Dr_Ruminahui Posted May 14 Share Posted May 14 (edited) Hail noble Knight Houses! Arise Kings and Princeps of the mighty steel steeds! Call to Arms is back this year, with @Dr_Ruminahui running it again. For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th! The forum is split up into 5 Strongholds: Imperium, loyal Astartes, Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating. For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for the new Rapid Deployment vow. Check out the full rules here If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout! Edited June 1 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/387938-event-call-to-arms-2026-imperial-knights/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 1 Author Share Posted June 1 STRONGHOLDS OPEN JUNE 15, 2025 For the Full Rules and where to place your vows for the Imperial Knights, go to the The Imperium Stronghold Start Date: 15th June End Date: 15th September Here is a more detailed list of points per model specifically for Imperial Knights The below list should cover every model for the Imperial Knights (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them); 4pts Armiger Knights 10pts Questoris, Valliant, Castellan, and Cerastus Knights 20pts Arcastus Knights, Warhound Titan 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge 2 Wardens (2x10pts), 1 Valiant (10pts), 1x Arcastus (20pts), your vow would be worth 50pts Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Imperial Knights and the Imperium to Victory!!! After June 15th, please do the same in the Imperium Stronghold! Rules and Place your Vow => The Imperium Stronghold For those who haven't done so already and are able, please consider donating to Bolter and Chainsword, as the current fundraising drive has not yet met B+C's yearly financial needs. All the mods and event organizers do their work out of love for the site, and the funds being raised are to keep the servers running and the software up to date. Link to comment https://bolterandchainsword.com/topic/387938-event-call-to-arms-2026-imperial-knights/#findComment-6173361 Share on other sites More sharing options...
drakheart Posted June 12 Share Posted June 12 @Dr_Ruminahui -What about Destrier Knights? Link to comment https://bolterandchainsword.com/topic/387938-event-call-to-arms-2026-imperial-knights/#findComment-6175182 Share on other sites More sharing options...
Dr_Ruminahui Posted June 12 Author Share Posted June 12 How about 7 points? That puts is directly between an armiger and questoris. It also puts it between a landraider and a baneblade, points wise. drakheart and Focslain 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387938-event-call-to-arms-2026-imperial-knights/#findComment-6175213 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15 Author Share Posted June 15 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. I will no longer be monitoring these faction rally points - if you have any questions, please ask me in the Strongholds, by messaging me, or by choosing my name from the dropdown menu when typing @ then my name (@Dr_Ruminahui). Link to comment https://bolterandchainsword.com/topic/387938-event-call-to-arms-2026-imperial-knights/#findComment-6175581 Share on other sites More sharing options...
firestorm40k Posted July 26 Share Posted July 26 First update from me - after several weeks of building and assembling, I’ve finally been able to start painting. Here are four of the six Armigers I’m painting, prior to drybrushing and Nuln Oil wash: The legs and torso of all six Armigers have had their dry brush and wash, I’ll continue with the weapons, also I ran out of Leadbelcher spray so picked some up yesterday to finish priming armour panels and other parts of these - as well as the Questoris Knight. derLumpi and kabaakaba 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387938-event-call-to-arms-2026-imperial-knights/#findComment-6180633 Share on other sites More sharing options...
