Battlesmith and cybertheurgic rite
Go to solution Solved by Churchill53,
Hello all.
Quick rules question. Can a magos do both battlesmith and cybertheurgic rite at the same time? Both are done instead of making a shooting attack. I can't seem to find anything written stating they can't be. I'm running dark mech for the first time and want to get it right.
Also, I'm aware that the paragon of metal upgrade does not allow for a cybertheurgic rite to be used on it. Does this extend to the animus integro? This allows for battlesmith to be used at 12" and to be done twice if the check is passed. I would assume not as the rite is making modifications to the standard rule but that a normal battlesmith would be fine.
Thanks.
  • Solution
Afraid not, the main rulebook faq for battlesmith says that you can't use battlesmith and any other ability that maybe used instead of making a shooting attack.
Not a clue about the second point though
Register a new account
Sign in
