Hi all,
As a first job I will start with some ooP Epic stuff. There will be 2 Devastator cards btw.
I am not too sure how it fits in the matrix, but I may propose that each Company accounts for a Battleline Entry and all the rest combined as an Elite Entry.
https://bolterandchainsword.com/topic/387350-bouargh%E2%80%99s-bunker-bingo-26/
Nice one! Great to see some OOP bits here too!
Thst sounds sensible to me :thumbsup: I shall take it to the High Lords... *shuffle shuffle*
  • 3 weeks later...
And here come my first units to start filling the card:
- Tactical Company
- Veteran Company
- 2 Devastator detachments, one Inquisitor and one Speeder detachment
This will complete 2 entries for Rank & File and 1 entry for Elite
What's next? I will wait for feb, but, staying with Epic, a Warlord as God of War entry is likely. I also have a full Land Raider Company, So, more Monsters and Machines. Yet, I do not have Psykers to complete the column. Yet...
  • 2 weeks later...
- Tactical Company
- Veteran Company
Looking good! I haven't yet gotten into Epic40K in my hobby journey. Have you played any games? Are the games fun?
I haven't played a single game of Space Marine (ooP EPIC) since ... 1995 or 96. My last game was a few months after the release of Titan Legions with my unpainted SM supporting Titans from another player in a multiplayer game. Before that I used to play only a few games as it has been more of a compulsory investment than a gaming group centered project. My area was lacking of contenders... And after that, real life matters sent forced me to disconnect from the hobby quite a lot: no time and no money.
When I have been able to get time to consider coming back,Epic 40000 was freshly released and the play tests I've had in GW store did not pleased me at all. So I stopped everything on the matter until resuming painting more or less recently :cuss:. I passed my frustration buying FW Wave Serpents that I ended up painting... in 2023. :confused:
But as far as I am concerned, the initial versions of Epic (Space Marine namely) were  fun, fast, and required less space than WFB or 40k. A winning trio? Not really as individual models beyond the plastic boxes were expensive.... for my wealth at the time.
I have just dropped an eye on my card and I realized I virtually have no model in my backlog for psykers or supernatural:confused:.
It is therefore problematic to fill row and file. Should I use this GW discount voucher I have to add such categories either for my Eldar or Dark Eldar forces?
While I think about it I guess I will resume painting in fev with more ooP Epic. May be a Warlord Titan for the God of War slot…
Edited by Bouargh
9 hours ago, Lathe Biosas said:
I'm sure there's a Librarian in one of your Command Squads. :thumbsup:
I have none unpainted. Yet. But in a few days I will have as I just redeemed my voucher (which was best before monday next). Eldrad and some (zombie) Wraithguard will do it.
It is therefore problematic to fill row and file. Should I use this voucher to add such categories either for my Eldar or Dark Eldar forces?
Yes... this is also going to be problematic for me as a Black Templars player...!
I'm in two minds about this - do we voucher it? Or do we own it and force ourselves to do a side project to get the square.
Maybe I should open that discussion out to the rest of the club?
A discussion would be OK and helpful; within such a frame I might propose for example that a "divergence" rule could be set such as for example: "you can substitute by any other category of the card BUT with a penalty", such as marking 50% of the poinst only...
Just a though
Edit: BTW, I've used my discount voucher to add Eldrad and Wraithguards to my collection, so I will have 2 entries as side projects that comply with the current card requirement (if Wraithguards are considered as undead thingies).
Edited by Bouargh
In a mind set of capitalizing all my WIP stuff, I will add to my card the following elements in the associated categories:
- 10 Drukharii Wytches - Rank and File
- 1 piece of custom scenery - Paint Something
- 1 ooP Epic Warlord Titan - Gods of War
I might even do more if my Psychics are delivered... Otherwise I have all the Epic stuff mentionned last month still in the queue for being painted.
Beware: fresh glue! ALthough I glued the filler last saturday it is so cold and wet outhere in my garage that it does not dry... to be moved in the kitchen above the fridge where motor and heat exchanger made it always warmer...
So I have had a think about this, and I think the voucher approach may be a good idea. A square can be substituted for 'paint something' but you lose 50% of the points for it. I may be worth it to someone to hit that row bonus (bonus for hitting all the squares in a vertical, horizontal or diagonal as broken down on the card).
However... I did also have another idea that I will run alongside it...
In the square that described 'Supernatural or Psycher'... there's nothing that stipulates that the psycher need be alive... MWAHAHA!
So on that basis, if it is sufficiently well painted as to justify it's own square, I will also award points for a dead psycher or supernatural - ie on a scenic base!
This used to be a Witch!
Would it be enough to qualify all my Ashland scenery as "supernatural"? :biggrin:
Of course, I guess NO. But sure that Silver shards terrain, Gnarl pits with glowing warpstone, Chaos Stargate... Could also be elligible.
More seriously, both appoach looks legit and OK to me
On 2/8/2026 at 11:55 AM, Brother Anderson said:
This post has got to be the funniest thing I've read on the B&C :biggrin:
:thumbsup: I try myself hard and harder every day.
Back on topic; some progress this week with 2 entries planned already done: the "God of War"-lord Titan and the "Something..." entries.
I will eventually add details in my blog latter today or tomorrow. (EDIT: Two out of One – something for my plodding along - Bouargh´s miniatures´ closet clean-up - The Bolter and Chainsword)
The Wytches have been built and are in the waiting list for painting:
The built is of course not that legit vs. rules and WYSIWYG; I explain: I already have one unit built when the datasheet for Ynnari wytches was released, without gladiator weapons. With the datasheet released in the Drukharii codex, up to 3 can bear such gladiator weapons. I therefore built 6 models with such tooling in prder to redistribute between the 2 units and use them in any army. I have used the bladed scourges inc. spares from the Venom crew. Other models were personalized so that they use in priority spare bits from previous sprues (dual knives from Venom and Raider crew, whip from Scourges...). Bitz managment or so: I do rather deplete old sprues from previous box rather than getting half used sprues from all boxes....
Edited by Bouargh
I have not progressed that much on my last pledge; despite a snowy weather all week end, I stayed stucked to the Olympic games instead (and to ToW miniatures / I needed painting some green).
But I've managed building up 5 Wraithguards and Inquisitor Ostramondeus + his retinue during interludes. This will be for next entries, one for "Supernatural" and second for "Leaders and HEroes"
I will resume painting 30/40k stuff this week, or at least I will try to. So, at the moment and until Whytches get some progress up to completion, my score card is still as such:
I think we may have a contender for the bonus points this month for "the funniest comment" haha!
I have decided to inject some planification in my card.
If I comply with the blue and green, it will already be a certain achievement. Red will mean that I succumbed to temptation again. And bought stuff I do not really need...
And here are the missing Wytches:
it brings my card to 6 stamps now:
As explained in a previous entry, this new wytch unit is meant to "legalize" my existing one by adding to it 3 minis with gladiator weapons. When I built my first unit based on the Ynnari Wytches datasheet the option was not defined. Now thta I may also field a small Drukharii army, I felt the need to correct thi (and add at the same time a second Wytch unit). This is how it loooks when all miniatures from both batches are mixed and redistributed:
image.thumb.jpeg.3f0491856e872980c2a783f4ac35e756.jpegimage.thumb.jpeg.1189bf2f65780f1a4f88ebdeb44f103b.jpeg
I will make a break for a few days (a.k.a. painting Gobs for TOW or working on custom scenery). But I have plenty of back log miniautres primed and ready for March!
Next pledges will be characters/Elites/Waystone zombies:
image.thumb.jpeg.163b9ed8cce6e8a04da28e952234b9f1.jpegimage.thumb.jpeg.a809c8d8b8141e182262bb1903dc4d03.jpeg
Ostomondeus retinue as a Leader, The arcuitor Magisterium as an Elite (at least this is how it was listed in HH 2.0) and Wraithblades as Undead / supernatural stuff.
