Valkyrion Posted July 17 Share Posted July 17 Firstly, no need to be so dismissive, my opinion and your courtesy hurts no one. Secondly, that one single thought isn't exactly the problem, is it? Thirdly I'm not flat out refusing anything, I'm joining in a discussion. To clarify my point, I mean that 3+ on a D6 on average is fine with regards the hit roll. This is a wargame, things need to be hit, things need to die. My only input, mild as it was yet worthy of such condescension, was that GW could open the door to D12 saves so as to make AP carry more meaning. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179819 Share on other sites More sharing options...
Dr_Ruminahui Posted July 17 Share Posted July 17 (edited) Just going to give this a little nudge, because we aren't there yet but I don't want to see an interesting discussion flame out. 1. Please remember to be civil. Discuss and challenge each others points, not each other. 2. Conversely, people are allowed to have opinions you may not share. Describing a rule as "stupid" doesn't mean people who support that rule are stupid. So far, none of the challenges on the positions held by other posters have been, in my view, attacks on those posters themselves. Let's keep it that way. Dr. R. Edited July 17 by Dr_Ruminahui 3 Back to top Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179823 Share on other sites More sharing options...
Xenith Posted July 17 Share Posted July 17 D12's wouldn't work as tourney try-hards would get custom dice where the 1s and 7s looked very similar and just pick up all the 1s. It's hard enough to tell with just pips on some marbled d6's. I think we do need to go back to a comparative WS system though. No way should a guardsman hit Jain zar 50% of the time. Even the same as heresy works - lower WS = 5+, half the WS is a 6+ to hit. With that you can make some characters more resilient without making up special rules. 2 Back to top Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179839 Share on other sites More sharing options...
phandaal Posted July 17 Share Posted July 17 23 hours ago, HeadlessCross said: Just carry a small bag? Like, what packaging do you specifically need? I also found 50 d12s on this website for cheap, so availability is clearly false assuming you're not from the 80's and have access to the internet. Ah, a website sells them. That certainly settles global manufacturing, shipping, retail, and the controversial question of whether cubes stack better than dodecahedrons. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179855 Share on other sites More sharing options...
jaxom Posted July 17 Share Posted July 17 I’ve played around with a few variations of melee systems when I’ve been working on stuff. Here’s some of the thoughts I’ve had based on that. Comparative WS works well with a limited number of set profiles in a game (eg Horus Heresy). Comparative hits cancelling out can work, but slows things down significantly when both sides are rolling high volumes of dice. A universal “parry” system works well, and the best version I playtested would take some explaining (2nd post?). Initiative (as it was) is similar to comparative weapon skill in my opinion. Initiative works well in a psuedo-simultaneous system where casualties are removed at end of turn. Initiative provides a differential to remove a limited number of casualties “before” they can act. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179858 Share on other sites More sharing options...
HeadlessCross Posted July 18 Author Share Posted July 18 5 hours ago, phandaal said: Ah, a website sells them. That certainly settles global manufacturing, shipping, retail, and the controversial question of whether cubes stack better than dodecahedrons. Why do they need to perfectly stack? Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179870 Share on other sites More sharing options...
Antarius Posted July 18 Share Posted July 18 We know they wanted to do special dice (d8, d12) for Warcry and the idea was nixed due to production costs, so it seems unlikely they would do it for the flagship games (plus, whether you agree or not, it will likely be seen as a barrier to entry). The discussion can still be interesting, of course. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179876 Share on other sites More sharing options...
Xenith Posted July 18 Share Posted July 18 14 hours ago, Valkyrion said: GW could open the door to D12 saves so as to make AP carry more meaning My thought in this is that with save modifiers you don't actually need invulnerable saves. Having a model with a 1+ save is just as effective and identical mechanically as a model with 2+ and 4++ against ap3 weapons. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179881 Share on other sites More sharing options...
Mogger351 Posted July 18 Share Posted July 18 1 hour ago, Xenith said: My thought in this is that with save modifiers you don't actually need invulnerable saves. Having a model with a 1+ save is just as effective and identical mechanically as a model with 2+ and 4++ against ap3 weapons. That's a good point and I like that train of thought. I guess again, as with the other stats, you'd need to functionally downgrade a lot of stuff. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179884 Share on other sites More sharing options...
Antarius Posted July 18 Share Posted July 18 Part of the point of inv saves is that they sort of “cap” the modifier, though (the 1+ save in the above example would be different against a weapon with ap4 or more, for example). So there is a difference, but whether that difference is a good thing or not is probably subjective (personally, I think invulnerable saves make a lot of sense for force fields, Daemons and the like). Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179886 Share on other sites More sharing options...
Xenith Posted July 18 Share Posted July 18 (edited) I'm of the opinion that a lascannon and volcano cannon shouldn't be equally survivable by a terminator! You can put the lascannon at -3ap and the volcano at like -7ap, or -10 ap or whatever you like, with no invulnerable they will have a different effect on a 1+ or even 0+ save. Old fantasy had this, a 1 always failed, but saves better than 2+ effectively ignored some ap. I recall in 2nd ed, with modifiers, terminators rolled their 3+ save on 2d6, so even with -4 ap they still had a good chance of saving! Edited July 18 by Xenith 1 Back to top Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179904 Share on other sites More sharing options...
HeadlessCross Posted July 19 Author Share Posted July 19 5 hours ago, Xenith said: I recall in 2nd ed, with modifiers, terminators rolled their 3+ save on 2d6, so even with -4 ap they still had a good chance of saving! Which was a ridiculous idea Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179914 Share on other sites More sharing options...
Antarius Posted July 19 Share Posted July 19 7 hours ago, Xenith said: I'm of the opinion that a lascannon and volcano cannon shouldn't be equally survivable by a terminator! You can put the lascannon at -3ap and the volcano at like -7ap, or -10 ap or whatever you like, with no invulnerable they will have a different effect on a 1+ or even 0+ save. Old fantasy had this, a 1 always failed, but saves better than 2+ effectively ignored some ap. I recall in 2nd ed, with modifiers, terminators rolled their 3+ save on 2d6, so even with -4 ap they still had a good chance of saving! A terminator is one thing, but what about a Daemon or a guy with a force field generator? Just trying to figure out whether you're of the opinion that invulnerable saves should go all together or just be rarer than they are now (the first I would disagree with, the latter I would probably be inclined to agree with). Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179920 Share on other sites More sharing options...
jaxom Posted July 19 Share Posted July 19 I really liked the brief period of time when daemons had two saves, one for melee and one for shooting. I felt it captured the same sense of fighting them that’s been present in some of the books and codex lore snippets. Personally I don’t see a big difference between force fields and physical armor. If one can be an invulnerable save than so could the other; sci-fantasy nonsense and all that. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179933 Share on other sites More sharing options...
Mazer Rackham Posted July 19 Share Posted July 19 *Observes the discourse from his Percentile Dice Ivory Tower* I think the premise of D12 is interesting, didn't Advanced Space Crusade use D12? Many, many years ago, I played a few '40k' games with friends just using those rules as a base, (since there was a small bestiary, and I think stuff in WD). They work fine, fun times were had. I still have the D12's IIRC. However, you could solve any problem of shipping or manufacturing by doing what Warzone: Resurrection did, and go to D20. Far more values to be had there, plenty of penalties imposed and could still survive, whilst some stuff just wiped your guys out. No Invulns there per se IIRC, just 'This value cannot be modified' type stuff. Plenty of D20's obtainable. Not as stackable, but that's what pockets and orifices are for. 1 Back to top Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179939 Share on other sites More sharing options...
Evil Eye Posted July 19 Share Posted July 19 1 hour ago, Mazer Rackham said: *Observes the discourse from his Percentile Dice Ivory Tower* I think the premise of D12 is interesting, didn't Advanced Space Crusade use D12? Many, many years ago, I played a few '40k' games with friends just using those rules as a base, (since there was a small bestiary, and I think stuff in WD). They work fine, fun times were had. I still have the D12's IIRC. However, you could solve any problem of shipping or manufacturing by doing what Warzone: Resurrection did, and go to D20. Far more values to be had there, plenty of penalties imposed and could still survive, whilst some stuff just wiped your guys out. No Invulns there per se IIRC, just 'This value cannot be modified' type stuff. Plenty of D20's obtainable. Not as stackable, but that's what pockets and orifices are for. I've heard a lot of good things about Warzone in its many forms (friend of mine is big into it); I really need to take a peek at the rules... But yes, D20 would definitely be a good choice for a non-D6 dice to use, at least partly because it's a relatively common one in other games. 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179942 Share on other sites More sharing options...
Mazer Rackham Posted July 19 Share Posted July 19 (edited) Last off topic from me, promise. 31 minutes ago, Evil Eye said: I've heard a lot of good things about Warzone in its many forms (friend of mine is big into it); I really need to take a peek at the rules... Do yourself a favour and check it out - the ruleset/fluff was written by Bill King, IIRC. Edited July 19 by Mazer Rackham 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179945 Share on other sites More sharing options...
phandaal Posted July 19 Share Posted July 19 1 hour ago, Mazer Rackham said: Do yourself a favour and check it out - the ruleset/fluff was written by Bill King, IIRC. It was indeed. You'll find some other legendary names associated with Warzone too, like Mark Copplestone and Bob Naismith. It was actually based on an RPG with even MORE lore than the wargame. Mutant Chronicles/Warzone is an awesome setting that had a lot of potential until the company that made it went epically nuclear. I was a Bauhaus fan back in the day. Good times. 3 Back to top Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179957 Share on other sites More sharing options...
Xenith Posted July 19 Share Posted July 19 18 hours ago, Antarius said: A terminator is one thing, but what about a Daemon or a guy with a force field generator? Should a rosarius provide identical protection from a power sword and a volcano cannon? I don't think so - power fields and things get overpowered and shorted out also. Things like "rosarius" could be +2 to a save characteristic. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6179968 Share on other sites More sharing options...
Tawnis Posted July 20 Share Posted July 20 On 7/18/2026 at 1:42 AM, Antarius said: We know they wanted to do special dice (d8, d12) for Warcry and the idea was nixed due to production costs, so it seems unlikely they would do it for the flagship games (plus, whether you agree or not, it will likely be seen as a barrier to entry). The discussion can still be interesting, of course. They did do both D12's and D6's for the bespoke Apocalypse rules a little while back though, so it's not outside the realm of possibility for their games to pick up on it, though I do agree that rolling it out for a flagship game is incredibly unlikely, even if I do think it would be a general improvement. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6180006 Share on other sites More sharing options...
HeadlessCross Posted July 20 Author Share Posted July 20 On 7/19/2026 at 9:10 AM, Evil Eye said: I've heard a lot of good things about Warzone in its many forms (friend of mine is big into it); I really need to take a peek at the rules... But yes, D20 would definitely be a good choice for a non-D6 dice to use, at least partly because it's a relatively common one in other games. I'm definitely not against D20, I was just more thinking about the ease of transitioning stat lines of units and weapons. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6180057 Share on other sites More sharing options...
jaxom Posted July 20 Share Posted July 20 20 minutes ago, HeadlessCross said: I'm definitely not against D20, I was just more thinking about the ease of transitioning stat lines of units and weapons. I can see that. Personally, I figure the dice size is more about granular scale. Would one want 1/12 to be the “knob” to turn or 1/20? Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6180058 Share on other sites More sharing options...
roryokane Posted July 20 Share Posted July 20 I was gonna say - why do D12 when D20 exists? In the interim, though, I agree with the 2D6 saves for some units like 2nd Ed terminators got (allowing for them to save against some truly monstrous modifiers). Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6180059 Share on other sites More sharing options...
Antarius Posted July 21 Share Posted July 21 One argument in favour of d12 over d20 would be that a d20 is a lot more "swingy" than a d12. Which would also be an argument for d6, I guess. Whether it's a compelling argument is probably a matter of taste. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6180064 Share on other sites More sharing options...
Antarius Posted July 21 Share Posted July 21 On 7/19/2026 at 11:16 PM, Xenith said: Should a rosarius provide identical protection from a power sword and a volcano cannon? I don't think so - power fields and things get overpowered and shorted out also. Things like "rosarius" could be +2 to a save characteristic. My concern is not so much with doomsday weapons as with regular weapons with AP, which would presumably also be affected. I find that going straight to the outliers tend to blur the implications for the "everyday" issues of the game. As with everything else, it's a matter of taste of course, but I personally like the idea that a Daemon is equally likely to be unaffected by, say a heavy bolter and a bolter (or a bolter and a lasgun etc. etc.). I don't really see any way, bar invulnerables, to produce that effect. Link to comment https://bolterandchainsword.com/topic/388255-dice-systems-d12-v-d6/page/2/#findComment-6180065 Share on other sites More sharing options...
