Inquisitor_Lensoven Posted May 16, 2024 Share Posted May 16, 2024 Corvus Corax Light/Scout Tank M 12” T9 SV3+ W10 LD7+ turret autocannon or lascannon hull mounted twin linked hvy stubbers (dorn style nipple guns) pintle mounted heavy stubber HKM <scout8> what do y’all think? Does it stand out from sentinels and hellhound variants enough to be interesting? heavily inspired by the M2 Stewart Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/ Share on other sites More sharing options...
Tokugawa Posted May 16, 2024 Share Posted May 16, 2024 How dare a profile weaker than GSC armoured truck call itself a "tank"? Hellhound is T10 2+. The bottomline of a chimera sized IG tank should be no worse than T10 3+. And it need to have some real guns on its turret. Cheapest Leman Russ is 145pts. If shrink the chassis to T10 3+, then remove hull lascannon, then remove sponson guns, it already reach ~100pts, which is an usual cost of a "light tank". Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040836 Share on other sites More sharing options...
casb1965 Posted May 16, 2024 Share Posted May 16, 2024 The only comparison I could think of is the Predator which is M 10" T10 Sv 3+ W 11 with a twin-linked lascannon, that's 130pts. I can't see players using a light tank instead of a LR for the sake of 40pts or even 2 armoured sentinels. I guess it would all come down to cost and firepower. Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040862 Share on other sites More sharing options...
Inquisitor_Lensoven Posted May 16, 2024 Author Share Posted May 16, 2024 (edited) 5 hours ago, Tokugawa said: How dare a profile weaker than GSC armoured truck call itself a "tank"? Hellhound is T10 2+. The bottomline of a chimera sized IG tank should be no worse than T10 3+. And it need to have some real guns on its turret. Cheapest Leman Russ is 145pts. If shrink the chassis to T10 3+, then remove hull lascannon, then remove sponson guns, it already reach ~100pts, which is a usual cost of a "light tank". I think a better question is how dare a truck be T10. That seems a little bit ridiculous. M2 had 6mm-25mm of armor while the M4 Sherman had 12.7mm-178mm of armor, so I think T9 is a rather acceptable protection level of protection based on its inspiration. 2 hours ago, casb1965 said: The only comparison I could think of is the Predator which is M 10" T10 Sv 3+ W 11 with a twin-linked lascannon, that's 130pts. I can't see players using a light tank instead of a LR for the sake of 40pts or even 2 armoured sentinels. I guess it would all come down to cost and firepower. I’m sure plenty of people would use it if it had a good model. Might not see tournament play, but plenty of casual players would likely still use it. rerolling wounds for a twin linked stubber wouldn’t be bad, and keep the weapon relatively usable against tough targets. Edited May 16, 2024 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040890 Share on other sites More sharing options...
Bouargh Posted May 16, 2024 Share Posted May 16, 2024 (edited) For fast and or Light tanks, we already have the Carnaudon and the Salamander Scout vehicle. Both are Legends of course, but IMHO more than satisfying to fit into the role. I would not look further. And I would cross fingers for one of those to become part of 40k cannon... But I am also crossing fingers for the Griffon mortar to make a full legit come back and... well, I am still waiting Edited May 16, 2024 by Bouargh SteveAntilles 1 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040923 Share on other sites More sharing options...
Inquisitor_Lensoven Posted May 16, 2024 Author Share Posted May 16, 2024 44 minutes ago, Bouargh said: For fast and or Light tanks, we already have the Carnaudon and the Salamander Scout vehicle. Both are Legends of course, but IMHO more than satisfying to fit into the role. I would not look further. And I would cross fingers for one of those to become part of 40k cannon... But I am also crossing fingers for the Griffon mortar to make a full legit come back and... well, I am still waiting The salamander is just uncreative trash. ive never even heard of that other vehicle before, so can’t be too great. SteveAntilles and sairence 2 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040941 Share on other sites More sharing options...
SteveAntilles Posted May 16, 2024 Share Posted May 16, 2024 How dare you bash my Salamanders! They're from the before times, when things were simpler... Jolemai and Bouargh 2 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040949 Share on other sites More sharing options...
Jolemai Posted May 16, 2024 Share Posted May 16, 2024 12 hours ago, Inquisitor_Lensoven said: Corvus Corax Light/Scout Tank M 12” T9 SV3+ W10 LD7+ turret autocannon or lascannon hull mounted twin linked hvy stubbers (dorn style nipple guns) pintle mounted heavy stubber HKM <scout8> what do y’all think? Does it stand out from sentinels and hellhound variants enough to be interesting? heavily inspired by the M2 Stewart Salamander Scout Tank M12, T8, Sv3+ W10 Ld7 OC3 Autocannon, heavy bolter, armoured tracks Can add a hunter killer missile, heavy stubber/storm bolter Scouts 9", can arrive in opponents Deployment Zone from SR Despite being almost identical to your suggestion, the bottom one is considered to be "uncreative trash". So why is your suggestion/improvement better? The Carnodon isn't Legends yet, but is a FW vehicle (so likely to go when the Codex comes out, sadly) M12, T10, Sv2+ W12 Ld7 OC3 2 Autocannons, Carnodon twin autocannon, armoured tracks Can add a hunter killer missile, Turret can be switched out for a Carnodon twin lascannon, Carnodon twin multi-laser, volkite culverin Sponsons can be switched out for 2 heavy bolters/heavy flamers/lascannons/militarum multi-lasers/volkite calivers Re-rolls a Hit and Wound roll of 1 against units in the enemy deployment zone Basically, imagine a Predator for the Imperial Guard. TrawlingCleaner and SteveAntilles 2 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040956 Share on other sites More sharing options...
Dr. Clock Posted May 16, 2024 Share Posted May 16, 2024 There is (ancient) precedent for Guard to have Rhinos, so why not Predators? Also: Chimedon (battle cannon) and Chimerax (quad autocannon) variants have precedence in assault roles. Cheers, The Good Doctor. Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040958 Share on other sites More sharing options...
Inquisitor_Lensoven Posted May 16, 2024 Author Share Posted May 16, 2024 6 minutes ago, Jolemai said: Salamander Scout Tank M12, T8, Sv3+ W10 Ld7 OC3 Autocannon, heavy bolter, armoured tracks Can add a hunter killer missile, heavy stubber/storm bolter Scouts 9", can arrive in opponents Deployment Zone from SR Despite being almost identical to your suggestion, the bottom one is considered to be "uncreative trash". So why is your suggestion/improvement better? The Carnodon isn't Legends yet, but is a FW vehicle (so likely to go when the Codex comes out, sadly) M12, T10, Sv2+ W12 Ld7 OC3 2 Autocannons, Carnodon twin autocannon, armoured tracks Can add a hunter killer missile, Turret can be switched out for a Carnodon twin lascannon, Carnodon twin multi-laser, volkite culverin Sponsons can be switched out for 2 heavy bolters/heavy flamers/lascannons/militarum multi-lasers/volkite calivers Re-rolls a Hit and Wound roll of 1 against units in the enemy deployment zone Basically, imagine a Predator for the Imperial Guard. Yea the salamander is just an open topped chimera. it’s like the 40K el camino SteveAntilles, crimsondave and Tokugawa 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040961 Share on other sites More sharing options...
Inquisitor_Lensoven Posted May 16, 2024 Author Share Posted May 16, 2024 How does one disagree with facts? the salamander is just a chimera with the roof and turret removed making it a generally worse vehicle than the chimera. Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040992 Share on other sites More sharing options...
SteveAntilles Posted May 16, 2024 Share Posted May 16, 2024 A Chimera is troop transport IFV. The Salamander is an open topped Chimera chassis used as a scout or command tank. A Basilisk is a Chimera chassis with a gun on it. A Hellhound is a Chimera turned into a flame thrower tank. I was disagreeing with the El Camino part of your comment. The point is you're trying to fan make rules for a tank that already exists. crimsondave 1 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040996 Share on other sites More sharing options...
Inquisitor_Lensoven Posted May 16, 2024 Author Share Posted May 16, 2024 11 minutes ago, SteveAntilles said: A Chimera is troop transport IFV. The Salamander is an open topped Chimera chassis used as a scout or command tank. A Basilisk is a Chimera chassis with a gun on it. A Hellhound is a Chimera turned into a flame thrower tank. I was disagreeing with the El Camino part of your comment. The point is you're trying to fan make rules for a tank that already exists. Yes, the salamander is just an open topped chimera. *exists* rules that have never been in any codex I’ve ever seen. Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6040997 Share on other sites More sharing options...
Focslain Posted May 16, 2024 Share Posted May 16, 2024 23 minutes ago, Inquisitor_Lensoven said: Yes, the salamander is just an open topped chimera. *exists* rules that have never been in any codex I’ve ever seen. Page 57 of the Astra Militarium Legend document Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041003 Share on other sites More sharing options...
Inquisitor_Lensoven Posted May 16, 2024 Author Share Posted May 16, 2024 (edited) 39 minutes ago, Focslain said: Page 57 of the Astra Militarium Legend document That’s not a codex, especially these days, legends is generally just a precursor to being removed from the game completely when the next codex comes out. Edited May 16, 2024 by Inquisitor_Lensoven Focslain, SteveAntilles and Metzombie 3 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041010 Share on other sites More sharing options...
DemonGSides Posted May 16, 2024 Share Posted May 16, 2024 That's not what Legends is at all. SteveAntilles 1 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041011 Share on other sites More sharing options...
Inquisitor_Lensoven Posted May 16, 2024 Author Share Posted May 16, 2024 (edited) But in the end, salamander doesn’t provide any option for a dedicated AT option. A massive flaw for something that’s supposed to be operating forward with limited support, and 6-12 stubber shots will deal with most infantry decently well, especially since you’ll be rerolling wounds on half of those shots. and the carnodon is just a guard predator, not really a light tank… Edited May 16, 2024 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041021 Share on other sites More sharing options...
sairence Posted May 16, 2024 Share Posted May 16, 2024 (edited) I don't think any vehicle approaching the tank-description has any business having a scout move, personally. That's just not a tank's role. If you want a light tank profile with an anti-tank gun, the Hellhound with Meltacannon, aka the Devil Dog, is an existing option. You get the HK, the Stubber and your choice of HB, HF or MM in the hull. Edited May 16, 2024 by sairence Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041060 Share on other sites More sharing options...
Inquisitor_Lensoven Posted May 16, 2024 Author Share Posted May 16, 2024 (edited) 23 minutes ago, sairence said: I don't think any vehicle approaching the tank-description has any business having a scout move, personally. That's just not a tank's role. If you want a light tank profile with an anti-tank gun, the Hellhound with Meltacannon, aka the Devil Dog, is an existing option. You get the HK, the Stubber and your choice of HB, HF or MM in the hull. Light Tanks have been scouting since like…the 1930s and almost imperial vehicles are based off of 30s-50s designs kinda mashed up… see the M2/3 Stuarts I based these off of https://en.m.wikipedia.org/wiki/M3_Stuart Edited May 16, 2024 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041066 Share on other sites More sharing options...
Inquisitor_Lensoven Posted May 16, 2024 Author Share Posted May 16, 2024 Also the claim that the carnodon is a light tank, doesn’t hold water per lexicanum. https://wh40k.lexicanum.com/wiki/Carnodon_(Tank) Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041077 Share on other sites More sharing options...
sairence Posted May 17, 2024 Share Posted May 17, 2024 Based on its statline, the Carnodon is a smaller, lighter version of the statline of other tanks available. You can argue semantics all you like, but that's simply the gist of it. In the hierarchy of Guard tanks, with Hellhounds, Carnodons, Russes, Malcadors, Dorns, Baneblades etc etc the Carnodon is one of the lightest ones available. Anyway...as to your question if that statline would be something interesting...no. it doesn't do anything that other things don't do better. If I want a scout, I have infantry or sentinels doing it cheaper. And if I want a tank, there's plenty of options with significantly more firepower. But I generally don't want those too close to the enemy, cause that just means thsy get charged quicker. And this thing doesn't have more primary dakka than a Sentinel anyway. so why would you pay for a more expensive Sentinel that, as a tank, is probably more awkward to move around terrain? Focslain, Bouargh and SteveAntilles 3 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041116 Share on other sites More sharing options...
casb1965 Posted May 17, 2024 Share Posted May 17, 2024 There are light tanks out there for Guard armies in the Siegfried and Scylla, neither have rules but are both considered alternatives to the armoured sentinel. The Hellhound, Devil Dog and Bane Wolf, although based on the Chimera chassis, are considered to be light tanks. Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041124 Share on other sites More sharing options...
AutumnEffect Posted May 17, 2024 Share Posted May 17, 2024 14 minutes ago, casb1965 said: There are light tanks out there for Guard armies in the Siegfried and Scylla, neither have rules but are both considered alternatives to the armoured sentinel. The Hellhound, Devil Dog and Bane Wolf, although based on the Chimera chassis, are considered to be light tanks. Scylla is a good shout. Just look at the cute little guy. Dr. Clock, Tokugawa and sairence 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041128 Share on other sites More sharing options...
casb1965 Posted May 17, 2024 Share Posted May 17, 2024 10 hours ago, sairence said: I don't think any vehicle approaching the tank-description has any business having a scout move, personally. That's just not a tank's role. If you want a light tank profile with an anti-tank gun, the Hellhound with Meltacannon, aka the Devil Dog, is an existing option. You get the HK, the Stubber and your choice of HB, HF or MM in the hull. Sherman, Stuart, Covenanter to name a few all served as Reconnaissance tanks during WW2 so no reason why the AM wouldn't do the same. That does lead us back to the Salamander which is exactly what the AM call a reconnaissance vehicle. Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041129 Share on other sites More sharing options...
crimsondave Posted May 17, 2024 Share Posted May 17, 2024 The Salamander has been legends since 8th edition and it still has a legends data sheet. I don’t think it’s going anywhere or it would already be gone. Focslain and SteveAntilles 2 Back to top Link to comment https://bolterandchainsword.com/topic/382933-light-tank-idea/#findComment-6041193 Share on other sites More sharing options...
