Karack Blackstone Posted September 27, 2025 Share Posted September 27, 2025 Hello again, been a while. Asking a question I've searched for and found nothing as of yet. How would you, dear reader, make the Rogal Dorn Tank for the Only War RPG? Simple enough question, which still begs the question of how does one go about doing this exactly? Please advise, Thanks, Karack. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/386776-only-war-rpg-rogal-dorn-tank/ Share on other sites More sharing options...
Mazer Rackham Posted September 27, 2025 Share Posted September 27, 2025 (edited) Hail Karack, Welcome back! For an RD, I think I'd try an amalgam of Leman Russ and Baneblade: Baseline Leman Russ AV +10 to Front, +5 Side, +5 Rear Structural Integrity +10/+15 Double Battle Cannon BC + Twin-Linked Oppressor Cannon Vanquisher cannon, but Range 1k, Pen 20 I think the other guns are in the other Splatbooks Size + 1 Step from Leman Russ Manoeuvre -20/-25 Crew 9 And have a play around until happy. YMMV. Hope this helps! Edited September 27, 2025 by Mazer Rackham jaxom 1 Back to top Link to comment https://bolterandchainsword.com/topic/386776-only-war-rpg-rogal-dorn-tank/#findComment-6133925 Share on other sites More sharing options...
Karack Blackstone Posted September 28, 2025 Author Share Posted September 28, 2025 I would figure it's about halfway between a Leman Russ and a Baneblade, so you're likely close, would have to find out if / how and what changes if any to make, that's for sure! I do have an idea for a Guard Regiment, the problem would be figuring out how PC's could be playable as such, given that most of the NPC's are built as such, although they'd be normal outside of that, just with Ogryn Bodyguard Wounds as the Regiment is a slight bit more robust than normal, for about 100 XP to pick up the added Wound rank for NPC's. Anyway, thanks much, food for thought, and indeed, while my mileage may vary, the help is greatly appreciated! Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/386776-only-war-rpg-rogal-dorn-tank/#findComment-6133989 Share on other sites More sharing options...
Mazer Rackham Posted September 28, 2025 Share Posted September 28, 2025 Welcome! Building statblocks is much more of a pain than actually lending them... Feel free to toss around ideas in the Nook, or the RPG (NIght) Club as well, if you get stuck, as the old gang from here is now coagulated across there, and may give you a few more eyes on with your projects. Cheers! Link to comment https://bolterandchainsword.com/topic/386776-only-war-rpg-rogal-dorn-tank/#findComment-6134016 Share on other sites More sharing options...
