TheArtilleryman Posted February 21, 2024 Share Posted February 21, 2024 (edited) Hi, Can anyone suggest any easily available (UK) paints that resemble the old citadel armour wash? This one: It’s very thin but very dark and grippy, and colours more of the surface than say Nuln oil, which is more watery and runs into the recesses more, leaving a lot more of the original colour on the raised areas. The armour wash is also ever so slightly metallic, giving the black a nice sheen. I used it to paint my Raven Guard infiltrators but I only have the one 25-year-old pot and am worried I won’t have enough for future projects. To give you an idea of what I need, here’s some of my marines: See the colour of the guns? That’s what the whole model looked like before I armour washed it. That’s the effect I want to create. Any suggestions welcome! Edited February 21, 2024 by TheArtilleryman Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/ Share on other sites More sharing options...
Solution Firedrake Cordova Posted February 21, 2024 Solution Share Posted February 21, 2024 (edited) Coat D'Arms Armour Wash should be the exact same paint. Otherwise, it should be possible to make something similar with a black and blue ink mix. Edited February 21, 2024 by Firedrake Cordova Agramar_The_Luna_Wolf, N1SB and Xenith 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6024217 Share on other sites More sharing options...
TheArtilleryman Posted February 21, 2024 Author Share Posted February 21, 2024 (edited) Thanks for the fast reply! I’ll definitely try some of that. £8.20 for one paint though because shipping is a fiver… dang Edited February 21, 2024 by TheArtilleryman Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6024222 Share on other sites More sharing options...
Firedrake Cordova Posted February 21, 2024 Share Posted February 21, 2024 (edited) Oof, that feels excessive! There's a few UK stockists (Black Hat are the distributor) - it might be worth looking at Essex Miniature, Hasslefree Miniatures, or Colonel Bills - I've not used any of them, but they all work out cheaper. Edited February 21, 2024 by Firedrake Cordova TheArtilleryman 1 Back to top Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6024228 Share on other sites More sharing options...
TheArtilleryman Posted February 21, 2024 Author Share Posted February 21, 2024 14 minutes ago, Firedrake Cordova said: Oof, that feels excessive! There's a few UK stockists (Black Hat are the distributor) - it might be worth looking at Essex Miniature, Hasslefree Miniatures, or Colonel Bills - I've not used any of them, but they all work out cheaper. Much appreciated. Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6024231 Share on other sites More sharing options...
Firedrake Cordova Posted February 21, 2024 Share Posted February 21, 2024 No prob Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6024234 Share on other sites More sharing options...
Xenith Posted February 21, 2024 Share Posted February 21, 2024 (edited) Basilicanum grey has more of the surface staining effect that you're after, and is an amazing paint. Black Templar will also turn a white to a black in the same manner as in your photos. Alternatively, if you like a metallic, black, try drybrushing metallics over black - here's some of my Effrit: These guys are successive, progressively lighter drybrushes of iron warriors, leadbelcher then iron hands steel over abaddon black. Edited February 21, 2024 by Xenith TheArtilleryman, LameBeard, Firedrake Cordova and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6024237 Share on other sites More sharing options...
tinpact Posted February 21, 2024 Share Posted February 21, 2024 As for making your own, you can get metallic medium by itself (which I may have to try out now). TheArtilleryman, Firedrake Cordova and Xenith 3 Back to top Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6024239 Share on other sites More sharing options...
TheArtilleryman Posted May 4, 2024 Author Share Posted May 4, 2024 On 2/21/2024 at 5:35 PM, Firedrake Cordova said: Oof, that feels excessive! There's a few UK stockists (Black Hat are the distributor) - it might be worth looking at Essex Miniature, Hasslefree Miniatures, or Colonel Bills - I've not used any of them, but they all work out cheaper. OK so just got around to ordering some from Essex Miniatures. Bit the bullet and ordered four pots, because I knew if it worked out I’d need a lot more. Just been giving it a go on two test models. Here’s the before shot with dawnstone and ulthuan grey drybrush: Here we are after one coat from each pot: The Coat d’arms behaves exactly the same way the armour wash does, but in this shot you can see the model on the left is considerably lighter than the other after one coat. I’m thinking this is likely because my Citadel pot is more than 25 years old and has probably lost some of its moisture over time. Here we are with a second coat on the Coat d’arms model: I think it’s a pretty good match after two coats. A bit annoying having to do two but not a big deal in the grand scheme of things. Seeing as I now have a good supply and a reliable source for a replacement, I think switching to the new pots is going to be the best plan. LameBeard, Scrinson, Firedrake Cordova and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6038352 Share on other sites More sharing options...
Firedrake Cordova Posted May 4, 2024 Share Posted May 4, 2024 Good to hear it's worked out for you. I suppose the plus side to needing to use two coats is you get a bit more control..? TheArtilleryman 1 Back to top Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6038359 Share on other sites More sharing options...
JeffJedi Posted May 9, 2024 Share Posted May 9, 2024 Very cool. I had a bottle. But I never used it that way, just as another black wash. Firedrake Cordova and TheArtilleryman 2 Back to top Link to comment https://bolterandchainsword.com/topic/382376-armour-wash-equivalents/#findComment-6039364 Share on other sites More sharing options...
