Valkyrion Posted May 27 Share Posted May 27 Either bona-fide strategy or unlikely one off - which single unit could roll the most dice in 10th edition? Probably need at least a minor restriction - I'm talking about attack dice, so combined number of dice involving To Hit, To Wound and accompanying rerolls. I didn't play a single game, so this is simply curiosity, but think I remember a 30 strong swarm of Termagants with the right psychic powers/stratagems/hive fleet rolling over 300 dice in 9th edition. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388002-which-unit-rolled-the-most-dice-in-10th/ Share on other sites More sharing options...
grailkeeper Posted May 27 Share Posted May 27 Statistically most likely to be the most used unit which is probably tactical mari es or intercessors. Link to comment https://bolterandchainsword.com/topic/388002-which-unit-rolled-the-most-dice-in-10th/#findComment-6172859 Share on other sites More sharing options...
Valkyrion Posted May 27 Author Share Posted May 27 No, sorry, I mean a single unit - so not intercessors in general, but like *your* intercessors that used a variety of strats or skills in order to roll hundreds of dice. Link to comment https://bolterandchainsword.com/topic/388002-which-unit-rolled-the-most-dice-in-10th/#findComment-6172862 Share on other sites More sharing options...
Tawnis Posted May 28 Share Posted May 28 (edited) I'll start us off in 10th with some Kroot Carnivores. With an attached melee Warshaper and a Flesh Shaper with the Borthrod Gland enhancement (2+ to hit, 5+ Sustained in melee) I charged in a full brick of 20. Each carnivore has 2 attacks and each shaper 4 so that's 48 base. However, my nearby Lone Spear gave them full hit re-rolls, so I go fishing for crits. The mathmatical average of wound rolls there is 70. My record is 85 wound rolls. Edited May 28 by Tawnis Link to comment https://bolterandchainsword.com/topic/388002-which-unit-rolled-the-most-dice-in-10th/#findComment-6172939 Share on other sites More sharing options...
Lynn_Moore Posted May 28 Share Posted May 28 (edited) Orks. A mob of 20 Boys armed with Choppas with one being a Nob, led by a Warboss with a Big Choppa and a Squig and Painboy. With the WAAAGH active, each Boy has 4 Attacks, as does the Nob. The Painboy would have 4+1. The Warboss would have 10+2 for a total of 97 Melee attacks hitting on 2+ with Sustained 1 due to being under the War Horde... Edited May 28 by Lynn_Moore 2 Back to top Link to comment https://bolterandchainsword.com/topic/388002-which-unit-rolled-the-most-dice-in-10th/#findComment-6172997 Share on other sites More sharing options...
MadEdric Posted May 29 Share Posted May 29 20 Khorne Beserkers lead by Kharne, joined with MoE. Beserker Warband on the charge 16 chain weapons x5 so 80 S6 -1 1 4 Heavy weapons x4 so 16 S10 -2 2 Kharne 9 S10 -3 2 MoE 6 S9 -2 2 111 attacks Getting Sustained and Lethal hits. Will be rerolling 1's on hit and wound rolls. Could add -1 AP 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/388002-which-unit-rolled-the-most-dice-in-10th/#findComment-6172999 Share on other sites More sharing options...
Kommisar_K Posted May 29 Share Posted May 29 (edited) My Infernus Marines led by a lieutenant with the Immolator enhancement would like a word. That's 10D6+1, and then with the Forgefather around reroll to wound ...if he's attached (which he often was) that's another D6+3 attack. D6+4 actually, with the lieutenant. And if we count overwatch rolls that's double in a round. Edited May 29 by Kommisar_K Link to comment https://bolterandchainsword.com/topic/388002-which-unit-rolled-the-most-dice-in-10th/#findComment-6173005 Share on other sites More sharing options...
Ming the Merciless Posted May 29 Share Posted May 29 4 hours ago, MadEdric said: 20 Khorne Beserkers lead by Kharne, joined with MoE. Beserker Warband on the charge 16 chain weapons x5 so 80 S6 -1 1 4 Heavy weapons x4 so 16 S10 -2 2 Kharne 9 S10 -3 2 MoE 6 S9 -2 2 111 attacks Getting Sustained and Lethal hits. Will be rerolling 1's on hit and wound rolls. Could add -1 AP This would have been my proposition too (without the Master of Executions as you can only attach him OR Khârn as leader). 1 Back to top Link to comment https://bolterandchainsword.com/topic/388002-which-unit-rolled-the-most-dice-in-10th/#findComment-6173008 Share on other sites More sharing options...
MadEdric Posted June 1 Share Posted June 1 On 5/28/2026 at 10:15 PM, Ming the Merciless said: This would have been my proposition too (without the Master of Executions as you can only attach him OR Khârn as leader). Ack, confusing with the CSM MoE. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388002-which-unit-rolled-the-most-dice-in-10th/#findComment-6173234 Share on other sites More sharing options...
