Posted (edited)
large.Imperium-AstraMilitarum.png.5d2ee3
Greetings Lords, Ladies, Commanders, Commissars, and Soldiers of the Imperium of Mankind.
Call to Arms is back this year, with @Dr_Ruminahui running it again.  For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th!
The forum is split up into 5 Strongholds: Imperium, loyal Astartes, Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating.  For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for the new Rapid Deployment vow.
Check out the full rules here
If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout!
Edited by Dr_Ruminahui
  • 3 weeks later...
STRONGHOLDS OPEN JUNE 15, 2025
For the Full Rules and where to place your vows for the Astra Millitarum, go to the  The Imperium Stronghold
Start Date: 15th June
End Date: 15th September
Here is a more detailed list of points per model specifically for Astra Millitarum
The below list should cover every model for the Astra Millitarum (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them);
1pt    Ratlings, Guardsmen, Scions
2pts   Ogrynn, Rough Riders
3pts   HWTs, Sentinals
4pts   Ordnance Batteries, Armiger Knights
5pts   Taurox, Chimera Chassis Tanks, Leman Russ Chassis tanks
6pts   Valkyrie, Vulture, Rogal Dorn, Malcador Chassis tanks, Macharius Chassis tanks
8pts   Baneblades, Shadowswords, Hellhammers etc)
10pts  Questoris, Valliant, Castellan, and Cerastus Knights
5pts   Psykers, Castellans, Commissars, Tech-Priests
Note: points are on a per model basis, so a command squad is 5 points for the character, the others as per the chart above (so typically 1)
40K Scale Titans
20pts Arcastus Knights, Warhound Titan
30pts Reaver Titan
40pts Warbringer Titan
50pts Warlord Titan
Terrain
1pt    3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges
2pts   Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade
3pts   Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks
4pts   Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls
5pts   Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier
6pts   Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent
8pts   Fronteris Hab Bunker, Manufactorum Administratus,
10pts Zone Morialtis Gang Stronghold
Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing.
All points are per model. For example if you pledge 20 Guardsmen(1ptx20), 3 Rough Riders (2ptsx3), Sentinal (3pts), and a Commissar (5pts), your vow would be worth 34pts
Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Astra Millitarum and the Imperium to Victory!!!  After June 15th, please do the same in the Imperium Stronghold!
Rules and Place your Vow =>  The Imperium Stronghold
For those who haven't done so already and are able, please consider donating to Bolter and Chainsword, as the current fundraising drive has not yet met B+C's yearly financial needs.  All the mods and event organizers do their work out of love for the site, and the funds being raised are to keep the servers running and the software up to date.
  • 2 weeks later...
* ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS *
Happy painting!  Be sure to cheer on your fellow stronghold participants!
As a reminder, all vows must be completed by September 15th.
I will no longer be monitoring these faction rally points - if you have any questions, please ask me in the Strongholds, by messaging me, or by choosing my name from the dropdown menu when typing @ then my name (@Dr_Ruminahui).
  • 3 weeks later...
Posted (edited)
Do we make our vows in this thread?
I have 60 guardsmen* to paint and i need motivation to paint them right miao!
oh and a leman russ from the '90s that I spent far too long refurbing >.<
so a 65pt vow?
all models either need building, are unsprayed or are at most base sprayed.
If this isn't the right place to post this let me know!
*Technically 20 to build on top of the 40 that already need painting!
Edited by ChloeLikesCrying
Register a new account
Sign in
