Deus_Ex_Machina Posted May 1, 2024 Share Posted May 1, 2024 When you apply the top plate upon the lower one there is a gap. Is this gap intentional or do you need to fill it with for example Green Stuff? Art depictions of the shoulder plates don´t indicate any gaps. sarabando 1 Back to top Link to comment https://bolterandchainsword.com/topic/382819-cataphractii-shoulder-plates/ Share on other sites More sharing options...
sarabando Posted May 1, 2024 Share Posted May 1, 2024 They should be flush to the body to create a more imposing silhouette. its an older video of mine but i covered it here i hope this helps. :) Deus_Ex_Machina and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/382819-cataphractii-shoulder-plates/#findComment-6037842 Share on other sites More sharing options...
Deus_Ex_Machina Posted May 1, 2024 Author Share Posted May 1, 2024 I know. I have taken a look at art images before assembly. The top plate is of course closer to the top of the armoured torso leaving almost no gap. However I speak of another gap which is the one between the UPPER plate and the LOWER plate. There is a cavity in there when you assemble them according to the guide. Do you need to fill that cavity with Green Stuff? Link to comment https://bolterandchainsword.com/topic/382819-cataphractii-shoulder-plates/#findComment-6037848 Share on other sites More sharing options...
sarabando Posted May 1, 2024 Share Posted May 1, 2024 5 minutes ago, Deus_Ex_Machina said: I know. I have taken a look at art images before assembly. The top plate is of course closer to the top of the armoured torso leaving almost no gap. However I speak of another gap which is the one between the UPPER plate and the LOWER plate. There is a cavity in there when you assemble them according to the guide. Do you need to fill that cavity with Green Stuff? ah my mistake, no you dont. They are supposed to be layered upon each other, with movement increasing "flexibility" Aarik 1 Back to top Link to comment https://bolterandchainsword.com/topic/382819-cataphractii-shoulder-plates/#findComment-6037851 Share on other sites More sharing options...
Deus_Ex_Machina Posted May 1, 2024 Author Share Posted May 1, 2024 (edited) 2 hours ago, sarabando said: ah my mistake, no you dont. They are supposed to be layered upon each other, with movement increasing "flexibility" When you look at art both plates are so close together that there can´t be any kind of cavity. Edited May 1, 2024 by Deus_Ex_Machina Link to comment https://bolterandchainsword.com/topic/382819-cataphractii-shoulder-plates/#findComment-6037875 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted May 3, 2024 Share Posted May 3, 2024 On 5/1/2024 at 2:41 PM, Deus_Ex_Machina said: When you apply the top plate upon the lower one there is a gap. Is this gap intentional or do you need to fill it with for example Green Stuff? Art depictions of the shoulder plates don´t indicate any gaps. It's totally intentional , so you don't need to fill it you want WrathOfTheLion and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/382819-cataphractii-shoulder-plates/#findComment-6038272 Share on other sites More sharing options...
