Elvatuar Posted January 1, 2025 Share Posted January 1, 2025 (edited) My first 1000 points of my Adepta Sororitas army is coming along nicely. But then something occurred to me. So I've got the old(!) Combat Patrol and the Army of Faith box. The first one includes 5 Seraphim, the latter 10 Seraphim and 5 Zephyrim. What if I took 5 of those Seraphim and painted them up like Zephyrim? Is that a good idea for a 1000-point army? Has anyone else done that? Instead of 15 S and 5 Z, I'd end up with 10 each. The Seraphim would be joined by a Jump Pack Canoness, the Zephyrim probably by Celestine. Edited January 10, 2025 by Elvatuar W.A.Rorie 1 Back to top Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/ Share on other sites More sharing options...
W.A.Rorie Posted January 1, 2025 Share Posted January 1, 2025 It would not hurt but I would run 10 seraphim and 2 5 zephyrim squads Sume and Elvatuar 2 Back to top Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6084318 Share on other sites More sharing options...
Elvatuar Posted January 4, 2025 Author Share Posted January 4, 2025 Thanks for the tip Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6084969 Share on other sites More sharing options...
Emperor Ming Posted January 5, 2025 Share Posted January 5, 2025 (edited) I don't like either I used to have two units always, with a mix of melta pistols, even in units of 5, a few bolt pistol shots could do something (back in the day) Now, a few s4 shots is like being tickled by a feather, and melta pistols are not what they used to be I found zeph useful when they came out, now with the T hikes. They have slid off the scale for me. Useful for what exactly. Killing guardians maybe Edited January 5, 2025 by Emperor Ming Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6085096 Share on other sites More sharing options...
ThePenitentOne Posted January 8, 2025 Share Posted January 8, 2025 I didn't know the Army of Faith box was a 10/5 split- I thought it contained 3 dual build units. If there are only parts for 5 Zephyrim in the box, and there are NO parts for Zephyrim in the Combat Patrol, what parts are you using to build the extra 5 Zephyrim, because a paint job won't make them melee units. If I've interpreted correctly, this makes me glad I didn't buy the box- like you, I wanted 10 and 10, but I would have fielded them as 5/5 and 5/5. Bot if the box doesn't make that possible without conversion/ tinkering, suddenly it's not as good a deal. Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6085855 Share on other sites More sharing options...
Indy Techwisp Posted January 8, 2025 Share Posted January 8, 2025 4 hours ago, ThePenitentOne said: I didn't know the Army of Faith box was a 10/5 split- I thought it contained 3 dual build units. If there are only parts for 5 Zephyrim in the box, and there are NO parts for Zephyrim in the Combat Patrol, what parts are you using to build the extra 5 Zephyrim, because a paint job won't make them melee units. If I've interpreted correctly, this makes me glad I didn't buy the box- like you, I wanted 10 and 10, but I would have fielded them as 5/5 and 5/5. Bot if the box doesn't make that possible without conversion/ tinkering, suddenly it's not as good a deal. The Army of Faith Box just has 3 of the Seraphim/Zepharyim kit, so you can build 3 Seraphim, 3 Zepharyim or 2 of 1 and 1 of the other. Sume 1 Back to top Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6085949 Share on other sites More sharing options...
Elvatuar Posted January 10, 2025 Author Share Posted January 10, 2025 On 1/8/2025 at 7:05 PM, Indy Techwisp said: The Army of Faith Box just has 3 of the Seraphim/Zepharyim kit, so you can build 3 Seraphim, 3 Zepharyim or 2 of 1 and 1 of the other. Yes. That's why I'm faced with a choice. I'll build at least 10 Seraphim, and I'm wondering how many Zephyrim I should build, 5 or 10. Army of Faith box contains the following: 15x Seraphim/Zephyrim 1x Jump Pack Canoness 1x Exorcist Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6086351 Share on other sites More sharing options...
Sume Posted January 10, 2025 Share Posted January 10, 2025 Since I ended up with 8 boxes of this kit. I made 15 zepharim. Then the rest serphaim with all the loadouts. A I couldnt make up my mind on what to make. Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6086417 Share on other sites More sharing options...
Indy Techwisp Posted January 10, 2025 Share Posted January 10, 2025 6 hours ago, Elvatuar said: Yes. That's why I'm faced with a choice. I'll build at least 10 Seraphim, and I'm wondering how many Zephyrim I should build, 5 or 10. Army of Faith box contains the following: 15x Seraphim/Zephyrim 1x Jump Pack Canoness 1x Exorcist I'd say build 10 Zephyrim and 5 Seraphim. You've already got the 5 Seraphim from the old Combat Patrol, so build the 5 Seraphim from the Army of Faith box as the other 5 for a full strength unit (I.e. build the Seraphim Superior as a normal Seraphim), then for the 10 remaining build 5 Zephyrim with a Zephyrim Superior and 5 as regular Zephyrim so you can field a 10-model unit of each. Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6086450 Share on other sites More sharing options...
TheArtilleryman Posted January 10, 2025 Share Posted January 10, 2025 4 hours ago, Sume said: Since I ended up with 8 boxes of this kit. I made 15 zepharim. Then the rest serphaim with all the loadouts. A I couldnt make up my mind on what to make. Urm… how do you “end up with” 8 boxes of a £150 kit? Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6086491 Share on other sites More sharing options...
Indy Techwisp Posted January 10, 2025 Share Posted January 10, 2025 10 minutes ago, TheArtilleryman said: Urm… how do you “end up with” 8 boxes of a £150 kit? 8 very generous friends who don't communicate with eachother about what they're buying for Christmas? W.A.Rorie, TheArtilleryman and RolandTHTG 3 Back to top Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6086494 Share on other sites More sharing options...
Sume Posted January 11, 2025 Share Posted January 11, 2025 Nah I ended up with 8 boxes of the Serphaim/Zephrayim kit during the pandemic lockdowns. I would order one from my local store. Pick it up, then I'd stick it on a shelf with my other stuff of shame. I then would forget that I had them haha. I was planning on getting 4 boxes in total. Then when I was trying to figure out what I wanted next. I was like umm why is there 8 boxes of these. I thought I had more battle sister boxes. Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6086602 Share on other sites More sharing options...
TheArtilleryman Posted January 11, 2025 Share Posted January 11, 2025 6 hours ago, Sume said: Nah I ended up with 8 boxes of the Serphaim/Zephrayim kit during the pandemic lockdowns. I would order one from my local store. Pick it up, then I'd stick it on a shelf with my other stuff of shame. I then would forget that I had them haha. I was planning on getting 4 boxes in total. Then when I was trying to figure out what I wanted next. I was like umm why is there 8 boxes of these. I thought I had more battle sister boxes. Lol so you forgot you had it 4 times? Very convenient W.A.Rorie 1 Back to top Link to comment https://bolterandchainsword.com/topic/384973-seraphim-vs-zephyrim/#findComment-6086665 Share on other sites More sharing options...
