Helias_Tancred Posted November 20, 2023 Share Posted November 20, 2023 I've got several P3 paints I heard mentioned often, Thramar Black, Coal Black, and Gravedigger Denim. I've got a black armored army (BT) and I'm looking for an all-purpose black to use on them over the Chaos Black spray primer. I'm considering Thramar Black, but I wanted to see what the experiences and opinions were before I start using it on all of my templars. Thanks. Link to comment https://bolterandchainsword.com/topic/381719-p3-opinions/ Share on other sites More sharing options...
Bung Posted November 20, 2023 Share Posted November 20, 2023 Coal Black isnt a real black, its a bit brighter Incubii Darkness. I Like it cause its great for shading Red tones. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/381719-p3-opinions/#findComment-6004036 Share on other sites More sharing options...
OttoVonAwesome Posted November 20, 2023 Share Posted November 20, 2023 (edited) Yeah Coal black is like Vallejo deep sea green or Incubii darkness I think maybe a touch darker very good to have if your going for blue or blue grey highlights or as a glaze to add a hint of colour. Black can be pretty boring when done in grey scale. You def want to use Thramar black as the basecoat though since it's a true black. Edited November 20, 2023 by OttoVonAwesome Helias_Tancred and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/381719-p3-opinions/#findComment-6004065 Share on other sites More sharing options...
Solution phandaal Posted November 20, 2023 Solution Share Posted November 20, 2023 Thamar Black is a great paint that covers really well. I have a pot that I bought 10+ years ago and still use for painting the rims on some of my bases. Finally running out but the paint still goes on as good as the day I bought it. Helias_Tancred and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/381719-p3-opinions/#findComment-6004079 Share on other sites More sharing options...
Helias_Tancred Posted November 20, 2023 Author Share Posted November 20, 2023 (edited) On 11/20/2023 at 5:03 AM, phandaal said: Thamar Black is a great paint that covers really well. I have a pot that I bought 10+ years ago and still use for painting the rims on some of my bases. Finally running out but the paint still goes on as good as the day I bought it. Expand That is a convincing testimonial! Thanks. Edited November 20, 2023 by Eilio Tiberius Link to comment https://bolterandchainsword.com/topic/381719-p3-opinions/#findComment-6004082 Share on other sites More sharing options...
Firedrake Cordova Posted November 20, 2023 Share Posted November 20, 2023 I like the P3 paints. As the others have said, Thamar Black is black, Coal Black is a dark blue-green, and Gravedigger Denim is a desaturated grey-blue. Privateer Press have a PDF of swatches for the line, which is reasonably accurate in my experience. For info: they're made by HMG in Manchester, who also made the 1990's GW flip-top line of paints, and the current line of GW paints. The range was designed by Mike McVey, who designed said 1990's line of GW paints. They use the same pots as the old GW flip-tops, which means the paint stays good "forever" (I still have pots from the early 1990s), but they did have a problem of the tab or hinge breaking, and they could be a bit hard to open (i.e. if you're opening 10 or more, you could end up with a sore thumb). Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/381719-p3-opinions/#findComment-6004097 Share on other sites More sharing options...
sarabando Posted November 20, 2023 Share Posted November 20, 2023 just make sure you clean the rim so you get a good seal and be careful of the hinge as it can break. Helias_Tancred and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/381719-p3-opinions/#findComment-6004131 Share on other sites More sharing options...
appiah4 Posted December 14, 2023 Share Posted December 14, 2023 I really wouldn't consider any P3 paints as being great to basecoat anything with.. Link to comment https://bolterandchainsword.com/topic/381719-p3-opinions/#findComment-6009443 Share on other sites More sharing options...
