Bear Posted February 8, 2024 Share Posted February 8, 2024 Hey all. Hopefully a fairly simple one. Can you turn the template ~90 degrees at the “x” point when using a torrent weapon (in like a “L” shape)? For instance, say you have a 18 inch torrent weapon and you measure straight 18 inches before putting the template down ~90 degrees sideways from the line you just measured to hit a squad of infantry that was hiding around a corner (or to cover a full squad that was partially obscured rather than just hitting the ~4 guys you could see). The rules simply state the narrow end must be closer to the firing model than the fat end but that is about all it has to say (pg 249 of my core rules). I feel like the answer should be “No” and the intent was to simply measure “X” inches before popping the template down facing roughly the same direction as the initial measurement line but the rule isn’t as clear as I would like. Thanks so much for your time regardless! LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/382281-torrent-rule-question/ Share on other sites More sharing options...
LameBeard Posted February 8, 2024 Share Posted February 8, 2024 I also had this question. In Zone Mortalis the rule as written seems ridiculously good - just pop the fat end round the corner. I guess the rule should be both thin and fat ends should be in line of sight? Bear 1 Back to top Link to comment https://bolterandchainsword.com/topic/382281-torrent-rule-question/#findComment-6021797 Share on other sites More sharing options...
Solution MichaelCarmine Posted February 9, 2024 Solution Share Posted February 9, 2024 The way i see it, you absolutely can place the Template that way and therefore get a hit for each model covered. But, since i don't know of any torrent weapon with the Barrage special rule, you can only kill what you see. So as soon as the models in LoS are removed, all remaining wounds are lost, as per the normal rules of allocating wounds. LameBeard and Bear 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/382281-torrent-rule-question/#findComment-6021841 Share on other sites More sharing options...
LameBeard Posted February 9, 2024 Share Posted February 9, 2024 7 hours ago, MichaelCarmine said: The way i see it, you absolutely can place the Template that way and therefore get a hit for each model covered. But, since i don't know of any torrent weapon with the Barrage special rule, you can only kill what you see. So as soon as the models in LoS are removed, all remaining wounds are lost, as per the normal rules of allocating wounds. Thanks, I’ll check that out. So it seems like it could be niche useful to improve the chance of killing one or two dudes you can see (by putting the template over those you can’t). The bizarre thing is those chances are improved compared to targeting a unit that had just those two dudes in the open and no-one else! But I could live with that - I can convert a flame storm cannon for my boxnaut with a clear conscience. Link to comment https://bolterandchainsword.com/topic/382281-torrent-rule-question/#findComment-6021882 Share on other sites More sharing options...
