Vallejo True Metallic Metals Primer?
Go to solution Solved by Casual Heresy,
  • Solution
I just used the over normal GW primer, Grey Seer in the case of the stuff I'm currently working on. I've used Amethyst Purple and Imperial Gold so far and they cover well. I'll try and get pics when I'm home from work.
Only thing I will say is the shades flow a little differently than I am used to. They self-level really nicely but I found it easy to go too heavy on surfaces with them, but you get used to it.
Mine came (specifically Ruby Red) and I tested it over some various stuff I had already primed. Seems like it works well over medium/dark primers. It looked fine over Mechanicus Standard Gray and over Vallejo Black so I don't think you need to be too picky about what to use.
Register a new account
Sign in
