Lathe Biosas Posted April 16 Share Posted April 16 Because I like my life to be difficult, I've been swapping the heads for my Sisters of Silence (hoods just look more sinister) and now I'd like to the same to the new Custodes models. Do any of the AoS (Stormcast Eternals or others) or Space Marine Primaris helmets fit the new Custodes bodies? Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/387815-do-aos-or-primaris-heads-fit-on-the-new-custodes/ Share on other sites More sharing options...
Evil Eye Posted May 12 Share Posted May 12 (Disclaimer: I do not own the new Custodes) Theoretically I see no reason why not; you might have to either fill in or carve out the necks depending on the connection, but a head is a head, to some degree )unless it has very unusual features like large horns or whatever). I can't imagine it being very difficult as they already wear power armour. Link to comment https://bolterandchainsword.com/topic/387815-do-aos-or-primaris-heads-fit-on-the-new-custodes/#findComment-6170893 Share on other sites More sharing options...
Grotsmasha Posted May 25 Share Posted May 25 IIRC, Stormcast neck armour is a tighter fit than 40k helms, so that would imply Stormcast helms are slighter than 40k ones, which means (to me) you should be good to go. Link to comment https://bolterandchainsword.com/topic/387815-do-aos-or-primaris-heads-fit-on-the-new-custodes/#findComment-6172546 Share on other sites More sharing options...
