Brother Tyler Posted April 23, 2025 Share Posted April 23, 2025 Wall of text glassy-eyed prevention: This is about the possibility of Space Hulk using larger tiles (squares) to accommodate the bases of the current range of Terminator models. If that interests you, read on. Also, I get a bit wish-listy at the bottom. I've also hidden that in spoilers for those who want to focus solely on the discussion about larger squares. If you've been on the site for any length of time, you know that I can get a bit long-winded. I've hidden portions of pontification and background. Spoiler Some of you may already know that I'm a fan of the Space Hulk game. You can see this in my discussion about the future of Space Hulk (that topic is from 2019 and it's a bit outdated now, so this current topic is a sort of update to it ) as well as my perpetually ongoing Indomitus Project. My more recent effort has been to revisit adapting Space Hulk into the current version of Kill Team, as seen here. However, I saw something on Kickstarter yesterday that got me thinking about the future of Space Hulk (again). To summarize the discussion about Space Hulk that I linked above, my concern at the time was the possible obsolescence of Terminator armour, possibly to be replaced by Gravis armour. With the recent updates to Terminator armour, however, it appears that my concerns were misplaced. This means that GW can republish the Space Hulk game in the future without having to replace the TDA-wearing protagonists of the first four editions of the game. In addition, I saw an advertisement for some magnetic hexagonal map tiles (linky). These are labeled as being for D&D and other tabletop RPGs, but I immediately thought about my Wrath of Angels project, which was an adaptation of Space Hulk featuring power armoured Space Marines versus Orks within an Ork rok during the Third War for Armageddon. The idea there was to use hexagonal tiles, much like the Kickstarter campaign that I linked. My mind then went to the possibility of Space Hulk map tiles being similarly magnetic, and then I thought about the ability for hobbyists to use their WH40K Terminators on proper 40mm bases. For those of you who don't know, the Space Hulk tiles are sized for the 25mm bases of the original Terminator models. Over the years, the bases of Terminator models have grown to 40mm. This makes positioning the Terminators a bit challenging as models on adjacent spaces can push into each other. The Terminator models in the most recent two editions of the game were also much larger and more dynamic than their predecessors, and they didn't have full bases. For example, here's Brother Deino, a "basic" Terminator equipped with a power fist and storm bolter: And that's a bit weedy compared to the new Terminators. If you would like to see what the original Terminators looked like on their 25mm bases, check out this Warhammer Community post from 2023. When the Terminator models in the last two editions of the game (the same models in both editions) were positioned adjacent to each other, which was typical during initial setup, things could get a bit complicated, especially with the fixed positioning of their arms and weapons, which often extended beyond the legs/bases. Many players, too, put those Space Hulk Terminators on round bases. This made them a bit more stable and allowed them to be used in games of Warhammer 40,000. So after seeing those magnetic tiles, I considered the possibility of similar tiles for Space Hulk, but up-sized to either 40mm or 50mm squares instead of the current 25mm squares. And then my thoughts moved from magnetic tiles to simply up-sized tiles, whether using thick card as in the game box or some other material (players have used plaster of Paris, 3D printing, printed paper, etc. for their personal efforts). That is a considerable increase in size, and while it would make it much easier to keep the Terminators from falling over and/or pushing into each other, it would increase the cost of the game and likely the size of the box. Another possible effect would be on the Genestealers. The hypothesized 40mm/50mm tiles would still limit the Terminators to one model per square, but with larger squares, it would be possible to fit multiple Genestealers on the same square. It would be easy to preserve the one model per square limit on the Genestealers, but it would also be possible to modify the rules to allow two Genestealer models on the same square. This would have an impact on both the rules (which wouldn't need to be changed on account of the Terminators) and tactics (which could be significant). At this point, I'm not suggesting that Games Workshop will do this. This is more of an academic discussion for homegrown application. I considered putting this in the Homegrown Rules forum, but there's a bit of wish listy thought going on, too. So the focus at this point is discussing how the rules/tactics might change if two Genestealer models were allowed on the same (larger) square. A given (in my mind) is that nothing would change for the Terminators. All current (3rd/4th edition) rules would remain in effect without modification. The only impact on them would be the physicality of the models - much less interference between adjacent models. With the possibility of two Genestealers on the same square, however, there are some potential consequences. I could see the following: A blip and the Broodlord both count as a "Genestealer model" below. Genestealer models can move into/through a square if there is only one other Genestealer model on that square. At the end of any Genestealer model's movement, there may be no more than two Genestealer models on a square. When blips are turned over and Genestealer models are placed, the first Genestealer model must be placed on the square in which the blip was located. If the revealed blip shows 2 or more Genestealers and there is only one Genestealer model on the square, the second Genestealer must also be placed on that square. Additional Genestealer models must be placed on adjacent squares per the current rules. Those are the main rules effects that I've come up with. Can you think of anything else? The tactical considerations become more interesting. More worrisome, things become much more dangerous for the Terminators. Under the current rules, no model may move through another model. If Genestealers are allowed to move through spaces occupied by other Genestealers, however, things get rough, especially since, under the current rules, Terminators on Overwatch can only shoot at the Genestealer that triggered the Overwatch (e.g., it moved) and the Genestealer in front (i.e., the one nearest the Terminator) would effectively block the overwatch Terminator's LOS to the moving Genestealer. This would effectively allow a Genestealer to screen the movement of other Genstealers, possibly enabling those other Genestealers to reach the Terminator and perform their own close assault action with the Terminator only able to perform an overwatch shooting action on the turn(s) the acting Genestealer moves into/through the front Genestealer (and subsequent moves in the front Genestealer wasn't adjacent to the overwatch Terminator). Anyone who has played Space Hulk knows that overwatch is one of the invaluable tactics available to the Terminators. And given the default difficulty of the game, any degradation of overwatch can make things even more difficult (and less fun) for the Space Marine player. Canny placement and movement of Genestealers, on the other hand, is a key component of the Genestealer tactics. In this, being able to have a Genestealer block the Terminator's LOS to other Genestealers is a great screening technique, allowing the Genestealer player to move hordes of gribblies closer to the Terminators. Any attempt to adjust rules to offset balance for one must consider the other, trying to achieve a change that preserves the current balance of power. Or perhaps no change is needed...? So what could be done? My initial idea is that the overwatch shooting attack of a Terminator might target both Genestealers on the turn(s) that the acting Genestealer moves into and from the same space as another Genestealer model. If the Terminator's shooting attack rolls result in only one success, the acting Genestealer would be shot, with the other Genestealer only being shot if two successes are rolled (with doubles having the normal jam result). In practice, this will enable the Genestealer player to move Genestealers without them getting shot up when they move per the current rules, but it will give the Space Marine player chances to shoot the Genestealers when they take advantage of the multiple Genestealer models per square rule. Consider the situation shown in the diagram at left. The Terminator is in the square marked with the red crux and is facing down the corridor towards the Genestealer models (the circles with crosshair reticles) while on overwatch. Genestealer 1 (G1) is in the square marked with the green circle with crosshair reticles while Genestealer 2 (G2) is in the square marked with the purple crosshair reticles. In this situation, G1 has somehow moved into that position without getting shot and now the Genestealer player is activating G2. Under the current rules, with Genestealers unable to move into/through squares occupied by other models, G2 would be able to move up to the space marked "B" without any problem because G1 is blocking LOS for the Terminator. Under my hypothesized rule, if G1 is the only Genestealer model in that square, G2 could move into that square, and could continue moving forward into the space marked "C." In addition, the Terminator would be able to make overwatch shooting attacks against both G1 and G2 when G2 moves into the square with G1 as well as if (when) G2 moves into the square marked "C." If the Terminator fails to kill the Genestealer with his overwatch shooting attacks, the Genestealer would be able to use its remaining action points to perform close assault actions. If the Terminator were in the space marked "C," things would be much worse for him as he would have only one overwatch shooting action against G2 before the Genestealer performs its close assault actions. In both cases, while there is a clear benefit for the Genestealer player, the chance that the Space Marine player has the potential to destroy both Genestealers might even the odds a bit. Now for some wish-listy stuff that isn't quite related to this hypothesized up-sizing of the tiles. I'll hide this stuff in spoilers so that those players who aren't interested in wish-listing can just skip it. Spoiler The core of wish-listing is that Games Workshop might one day re-release Space Hulk. At the most basic level, this might simply be the 2014 version ("4th edition") all over again, without any changes. A slight variation on this might be to incorporate the mission packs in a more accessible format. My ideal there is that each would be published as a small expansion featuring the mission book and bespoke Terminator models suitable to the Chapter (Dark Angels for Bringer of Sorrow, Ultramarines for Duty and Honour, and Space Wolves for Return to Kalidus). While each of those campaigns used different map tiles in their original 1st/2nd edition iterations, Games Workshop modified the maps to use the map tiles found in the 3rd/4th edition Space Hulk box. Many fans of these Chapters would purchase these expansions for the models alone, even if they don't play Space Hulk. A bit more wish-listy: I wouldn't mind GW reverting the 4th edition mission pack maps to the original maps if they included the tiles in the expansion boxes. Even more wish-listy: Similarly, I'd love to see some mini-campaigns featuring other Chapters, too (see the link to my Indomitus Project for more on that). Each of these might feature 3 or so unique missions/maps, incorporating those into restructured missions from the core box. Any unique tiles would be included in those expansions, though they wouldn't necessarily be able to mix and match (i.e., each mini-campaign's maps would use only the tiles found in that mini-campaign's expansion and the tiles found in the core box). Each expansion would also include the appropriate Terminator models. I'd love to see bespoke black Black Templars Sword Brethren Terminators in a campaign, yellow Imperial Fists Terminators in another campaign, green Salamanders Terminators in yet another campaign, etc. Where Blood Angels players love the Space Hulk Terminators in their Warhammer 40,000 armies, fans of other Chapters would similarly love bespoke characterful Terminators for their favorite Chapters, too. And the pipe dream: I'd love to see GW provide continued support for Space Hulk by separating things a bit. The tiles would be great either as printed card (the current version) or plastic/resin. GW could then use these for Boarding Actions and Kill Team as an augmentation to the Gallowdark terrain. And if there is any place where GW can dip their toes into 3D printing and selling .stl files, it's in Space Hulk tiles. They could then sell the rules, missions, and accessories (timer, blips, command point markers, mission status board, etc.) as a package. Players could then purchase the Genestealer and Terminator models that they need based on the requirements of the campaign. GW might still sell the whole shebang as a full/deluxe package, but selling in three distinct groups (terrain, rules and accessories, Terminator/Genestealer models) opens things up for players. I don't see GW ever doing this (FOMO is a core element of their sales/marketing strategy, after all), but I can dream. apologist, LameBeard and firestorm40k 3 Back to top Link to comment https://bolterandchainsword.com/topic/385742-space-hulk-but-for-40mm-terminator-bases/ Share on other sites More sharing options...
apologist Posted April 24, 2025 Share Posted April 24, 2025 The Space Hulk ruleset is a timeless classic, but I'm always happy to see riffs on the formula for new editions of boardgames, as the original remains complete – win–win, as far as I'm concerned. Hex-based Space Hulk is a neat idea, and has a lot of potential to work well. On the practical side it helps to avoid 40mm bases abutting on adjacent tiles, while on the aesthetic side it helps keeps things appropriately tight and claustrophobic-feeling – I've seen some lovely scratch-made boards that accommodated 40mm bases, but the effect went from cramped tunnel fighting to a struggle through expansive halls. Ruleswise, hexes would be a nice way to add a few twists to the mechanics. Terminators could block LoS through the hex – unless the firing unit was directly behind it, representing the front Marine manouevring to allow a comrade to lean round and lend support. In current Space Hulk, you usually (but not always) want to leave space between Marines to maximise your reaction time if one gets killed, so this would provoke interesting tactical choices. For the genestealers, larger hexes would work well with your idea of doubling up models in spaces, with the concomitant tweaks to the rules you outline in the example above – another feature that would emphasise the asymmetric nature of the game. Either way, very interesting – something to chew over! LameBeard and Brother Tyler 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385742-space-hulk-but-for-40mm-terminator-bases/#findComment-6106435 Share on other sites More sharing options...
Mandragola Posted April 25, 2025 Share Posted April 25, 2025 One thing you might do on 40 or 50mm bases is to put two or three Genestealers on a base but not change the rules at all, just counting it as a single Genestealer with today's rules. You could then model them leaping, swinging off pipes, popping out of hatches and so on to create more of an effect of a swarm of stealers coming towards the terminators. Actually putting multiple separate models in a square is always going to be tricky, especially for Genestealers, with their arms poking out in every direction. But multi-basing could offer some great conversion opportunities without requiring any changes to the rules. You could even try square bases for all your models, featuring detail to match the board they're fighting over. Cactus, apologist, Brother Tyler and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/385742-space-hulk-but-for-40mm-terminator-bases/#findComment-6106611 Share on other sites More sharing options...
Brother Tyler Posted April 30, 2025 Author Share Posted April 30, 2025 (edited) While I wasn't aiming to work on hex-based Space Hulk, I love the idea. My earlier project idea was to replace the square tiles of Space Hulk with hexes. After seeing the modular magnetic tiles, however, I've been wondering if something like those tiles might work. The hex tiles have smaller hexes printed on each tile, though those appear to be too small to support 40mm Terminator models (assuming you want to keep each space large enough for a single model). Still, I'd love to pursue this idea as a set of variant Space Hulk rules (or, in line with my previous project, an adaptation using power armoured Space Marines versus ... something). I think that @Mandragola's square base idea is interesting. It works great for players that only intend to use their models for Space Hulk, but is much less workable for the many players that want to use their models, whether Terminators or Genestealers, in both Space Hulk and Warhammer 40,000. I suppose one possible option there is to simply magnetize the existing model bases so that they can be temporarily affixed to square tiles when playing Space Hulk. What the idea doesn't solve, however, is the size of the Terminators (and their bases) compared to the sizes of the squares on the Space Hulk terrain. The idea about mounting multiple Genestealers on a [larger] base is also intriguing, but I worry that it might become confusing for some players. The imagery of a small horde of Genestealers approaching is certainly thematic, but it might become problematic from a game play perspective. I definitely agree that trying to get multiple models in the same space, whether square or hex, will be challenging. I suppose the easy answer for my idea (KISS) is to simply upsize the squares to 40mm without any attendant rules changes. Either that or go the Space Marine Adventures [games] route and simply use tokens for the Genestealers if my idea of multiple Genestealers per space is viable. Most players don't like that option in the Space Marine Adventures games, however, and I seriously doubt that most would like it in Space Hulk. Edited May 5, 2025 by Brother Tyler Link to comment https://bolterandchainsword.com/topic/385742-space-hulk-but-for-40mm-terminator-bases/#findComment-6107373 Share on other sites More sharing options...
LameBeard Posted May 6, 2025 Share Posted May 6, 2025 Some intriguing ideas here. One worry I have about 40mm squares is just how massive the board is now, it’s gonna spill over the edge of the kitchen table. You rightly consider how terminators have had more scale creep than genestealers, but maybe they’ve had more power creep too? So one possibility it just substitute genestealers for tyranid warriors or ravenors or lictors or whatever and keep the rules the same. It’ll capture some of the original feel by looking more scary! I am currently working on a dungeon-crawl inspired partly by Advanced Heroquest. Why is this relevant? Because I have a similar scale creep problem. Originally, bases were typically 25mm but the board squares only about 22mm. So squeezing models has always been a thing! So I think the square base approach could work. Assume squares approx 30mm (not actually that different, because previously we had some margin around the base). Terminators at current scale but on 30mm square base, so margin gone. The diagonal on a 30mm base is actually more than 40mm, so it still accommodates a wide range of poses. GW could release terminators with no tactical rocks and pegs on the feet. And then put 30mm square bases in the box, sell a set of alternative 40mm round bases (could be sculpted) as an upgrade for people taking their terminators to 40k. Swapping using pegs isn’t ideal, but it’s doable, so doesn’t force magnets. Link to comment https://bolterandchainsword.com/topic/385742-space-hulk-but-for-40mm-terminator-bases/#findComment-6108099 Share on other sites More sharing options...
Brother Tyler Posted September 24, 2025 Author Share Posted September 24, 2025 Seeing the new Assault Terminators made me think of a new idea. This only works if Games Workshop gives us a totally new Space Hulk edition (5th, or, if you're like me and consider the 2014 version to be 3.5th instead of 4th, a proper 4th ). In this scenario, the new Terminator models would come with the base style that you see in Brother Noctis, below... ...(I forget what the style is called). In addition, there would be round bases for each of the models, each shaped so that the model could be glued in place with their integral bases fitting into shaped depressions (i.e., each model would have a base that works only for them). The more likely scenario for this to happen would be if the hypothetical Space Hulk 5e (4e!) models are also sold in separate boxes for use/inclusion in the Warhammer 40,000 game. Yes, similar bases would be available for the Genestealers. If we assume that the SH5e (4e!) Terminators are embiggened to match the size of the mainstream Warhammer 40,000 Terminators, they'll already be large enough to be even more problematic size-wise for the SH tiles, but leaving them off the 40mm round bases would probably make them work tolerably. Circling back to the input provided by @apologist, @Mandragola, and @LameBeard, I've begun to wonder if it might be worthwhile to adapt Space Hulk concepts into a different setting. My first instinct in that vein is to revisit the Third War for Armageddon and the campaign to purge the Ork roks (using larger hexes) and space hulks/other Ork vessels (using the existing SH tiles). This would be a great campaign in which to feature the Black Templars and the handful of other Chapters that participated in these actions. Hmmm... something to ponder upon and, hopefully, pursue if I ever find the free time. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/385742-space-hulk-but-for-40mm-terminator-bases/#findComment-6133582 Share on other sites More sharing options...
LameBeard Posted October 1, 2025 Share Posted October 1, 2025 The answer might be the other way round: replace terminators with chonky and not-agile alternatives: orks in mega-armour, or exo-armour squats. Let them shoot bugs (and stand on smaller bases!) Link to comment https://bolterandchainsword.com/topic/385742-space-hulk-but-for-40mm-terminator-bases/#findComment-6134530 Share on other sites More sharing options...
