Doobles57 Posted June 19, 2025 Share Posted June 19, 2025 11 minutes ago, Fire Golem said: It does specify that that rule is what protects you from your own plasma weapon specifically. I think Overload does work differently to how Gets Hot did yeah. Possible that Overload causes a hit on the bearer rather than a wound now? So lowering the strength on hits from it's own plasma as well as your opponents would matter then? Just a guess. Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117385 Share on other sites More sharing options...
Nephaston Posted June 19, 2025 Share Posted June 19, 2025 20 minutes ago, Bradeh said: Another cheeky note is that the AP3 template Particle Shredder that comes with the Termies isn't included in the box for the Dread. Presumably these are included in the Grav/Inversion kit. Or maybe even just using the bits from the terminators if going for any of the fist-less configurations. Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117386 Share on other sites More sharing options...
Fire Golem Posted June 19, 2025 Share Posted June 19, 2025 3 minutes ago, Nephaston said: Presumably these are included in the Grav/Inversion kit. Or maybe even just using the bits from the terminators if going for any of the fist-less configurations. Yeah they come with the other weapons: Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117387 Share on other sites More sharing options...
Gorgoff Posted June 19, 2025 Share Posted June 19, 2025 2 hours ago, Jarl of Wulfen said: Interesting that the grav pulverizer is considered plasma not grav. Typo? Typo. They changed it in the mean time. SalamandersBro, Jarl of Wulfen, DarkChaplain and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117388 Share on other sites More sharing options...
Captain Idaho Posted June 19, 2025 Share Posted June 19, 2025 (edited) 1 hour ago, BitsHammer said: Honestly I'm just sad there isn't a new Volkite thing for it. And I don't think you're wrong about the points spread but honestly I look at it and think less "which is the strongest option for points" and more "what would Night Lords be most likely to equip one of these with?" Sure we can chase the meta but I'm constantly being told that 30k is supposed to be the narrative driven game and I personally would like to lean into that. Narrative play is hurt even more. If you invest into the game an expensive Saturnine Dreadnought with dual Disintegrators because your theme is Destroyers, then you come up against a Saturnine Dreadnought with dual Graviton Pulverisers for just 20pts more... then he wipes the floor with your choice and this is repeated every week because you've used too many points in broken choices for theme... ...how much fun will you really have? 23 minutes ago, Doobles57 said: Possible that Overload causes a hit on the bearer rather than a wound now? So lowering the strength on hits from it's own plasma as well as your opponents would matter then? Just a guess. They explained previously that Overload results is your weapon hitting your own unit. So Disintegrators are death traps with no place on expensive models like Saturnine Dreadnoughts and Terminators. Edited June 19, 2025 by Captain Idaho Aarik and DarkChaplain 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117390 Share on other sites More sharing options...
SalamandersBro Posted June 19, 2025 Share Posted June 19, 2025 I don't know about anyone else. I appreciate the icons in the upper left on the datasheets. Now i won't get confused on the images for the force organization chart. Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117391 Share on other sites More sharing options...
Gorgoff Posted June 19, 2025 Share Posted June 19, 2025 9 minutes ago, Captain Idaho said: Narrative play is hurt even more. If you invest into the game an expensive Saturnine Dreadnought with dual Disintegrators because your theme is Destroyers, then you come up against a Saturnine Dreadnought with dual Graviton Pulverisers for just 20pts more... then he wipes the floor with your choice and this is repeated every week because you've used too many points in broken choices for theme... ...how much fun will you really have? Most people play a different army list in every game so I don't aee the problem. DarkChaplain 1 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117392 Share on other sites More sharing options...
Vassakov Posted June 19, 2025 Share Posted June 19, 2025 1 minute ago, Captain Idaho said: Narrative play is hurt even more. If you invest into the game an expensive Saturnine Dreadnought with dual Disintegrators because your theme is Destroyers, then you come up against a Saturnine Dreadnought with dual Graviton Pulverisers for just 20pts more... then he wipes the floor with your choice and this is repeated every week because you've used too many points in broken choices for theme... ...how much fun will you really have? But you should probably be building a balanced overall force, no? Like, we can get all up on X unit with guns equipped for targeting Y will be very one sided, but part of the game is (or at least should be) making sure your army is capable of responding to different threats and then trying to fight on favourable terms with your opponent. AP2 is also nothing to sneeze at, it's clearly an Anti-Terminator/Artificer option. Also, take it from someone with Mhara Gal Dreadnoughts - BS3/4 3" blasts are not reliable at hitting more than a couple of models. And if your point is that if you take a very themed list, you may well run into a bad match up... yes? That's always been the case hasn't it? DarkChaplain 1 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117393 Share on other sites More sharing options...
jaxom Posted June 19, 2025 Share Posted June 19, 2025 1 hour ago, Bradeh said: They said the Thermal Field mitigates Overload damage, just have to find out in what way. 32 minutes ago, Doobles57 said: Possible that Overload causes a hit on the bearer rather than a wound now? So lowering the strength on hits from it's own plasma as well as your opponents would matter then? Just a guess. ^That is correct. Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117394 Share on other sites More sharing options...
Marshal Rohr Posted June 19, 2025 Share Posted June 19, 2025 (edited) 16 minutes ago, Captain Idaho said: Narrative play is hurt even more. If you invest into the game an expensive Saturnine Dreadnought with dual Disintegrators because your theme is Destroyers, then you come up against a Saturnine Dreadnought with dual Graviton Pulverisers for just 20pts more... then he wipes the floor with your choice and this is repeated every week because you've used too many points in broken choices for theme... ...how much fun will you really have? They explained previously that Overload results is your weapon hitting your own unit. So Disintegrators are death traps with no place on expensive models like Saturnine Dreadnoughts and Terminators. Your double disintegrators have 6 inches on the GraviSat, so you can back pedal away and peel his wounds off if the other person is trying to do a Sattie duel. The Saturnine actually looks more balanced than I thought it would be. It would’ve been very easy to make that grab weapon 24 inches or the Inversion Beamer an auto take. Edited June 19, 2025 by Marshal Rohr DarkChaplain 1 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117395 Share on other sites More sharing options...
Captain Idaho Posted June 19, 2025 Share Posted June 19, 2025 The rules for weapons new Saturnine Dreadnoughts and Terminators are poor and I won't be buying the new boxed set because of it. I have no need and won't buy something with money I can't afford just because "narrative". And if I don't like something or buy it, that means other people won't... 15 minutes ago, Marshal Rohr said: Your double disintegrators have 6 inches on the GraviSat, so you can back pedal away and peel his wounds off if the other person is trying to do a Sattie duel. The Saturnine actually looks more balanced than I thought it would be. It would’ve been very easy to make that grab weapon 24 inches or the Inversion Beamer an auto take. The double Disintegrator Saturnine Dreadnought fires 4 shots that Overload every 1-2 with a S9 hit and D3! Roll some dice and simulate a 4 turn game and see how much damage it takes just from itself. 17 minutes ago, Vassakov said: But you should probably be building a balanced overall force, no? Like, we can get all up on X unit with guns equipped for targeting Y will be very one sided, but part of the game is (or at least should be) making sure your army is capable of responding to different threats and then trying to fight on favourable terms with your opponent. AP2 is also nothing to sneeze at, it's clearly an Anti-Terminator/Artificer option. Also, take it from someone with Mhara Gal Dreadnoughts - BS3/4 3" blasts are not reliable at hitting more than a couple of models. What's balanced about a 340pts model that can't kill much because it has double Heavy Plasma bombards, or heavy Disintegrators that kills it every game and makes it weak to being finished off by enemy fire? If you want AP4 weapons, take heavy bolters on something. If you want AP2 S9 weapons, take Lascannons that won't kill you every game when you're 340pts. Gorgoff, Aarik, DarkChaplain and 1 other 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117396 Share on other sites More sharing options...
Bradeh Posted June 19, 2025 Share Posted June 19, 2025 (edited) How about we get some test games in first with all the rules at our disposal before chucking wobblys? This level of analysis doesn't do anyone any favours. Heresy meant to be the more adult game. Edited June 19, 2025 by Bradeh Gorgoff, TwinOcted, Brother Kraskor and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117399 Share on other sites More sharing options...
Mogger351 Posted June 19, 2025 Share Posted June 19, 2025 14 minutes ago, Captain Idaho said: The rules for weapons new Saturnine Dreadnoughts and Terminators are poor and I won't be buying the new boxed set because of it. I have no need and won't buy something with money I can't afford just because "narrative". And if I don't like something or buy it, that means other people won't... The double Disintegrator Saturnine Dreadnought fires 4 shots that Overload every 1-2 with a S9 hit and D3! Roll some dice and simulate a 4 turn game and see how much damage it takes just from itself. What's balanced about a 340pts model that can't kill much because it has double Heavy Plasma bombards, or heavy Disintegrators that kills it every game and makes it weak to being finished off by enemy fire? If you want AP4 weapons, take heavy bolters on something. If you want AP2 S9 weapons, take Lascannons that won't kill you every game when you're 340pts. Come on, its been shown that matched play (lol) games are 4 turns as standard somewhere iirc. So that's 16 shots with 2 disintegrators as a maximum output whole game. Of those, 5 and a bit overload. Of those, we can round up to 3 wounds, 1.5 saved, it's taken off half its health over the course of a full game in the unlikely scenario it fires full whack all game. In return, whilst im not sure what the secondary weapons do, if we massage the maths using them and assuming terminators are a 5++ (not sure if its been seen?) It will take out a unit of terminators. That sounds tame based on the exchange rate in 40k, but the numbers aren't worse than a unit of 10 lascannons using my fingers for maths. (I have fingers and can use a keyboard, so obviously my intelligence stat is high) 9 minutes ago, Bradeh said: How about we get some test games in first with all the rules at our disposal before chucking wobblys? This level of analysis doesn't do anyone any favours. Heresy meant to be the more adult game. Not sure i agree with adult. Just different audience. Gorgoff and DarkChaplain 2 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117400 Share on other sites More sharing options...
Captain Idaho Posted June 19, 2025 Share Posted June 19, 2025 We heard that from people when 40K released 10th and Eldar were broken as hell, then those same people tried to tell us the evidence of Eldar and our own experience was wrong... then GW changed Eldar several times and those same people were happy GW did that because they know what they're doing. So throwing implied insults about from a position of superiority, that "it's supposed to be adult game" does nothing to prove a point. Indeed, it's being mature and understanding the rules dynamic that enables us to see where the game mistakes are. 20 hours ago, Mogger351 said: Come on, its been shown that matched play (lol) games are 4 turns as standard somewhere iirc. So that's 16 shots with 2 disintegrators as a maximum output whole game. Of those, 5 and a bit overload. Of those, we can round up to 3 wounds, 1.5 saved, it's taken off half its health over the course of a full game in the unlikely scenario it fires full whack all game. So good odds it'll lose 3-6 wounds every game from itself on average... That's awful! It only has 8 wounds and costs 340pts! Aarik and DarkChaplain 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117401 Share on other sites More sharing options...
Marshal Rohr Posted June 19, 2025 Share Posted June 19, 2025 20 minutes ago, Captain Idaho said: The rules for weapons new Saturnine Dreadnoughts and Terminators are poor and I won't be buying the new boxed set because of it. I have no need and won't buy something with money I can't afford just because "narrative". And if I don't like something or buy it, that means other people won't... The double Disintegrator Saturnine Dreadnought fires 4 shots that Overload every 1-2 with a S9 hit and D3! Roll some dice and simulate a 4 turn game and see how much damage it takes just from itself. What's balanced about a 340pts model that can't kill much because it has double Heavy Plasma bombards, or heavy Disintegrators that kills it every game and makes it weak to being finished off by enemy fire? If you want AP4 weapons, take heavy bolters on something. If you want AP2 S9 weapons, take Lascannons that won't kill you every game when you're 340pts. Overload is just a hit, you still do wounds and saves. DarkChaplain 1 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117404 Share on other sites More sharing options...
Captain Idaho Posted June 19, 2025 Share Posted June 19, 2025 3 minutes ago, Marshal Rohr said: Overload is just a hit, you still do wounds and saves. Yep. Try rolling it out, 4 shots a turn for 4 turns and see how much damage it causes. Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117406 Share on other sites More sharing options...
Mogger351 Posted June 19, 2025 Share Posted June 19, 2025 4 minutes ago, Captain Idaho said: So good odds it'll lose 3-6 wounds every game from itself on average... That's awful! It only has 8 wounds and costs 340pts! Im sort of coming round to your way of thinking, simply because it's preferred prey are also rocking Invulns. Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117408 Share on other sites More sharing options...
Captain Idaho Posted June 19, 2025 Share Posted June 19, 2025 3 minutes ago, Mogger351 said: Im sort of coming round to your way of thinking, simply because it's preferred prey are also rocking Invulns. Yeah! And I'm very much of the theme of wanting a Destoyer themed Dread with illegal and shaded weapons like disintegrators! Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117409 Share on other sites More sharing options...
Marshal Rohr Posted June 19, 2025 Share Posted June 19, 2025 4 minutes ago, Captain Idaho said: Yep. Try rolling it out, 4 shots a turn for 4 turns and see how much damage it causes. I got two Overloads in four turns and only wounded once and saved it. It’s risky, but it’s not Moritat with Disintegrators risky Brother Sutek 1 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117410 Share on other sites More sharing options...
Captain Idaho Posted June 19, 2025 Share Posted June 19, 2025 Just now, Marshal Rohr said: I got two Overloads in four turns and only wounded once and saved it. It’s risky, but it’s not Moritat with Disintegrators risky Oh that was lucky, in that case it's the results we'll all get! Lord Abaia, lokkorex and DarkChaplain 3 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117411 Share on other sites More sharing options...
Misterduch Posted June 19, 2025 Share Posted June 19, 2025 (edited) How about giving it a break. We don't even know how the thermal shielding thingy works with overload so doing some math and proclaiming that disintegrators with overload 2 are unusable is wild Edited June 20, 2025 by Xenith language lokkorex, Brother Kraskor, Gorgoff and 2 others 1 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117412 Share on other sites More sharing options...
CommissarXin Posted June 19, 2025 Share Posted June 19, 2025 Everyone is being soo negative when we have yet to have the full rules for everything. Just..be patient. DarkChaplain, Gorgoff and MoriyaSchism 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117415 Share on other sites More sharing options...
Captain Idaho Posted June 19, 2025 Share Posted June 19, 2025 Games Workshop literally told us the rules, including how shielding works, in the article they published. DarkChaplain 1 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117416 Share on other sites More sharing options...
dicebod Posted June 19, 2025 Share Posted June 19, 2025 11 minutes ago, Captain Idaho said: Games Workshop literally told us the rules, including how shielding works, in the article they published. Come on my guy. Writing out how something *generally* works is one thing, seeing the actual rule text is something else. DarkChaplain and lokkorex 2 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117417 Share on other sites More sharing options...
CommissarXin Posted June 19, 2025 Share Posted June 19, 2025 And it's still in a vacuum. We do not have all the rules for the game. And even if it's not how people want it..that's ok. DarkChaplain and Antarius 2 Back to top Link to comment https://bolterandchainsword.com/topic/385821-new-edition-or-just-horus-hearsay/page/96/#findComment-6117418 Share on other sites More sharing options...
