ZeroWolf Posted May 19, 2024 Share Posted May 19, 2024 The only 40k element on the Sunday preview (aside from black library releasing a HH omnibus): Made to Order: Warhammer 40,000 Terrain Quote Spice up your 41st Millennium battlefields with a range of classic Warhammer 40,000 terrain returning on a Made to Order basis, starting with a Void Shield Generator complete with functioning cogs that can be left unglued and rotated. The Sub-cloister and Storage Fane set is an all-purpose pair of ruined Imperial buildings, while Plasma Regulators and Conservators make for great scatter terrain between larger buildings. Quote If you want to give your battlefield the air of an industrial hub or forge world, four returning kits from the Battlezone: Mechanicus range are the perfect way to add some brutal Imperial architecture. The Ferratonic Furnace and Pyrolation Incinerator add high gantries and ample vantage points for getting the drop on your opponents, while towering Alchomite Stacks and buzzing Haemotrope Reactors provide troops with cover as they advance through the forge. https://www.warhammer-community.com/2024/05/19/sunday-preview-the-dawnbringers-saga-ends-under-a-cloud-of-chaos/ templargdt, Gamiel, Wolf Lord Duregar and 2 others 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/ Share on other sites More sharing options...
Marshal Rohr Posted May 19, 2024 Share Posted May 19, 2024 When did they get rid of Sector Mechanicus? The Scorpion and Prot 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041687 Share on other sites More sharing options...
Burni Posted May 19, 2024 Share Posted May 19, 2024 Just now, Marshal Rohr said: When did they get rid of Sector Mechanicus? Yeah, half of that stuff made me go ‘Wait, can I not just buy this from stock now?! When did that change?!’. ZeroWolf, Mithrilforge, Kastor Krieg and 9 others 1 11 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041689 Share on other sites More sharing options...
aa.logan Posted May 19, 2024 Share Posted May 19, 2024 How much was the void shield generator before it was discontinued? Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041690 Share on other sites More sharing options...
Nephaston Posted May 19, 2024 Share Posted May 19, 2024 14 minutes ago, aa.logan said: How much was the void shield generator before it was discontinued? One store I found lists it at 85€, no clue if that relates to MSRP or just the site scalping it after it became discontinued. aa.logan 1 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041694 Share on other sites More sharing options...
torcathmk2 Posted May 19, 2024 Share Posted May 19, 2024 Element Games in the UK still has the old listing up for it at £85 Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041696 Share on other sites More sharing options...
Noserenda Posted May 19, 2024 Share Posted May 19, 2024 That sounds about right, i recall it being substantially more than the planetstrike range, enough that it was offputting even when they were clutch mechanically, and to be fair, released so late most people had scratch built alternatives. Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041705 Share on other sites More sharing options...
Wolf Lord Duregar Posted May 19, 2024 Share Posted May 19, 2024 Some of this terrain was in Shadow War Armageddon, correct? Pretty good Necromunda stuff.. Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041709 Share on other sites More sharing options...
excelite Posted May 19, 2024 Share Posted May 19, 2024 That void shield generator is tempting… but depends on what they ask for it now firestorm40k 1 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041717 Share on other sites More sharing options...
Hfran Morkai Posted May 19, 2024 Share Posted May 19, 2024 Here's hoping they do Sector Imperialis again at some point then. Firedrake Cordova, Corswain and mel_danes 3 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041718 Share on other sites More sharing options...
Mithrilforge Posted May 19, 2024 Share Posted May 19, 2024 This stuff albeit great terrain was a bit expensive when it was standard, I shudder to think what they’re going to charge for MTO … If you have any of the old pipe sections you can turn them up straight and get some finished deodorant roll on balls from empty containers and use them as the tops for a custom void generator M Wolf Lord Duregar, Firedrake Cordova and Interrogator Stobz 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041723 Share on other sites More sharing options...
lhg033 Posted May 19, 2024 Share Posted May 19, 2024 Having recently picked up the latest kill team terrain that had a furnace in it (with 20% discount it was hard to resist), I really dont 'need' another one as this was my second to add to the terrain I have from Kill team (tau/reivers set) Ideally I would like another two but I am not sure I can justify how much they will cost. I think they were around £30 a piece before now. actually, What I would really have like is more plasma pipes and possibly a couple of the domes (cant think of the name) but I dont need the other part (achomite stack) as I seem to have about 5 of these already. Oh and possilby some ladders/stairs from 'munda would be good Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041725 Share on other sites More sharing options...
Cactus Posted May 20, 2024 Share Posted May 20, 2024 I really want the set with the utility vehicles. I'm not willing to invest in a table's worth of GW terrain but those little machines can find use in many settings. The generator is great, very 'mad science' and would make an eye-catching objective in all sorts of scenarios but IIRC I already didn't buy because of the price when it was new. History is likely to repeat. Mithrilforge, brother Vorn_GarDos, ThaneOfTas and 2 others 1 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041738 Share on other sites More sharing options...
Jukkiz Posted May 20, 2024 Share Posted May 20, 2024 void shield was originally already 70€ so knowing GW it might be closer to 90-100€ range now. Emperor Ming, brother Vorn_GarDos and ZeroWolf 3 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041820 Share on other sites More sharing options...
brother Vorn_GarDos Posted May 20, 2024 Share Posted May 20, 2024 I might purchase the plasma regulators as they make decent vantage point in kill team games, but it will depend on my mood. No need to talk about price since it will be higher at this point. Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041952 Share on other sites More sharing options...
The Scorpion Posted May 20, 2024 Share Posted May 20, 2024 On 5/19/2024 at 1:29 PM, Wolf Lord Duregar said: Some of this terrain was in Shadow War Armageddon, correct? Pretty good Necromunda stuff.. There used to be a Warcom article on combining Necromunda terrain with Sector Mechanicus and everything Wolf Lord Duregar and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041953 Share on other sites More sharing options...
Wolf Lord Duregar Posted May 20, 2024 Share Posted May 20, 2024 Cool, I´ll see if I can find it! Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6041973 Share on other sites More sharing options...
Firedrake Cordova Posted May 23, 2024 Share Posted May 23, 2024 (edited) On 5/20/2024 at 9:44 PM, The Scorpion said: There used to be a Warcom article on combining Necromunda terrain with Sector Mechanicus and everything The scenery guys - Ray Dranfield and Owen Patten, I think - had threads on their Twitter accounts on combining the kits and doing interesting things with them, if I remember correctly. ++EDIT: Bah, it looks like Ray's deleted his Twitter account Edited May 23, 2024 by Firedrake Cordova Wolf Lord Duregar and Matcap86 2 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6042388 Share on other sites More sharing options...
Bryan Blaire Posted May 23, 2024 Share Posted May 23, 2024 The Sector Mechanicus terrain is exactly two Zone Mortalis “levels” high when using the ZM spacers/walkways, so they link up pretty well. Bouargh and Wolf Lord Duregar 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6042412 Share on other sites More sharing options...
Bouargh Posted May 23, 2024 Share Posted May 23, 2024 5 hours ago, Firedrake Cordova said: The scenery guys - Ray Dranfield and Owen Patten, I think - had threads on their Twitter accounts on combining the kits and doing interesting things with them, if I remember correctly. ++EDIT: Bah, it looks like Ray's deleted his Twitter account Archeology in GW/WarCom site also allows resurrecting similar stuff or googling it with "Zone Mortalis Tip" keywords: you can find back stuff. And many blogs have anyway copied / pasted the advices and pics of all these sources. For example: combining necromunda sector mechanicus - Recherche Google combining necromunda sector mechanicus - Recherche Google And my all times favourite combo: Should they have put this in MTO, I would have (probably) ordered one fragdrill... Next time maybe, with GSC Codex release. skylerboodie, excelite, Mithrilforge and 4 others 2 1 4 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6042416 Share on other sites More sharing options...
Deus_Ex_Machina Posted May 23, 2024 Share Posted May 23, 2024 I can´t find the "Made to Order" section on the GW website. Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6042453 Share on other sites More sharing options...
firestorm40k Posted May 23, 2024 Share Posted May 23, 2024 7 minutes ago, Deus_Ex_Machina said: I can´t find the "Made to Order" section on the GW website. It's in the 'New and Exclusive' section: https://www.warhammer.com/en-GB/new-and-exclusive-lp These terrain pieces will listed here when they go up on Saturday Deus_Ex_Machina 1 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6042455 Share on other sites More sharing options...
Firedrake Cordova Posted May 25, 2024 Share Posted May 25, 2024 (edited) The prices seem to be a bit of a jump from what they were previously... Alchomite Stack is £40 and was £30 Ferratonic Furnace is £40 and was £30 (I think - the Ferratonic Incinerator was £35 in 2019) Plasma Regulators are £25 and were £15 I can't comment on the others as I don't have them (I did some diving through my order history...) Edited May 25, 2024 by Firedrake Cordova Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6042634 Share on other sites More sharing options...
Lord Marshal Posted May 25, 2024 Share Posted May 25, 2024 1 hour ago, Firedrake Cordova said: The prices seem to be a bit of a jump from what they were previously... Alchomite Stack is £40 and was £30 Ferratonic Furnace is £40 and was £30 (I think - the Ferratonic Incinerator was £35 in 2019) Plasma Regulators are £25 and were £15 I can't comment on the others as I don't have them (I did some diving through my order history...) Unfortunately this is par for the course with MTO now. Whether it be terrain or models, the markup from what they were when they were being sold is nearly always noticeable. Mithrilforge and MoriyaSchism 2 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6042643 Share on other sites More sharing options...
Corswain Posted May 25, 2024 Share Posted May 25, 2024 Haemotrope reactors $110AUD when you can still source them in Warhammer Imperium for $20 each? That seems very optimistic, GW. Firedrake Cordova, MoriyaSchism, Deus_Ex_Machina and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/382967-40k-terrain-coming-to-made-to-order/#findComment-6042645 Share on other sites More sharing options...
