Dr_Ruminahui Posted June 2 Share Posted June 2 (edited) Just realized I missed posting this here. Greetings all warlords and generals of the Horus Heresy. Call to Arms is back this year, with @Dr_Ruminahui running it again. For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th! The forum is split up into 5 Strongholds: Imperium, loyal Astartes, Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating. For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for the new Rapid Deployment vow. Check out the full rules here If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout! STRONGHOLDS OPEN JUNE 15, 2025 For the Full Rules and where to place your vows for the Horus Heresy go to The Heresy Stronghold Start Date: 15th June End Date: 15th September Here is a more detailed list of points per model specifically for the Heresy The below list should cover every model for the Heresy (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them); Epic/Imperialis Scale Models 1pt Infantry Base, Dreadnaught Base, Rapier Base, Jetbike/Speeder Base, Sentinal Base, Rhino, Predator, Medusa, Leman Russ, Drop Pod 2pts Sicaran, Land Raider, Spartan, Malcador, Armiger Knights, Questoris Knights, Ceratus KInights 3pts Fellblade Chassis tanks, Kratos Battletank, Baneblade Chassis tanks, Arcastus Knights, LI/AI Aircraft 4pts Thunderhawk Gunship 5pts Warhound Titan 6pts Reaver Titan 7pts Warbringer Titan 8pts Warlord Titan 10pts Warmaster Titan 5pts Leader and Unit Composition: Command Base *I am super unfamiliar with the Aeronautica Craft, so please let me know if there need to be more points gradings for the different Aircraft* 30K/40K Scale Models 1pt Power armour (all types), Terminators (non-saturnine) 2pts Bikes, Rapiers, Saturnine terminators 3pts Attack Bikes, Land Speeders, Dreadnoughts 4pts Armiger Knights 5pts Saturnine dreadnought, Rhino Chassis Tanks, Drop Pod 6pts Sicaran Chassis Tanks, Landraiders, Spartans 8pts Glaive, Fellblade, Falchion, Fire Raptor, Storm Eagle 10pts Mastadon, Astraeus, Questoris, Valliant, Castellan, and Cerastus Knights 5pts Consuls, Praetors, Apothecaries, Techmarines, Librarians, Chaplains, Chapter Masters 10pts Primarchs 30K/40K Scale Titans 20pts Arcastus Knights, Warhound Titan, Thunderhawk 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan, Stormbird Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge (epic scale models) 5 Infantry bases (1ptx5), 2 Warmaster titans (2ptsx10), 3 Landraiders (3x2pts), and a Thunderhawk (4pts), your vow would be worth 35pts. Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the forces of the Emperor or Warmaster and the Heresy to Victory!!! After June 15th, please do the same in the Heresy Stronghold! Rules and Place your Vow => The Heresy Stronghold For those who haven't done so already and are able, please consider donating to Bolter and Chainsword, as the current fundraising drive has not yet met B+C's yearly financial needs. All the mods and event organizers do their work out of love for the site, and the funds being raised are to keep the servers running and the software up to date Edited June 2 by Dr_Ruminahui Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/388018-event-call-to-arms-2026-heresy/ Share on other sites More sharing options...
Bouargh Posted June 7 Share Posted June 7 I have ooP Epic material, SM and Squat, can they be pledged here under Epic scale? Link to comment https://bolterandchainsword.com/topic/388018-event-call-to-arms-2026-heresy/#findComment-6174099 Share on other sites More sharing options...
Dr_Ruminahui Posted June 7 Author Share Posted June 7 @Bouargh - SM, definitely. Squat stuff you can pledge it here or in the Xenos forum. I figure we'll need to do a bunch of "what's it closest in size to", so we can wrangle that here or by message. Bouargh 1 Back to top Link to comment https://bolterandchainsword.com/topic/388018-event-call-to-arms-2026-heresy/#findComment-6174118 Share on other sites More sharing options...
Bouargh Posted June 7 Share Posted June 7 2 hours ago, Dr_Ruminahui said: @Bouargh - SM, definitely. Squat stuff you can pledge it here or in the Xenos forum. I figure we'll need to do a bunch of "what's it closest in size to", so we can wrangle that here or by message. I ll send pics and rooster when challenge will start, should I pledge the squats. Thanx Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/388018-event-call-to-arms-2026-heresy/#findComment-6174148 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15 Author Share Posted June 15 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. I will no longer be monitoring these faction rally points - if you have any questions, please ask me in the Strongholds, by messaging me, or by choosing my name from the dropdown menu when typing @ then my name (@Dr_Ruminahui). Link to comment https://bolterandchainsword.com/topic/388018-event-call-to-arms-2026-heresy/#findComment-6175603 Share on other sites More sharing options...
