Corbulo Posted May 20 Share Posted May 20 Hey guys, I just started playing T'au again. I was even using the For the Greater Good ability from the codex for a couple of games until I read the Balance Dataslate and saw they changed it significantly. I have a quick question about Stealth Teams when used as an observer unit. Sorry if this is a noob question. If I use a stealth team to be an observer and select an enemy unit. I then have 3 T'au units that can target that enemy unit and they are now considered guided units. Do all 3 units get to re-roll 1s to hit and wound against the spotted unit? Thanks. Link to comment https://bolterandchainsword.com/topic/387976-stealth-team-as-an-observer/ Share on other sites More sharing options...
Solution Focslain Posted May 20 Solution Share Posted May 20 The way For the Greater Good works now. You are correct. Which is why stealth suits got more expensive (point wise) outside of their expanded unit size (squad of 5 only now) Corbulo and Tawnis 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387976-stealth-team-as-an-observer/#findComment-6172088 Share on other sites More sharing options...
Corbulo Posted May 20 Author Share Posted May 20 Thanks for the reply, I appreciate it :) Focslain 1 Back to top Link to comment https://bolterandchainsword.com/topic/387976-stealth-team-as-an-observer/#findComment-6172095 Share on other sites More sharing options...
