Tawnis Posted June 17 Share Posted June 17 Something interesting I just noticed when doing some mathhammer. The new rules say the entire squad must be withing 9" of everyone else in the squad. If you have 10 models on 28.5mm bases, and line them up touching each other in a straight line, the furthest 2 models from each other will be 8.976376" apart, just a hairs breadth inside the acceptable threshold. Should be an easy way to place squads in a line if needed without fiddley measuring all the time. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388106-within-9/ Share on other sites More sharing options...
grailkeeper Posted June 17 Share Posted June 17 Whats the largest squad size possible now? Any units go beyond 20? Link to comment https://bolterandchainsword.com/topic/388106-within-9/#findComment-6176104 Share on other sites More sharing options...
Tawnis Posted June 17 Author Share Posted June 17 1 hour ago, grailkeeper said: Whats the largest squad size possible now? Any units go beyond 20? You can get up to 26 with 20 Guardsmen, a Command Squad, and an Ogryn Bodyguard. I think that's the largest? Neurotyrant and Neurogaunts are 23... Kroot Carnivores and their characters are 22. Link to comment https://bolterandchainsword.com/topic/388106-within-9/#findComment-6176112 Share on other sites More sharing options...
Xenith Posted June 18 Share Posted June 18 Remember that the bases have to be within 9", not wholly within 9", so the inner edges of 2 bases can be 8.999" away, and you can put 12 models straight line base to base and be in coherency. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388106-within-9/#findComment-6176228 Share on other sites More sharing options...
Tawnis Posted June 22 Author Share Posted June 22 On 6/18/2026 at 10:59 AM, Xenith said: Remember that the bases have to be within 9", not wholly within 9", so the inner edges of 2 bases can be 8.999" away, and you can put 12 models straight line base to base and be in coherency. It's only 12 if they are the 25mm bases, the 28.5mm ones are 10 at that distance. Link to comment https://bolterandchainsword.com/topic/388106-within-9/#findComment-6176562 Share on other sites More sharing options...
