https://bolterandchainsword.com/topic/381562-new-legionaries-and-40k-khorne-berzerkers-compatible/#findComment-6000633 Share on other sites More sharing options...
